Question about Toshiba Satellite Computers & Internet
Toshiba satellite L850D dim screen can't adjust brightness
ghost_cyrix
  • 33 Answers
SOURCE: Screen Brightness gone too low on toshiba satellite 1110 laptop
Hello Tim,
Sorry to answer u by this news :
this problem u have happening by 2 cases ..
1st Case :::: that's maybe ur screen lamps is broken ..so u can see the data but very dark or no Back-light .. so u will need to replace the screen..or advanced option but with expret person to change the lamps from another broken sceen,,
2nd Case ::::: The high-voltage board..it's small board built below the screen to give the screen the right voltage to light on .. so u will need to replace it also ..or Advanced option also but with expert electronic person to check it ..
best luck.
Posted on Dec 01, 2008
  • 221 Answers
SOURCE: how do i adjust the screen brightness
To adjust screen brightness on a laptop press the Fn key at the lower left of the keyboard and then press the arrow key's at the lower right of the keyboard.
Posted on Apr 17, 2009
  • 452 Answers
SOURCE: Toshiba Satellite Pro A200. Screen has gone very
Most likely the backlight gone bad. It could also be the inverter. but try the backlight first, it's cheaper and easier.
Posted on May 04, 2010
lorievans222
  • 10 Answers
SOURCE: How to adjust screen brightness on Toshiba
You can adjust the the screen brightness by hold down the FN key and hitting F6 or F7. F6 will decrease the brightness and F7 will increase the brightness.
Posted on Jul 13, 2010
joecoolvette
  • 5660 Answers
SOURCE: laptop toshiba satellite p200 bw5
An LCD screen cannot produce enough light by itself. It needs a Backlight to help illuminate the screen.
Power for the Backlight is produced by an Inverter. An Inverter also provides power for the LCD screen.
It reduces voltage for the Backlight, and increases Voltage for the LCD screen, from the laptop's power.
Most of the time a dark LCD screen can be attributed directly to a bad Inverter. (Around 90 percent)
A Backlight is a CCFL.
Cold Cathode Fluorescent Light.
VERY similar to the fluorescent lights you see used in residential, and commercial applications.
(Homes, and businesses)
Only on a MUCH smaller scale in physical size, and needed power to operate.
When a Backlight goes bad, it just goes all at once. Not goes dark as you have stated.
(Your statement meant to me that you power on the laptop, the LCD screen shows well, then goes dark)
How to install an Inverter in a Toshiba Satellite P200 series laptop,
http://www.irisvista.com/tech/laptops/toshiba-satellite-p205/take-apart-display-panel-1.htm
(You can click on each individual photo to enlarge. You are on Page 1. Page 2 is accessed at the bottom, by clicking on it. Page 1::Page 2::Find another model)
Just one of many places that offers an Inverter for your Satellite P200.
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=5367&zenid=43bc1e775a9ed2d4309140111231cab5
NOTE*
1) ALL power removed from the laptop before beginning.
AC adapter (Charger), and Battery.
2) The screws you will remove, may have screws that look alike, but are NOT.
Do Not mix them up.
For this reason it is suggested to use a multi-compartment container, and label the compartments for where the screws came out of.
You can use a clean egg container, and label the individual egg holders, in a pinch.
IMHO it isn't hard to perform this repair, and you can do it. Save yourself money.
For additional questions regarding this, or comments, please post in a Comment.
Regards,
joecoolvette
Posted on Oct 22, 2010
Toshiba L850D bios password
If removing CMOS battery did not help, you need to do the BIOS reset from jumper on motherboard.
Apr 22, 2014 | Computers & Internet
Help. I can't adjust the brightness on toshiba satellite C870. It's new to me and hard to use in different rooms. fn/f2/fn/f3 does not work.
First are you using battery power, does it brighten when plugged in ? Go to the Taskbar Notifications Area look for the battery/power Icon right click choose Power Options click openPower Options, you will fid your Power Options located here, Your laptop probaly is defaulted to Power Savings, I use High Preformance, change them to your preferences, REMEMBER, There is a reason the laptop dims on battery, to save energy and extend battery between charges.
Nov 06, 2012 | Toshiba Satellite C870-ST2N03 : Laptop...
Toshiba tecra a2 screen backlight problem the is screen not lighting up at all but in bright daylight fully functioning screen can be seen could this be the lcd inverter and how difficult is it to replace
screen not lighting up is either the screen inverter or a broken tube inside the screen. Tubes don't break by themselves so a dim screen usually comes after a transport or a drop. I would replace the inverter first (just cause it's easy and cheap). eBay's a good source for inverters and screens and you ought not pay more than $5 for a used inverter and anything more than $30 for a used screeen would be considered tourist price. Tecra A2's are rare, but it's the same as the more popular Satellite A55's. Its screen should be a 15" XGA and would be the same screen as many other Toshiba Satellite models (A10, A15, A40, A45, A55) and Satellite Pro models (M10, M15), to name a few.
In my opinion, dim screens are 98% broken tubes and 2% inverters.
Jul 29, 2011 | Toshiba Tecra A2-S336 Notebook
The screen on my Toshiba Satellite L305-S5933 PC Notebook suddenly got very dim, to the point that I can barely read/see anything. I tried adjusting the brightness in control panel; the slider is all the...
Probable inverter board failure; this supplies high voltage to the fluorescent back light(s).
You can see what they look like here:
eBay-Toshiba inverter boards
The first characters of your model number - L305, are the most important, the others detail items such as CPU, hard drive, etc.
Dec 01, 2010 | Toshiba Satellite L305-S5933 Notebook
How to adjust screen brightness on Toshiba Satellite 1005-S157
Jul 13, 2010 | Toshiba Satellite 1005-S157 Notebook
The screen on my Toshiba 1130 has dimmed.Is there any way I can get it brighter, or use an external monitor?
For a quick adjustment of the screen brightness you can also try using the key combinations Fn+F6 (darker) and Fn+F7 (brighter).
Mar 30, 2010 | Toshiba Satellite 1130-S155 Notebook
My acer netbook screen is always dim even when it is plugged into the wall
adjust brightness settings on most acer laptops u hold the FN key and press one of ur arrow keys quite often the left and right for brightness up and down hope this helps
Mar 11, 2010 | Toshiba Satellite 5205-S503 Notebook
I have a toshiba a45-s250. the screen is dim but
Have you adjusted screen brightness control as I have seen lots of Laptops with the screen brightness control "bumped" to min.!!!
Nov 20, 2009 | Toshiba Satellite A45-S250 Notebook
Toshiiba Screen Dimmin
bad video, possiblem, but if the battery is low needs a recharge, to see if problem persists remove battery and run soley on home power.
Jun 29, 2008 | Toshiba Satellite A135-S4527 Notebook
I'm using a toshiba 4300 satellite pro 4300 series laptop, i don't know how to dim the screen. i've tried pressing Fn and various F keys to no avail. Please don't reply in computer language because i'
Hi. According to the user manual, the Fn + Esc (key)displays the screen brightness pop-up window which are: super bright; bright and semi bright. You may want to check out Toshiba 32-bit Online User's Guide for Satellite Pro 4300 Series (5790)at http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=107128&moid=1073769765&BV_SessionID=@@@@0579949615.1140817607@@@@&BV_EngineID=cccfaddhdidhgdecgfkceghdgngdgmm.0&ct=DL. Hope this works out ok for you. Regards.
Apr 09, 2007 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
Computers & Internet Logo
114 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
