Question about Memorex MVT2135 13 in. TV/VCR Combo
Some of my channels on my tv dont work with the converter box
When i hooked up my converter box to my television and programmed all my channels to the box i noticed that one of my channels will not work. when i checked the problem out on the screen it said that im not getting any signal- how do i correct this problem-sometimes my other channels will do that also but not allm the time
  • 22 Answers
Sound like you need a stronger antenna. Weather also effects signal strength, thus a lot of wind and rain and the signal can go away.
Posted on Jun 02, 2009
  • 30 Answers
Www.antennaweb.org
If you live closer than 15 miles, rabbit ears
If you live closer than 20 miles, omnidirectional
If you live closer than 50 miles, midrange outdoor (oldschool arial w/ rotator)
Further than 80 miles, you'll need a long range with rotator, perhaps even an amplifier to go with it. Print off what your results were on antenna web and bring it to a RadioShack or a local antenna store and they should be able to point you to the right antenna for your particular location.
  • iamldyscarlt Jun 02, 2009
    www.antennaweb.org
With Sony KP-46WT520 46 in. Rear Projection HDTV-Ready Television, does it receive digital signal over air? Do I need the separate digital converter box? What do I hook up where to get channels? and how do...
Hi Gwen,
This TV set doesn't have a digital tuner and you will need a digital converter box to receive over the air channels.
You still an antenna to receive the signal and then to connect it to your digital converter box. The programming should be easy.
The converter box should come with the user's guide on how to hook it up and program it.
Jan 13, 2018 | Sony KP-46WT520 46" Rear Projection...
Im not sure how to hook the converter box up to it
For a digital to analog converter box, connect your antenna cable to the converter box. Then pick your output connection. Either set the TV to channel 3 or 4 and connect the coax out from the converter to the TV or connect the composite video (AV) to one of the A/V inputs on the TV (change the TV source to the appropriate input). The source is changed with the remote (TV/Video button).
If you have other devices like a VCR in the connection sequence, you could connect the converter box to the VCR (and record on channel 3 or 4) and then connect the VCR to the TV as above. You will be limited to recording and watching the same program unless you get another converter box or tuner.
Programming the remote will depend on the box. For other set top boxes, the connections will be very similar.
I hope this helps.
Feb 17, 2011 | Sony KV-32FS10 32" TV
DTV converter box needs specific channel
My GE tv, an older model, no longer works on channels 3 or 4 while hooked to my DVD/VHS player. I have to set my tv to channel 91 and I use the player to change channels.
Jan 28, 2009 | GE 25GT240 25" TV
How to record ditigally on old comb tv/vhs
If you have the box hooked up to your 1996 combo turn or tune on channel 3 if the converter box is selected to channel 3 you should get all your digital reception from the box to your tv/vcr. Select what you want to watch or tape on the box, what you see on your tv will record to your vcr when you select record.
Jan 14, 2009 | Televison & Video
Cannot hook up ps2 to durabrand model DWT1304
yes , you need to be in GAME mode on the TV , since you don't have the remote you can still access GAME mode from the menu button on the front of the TV . you must be in GAME mode for your PS2 to work. thanks
Dec 30, 2008 | Durabrand DWT1304 13" TV
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the...
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Dec 16, 2008 | Toshiba 27AF42 27" TV
DTA800B1 how or should I say why can I not see channels on the VCR when the converter is hooked up to it and the tv works just fine but will not set the channels on the vcr
instead of putting the converter box on ch4 ,put it on ch3 same as the vcr . set the converter box channel for the channel to be recorded, program the vcr to channel 3 for the channel to be recored. set the time and date on the vcr progam.tv does not need to be on for the program to be recored but the converter box needs to be on.
Aug 21, 2008 | RCA Televison & Video
Record to vhs with converter box
I need to leave my TV on channel 3 and set the converter to the channel I want to record. When programming for future recording, it's always from channel 3, not the channel I want the converter displaying.
Jul 17, 2008 | Samsung CXN2085TP 20 in. TV/VCR/DVD Combo
I have purchased the converter box to receive digital signals and my tv doesn't have the red/yellow/white connections. Is there a model of converter that will work on this tv which is an RCAModel F25423...
THE CONVERTER BOX HAS R.F. OUTPUT. JUST HOOK IT UP AND PUT THE T.V. ON CHANNEL 3.(OR WHAT EVER THE INSTRUCTIONS THAT CAM WITH THE BOX) YOU WILL NEED TO CHANGE THE CHANNELS WITH THE REMOTE THAT CAME WITH THE BOX. YOU MIGHT NEED TO SET UP THE BOX (SCAN FOR CHANNELS) THAT IS ALL IN THE INSTRUCTIONS THAT CAME WITH THE BOX.
DON.
Jun 15, 2008 | RCA Televison & Video
Memorex MVT2135 13 in. TV/VCR Combo Logo
102 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
