Question about GTO Inc. / Mighty Mule Gate Opener Battery Heater
Mighty mule error 3 short beeps
Gate opened a few inches and stopped. Now getting 3 beeps, a few second delay, 3 more beeps. Beep cycle continues
3 Suggested Answers
  • 4 Answers
SOURCE: my mighty mule gate opener
In order to provide a solution to the problem, we need to know what it's doing. Does it start opening? Not open at all? Act like the battery is low.... I have one of these and it hasn't been non-problematic..
Posted on Feb 10, 2011
sittingducks
Condensation inside the arm shorts the limit switch in the rev counter board in cool damp weather.
Open the arm, dry the board and mop up the condensation inside the casing.
The solder contacts to the limit microswitch will corrode over time, and the board will eventually need to be replaced. Part RVCTBD50-E or similar.
Posted on Jun 18, 2016
Gate beeps when turned on and opens on its own mighty mule dual gate
There are limit switches that set the open and closed position and also a sensor for obstructions. Check those items for shorts and proper connection
Feb 10, 2017 | Cars & Trucks
What is the u shaped component on the rev.counter card called? Where can i purchase this component?
  1. Mighty Mule Parts - Gate Opener Parts & Accessories‎
    Adwww.mightymule.com/Accessories‎Cable Gate Lock
  2. Driveway Alarms
  3. Gate Opener Kits
  4. Where to Purchase
Search Results
    Mighty Mule Store ' Genuine Mighty Mule replacement parts
    www.mightymulestore.com/Mighty-Mule-Gate-Opener...Parts-s/21.htm
    Genuine Mighty Mule Replacement Parts. Choose a Product Category. Mighty MuleFM200 Automatic Gate Openers · Mighty Mule FM350 and FM352 Gate ...‎Mighty Mule 500 Parts - ‎FM350 or FM352 - ‎MM600
    Mighty Mule 500 Parts ' Shop Accessories and parts for the ...
Jan 01, 2016 | GTO Mighty Mule Automatic Gate Opener For...
PC power on but doesn't display anything on the monitor and has a beep code of different intervals of time. Here are the beep codes: 2 beeps, after 1 sec, 8beeps, after how many seconds 2 beeps after how...
AMI BIOS beep codes
Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions Document
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
For more information go to: http://www.computerhope.com/beep.htm#04
Jan 09, 2011 | EliteGroup P4VXASD2 Motherboard
Inspiron 531s will not boot up, keeps beeping, saying it is in power save mode. How do I fix the problem
System Beep Codes The Inspiron™ 531 / 531s system can emit a series of beeps during start-up if the display cannot show errors or problems. These series of beeps, called beep codes, identify various problems. One possible beep code consists of repetitive three short beeps. This beep code indicates the computer encountered a possible system board failure.
The series of beeps has a 3-second delay before it repeats. The series and delays continually loop until you press the power button.
Code Description Suggested Remedy 1 BIOS ROM checksum in progress or failure System board failure; covers BIOS corruption or ROM error 2 No memory modules detected
  1. If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  2. If available, install a good memory module of the same type into the computer.
  3. If the problem persists, contact Dell.
3 Chipset error (North and Southbridge chipset, DMA/IMR/Timer Error for Intel® platform); chipset error System board failure. Power LED is blinking amber. Time-Of-Day Clock test failure Gate A20 failure Super I/O chip failure Keyboard controller test failure 4 RAM read/write failure
  1. Ensure no special memory module/memory connector placement requirements exist.
  2. Verify the memory modules you are installing are compatible with the computer.
5 Real time clock failure. Possible battery failure or system board failure.
  1. Replace the battery.
  2. If the problem persists, contact Dell.
6 Video BIOS test failure Video card failure 7 CPU cache test failure Processor failure
Oct 06, 2010 | Dell Inspiron 531s Desktop Computer
Does anyone repair pc boards for the Mighty mule gate openers?
Hello, im sorry to hear that you are having trouble with your gate opener. but it depends, on if your opener is still under warrenty and how the board got damaged, GTO "which is the manufacturer of mighty mule" is very picky about returning goods, so you MIGHT be able to get it replaced, but just getting it repaired is out of the question because of the components being heat sensitive and having software in the board, if you have more questions please email me a jasonruis123@yahoo.com
Dec 17, 2009 | Gates Deer Fence: Mighty Mule Driveway...
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
I have a mighty mule gate opener model number 352 and the cycles only open and close two inches. How can I have it properly open
Check the STALL FORCE setting on BOTH openers, check for gate obstructions broken gate hardware. OR your limit settings have been erased, but if none are the problem that you have a broken REV COUNTER which is inside the arm
Oct 18, 2009 | Gates Deer Fence: Mighty Mule Driveway...
Gate open and beeping,it will not close
Well if your board is getting power and the power supply is ok, but when you try to activate the opener, and do not get a response, than you have a faulty board, im Guessing you have a GTO 1000, Mighty Mule 700, or Mighty Mule FM500 series
Mar 13, 2009 | GTO Inc. / Mighty Mule Gate Opener Battery...
Laptop won't boot up. Only 3 beeps.
listen to the beep heres some information on beep code errors
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 25, 2009 | Toshiba Satellite X200-AA3 Notebook
GTO Inc. / Mighty Mule Gate Opener Battery Heater Logo
599 people viewed this question
Top GTO Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a GTO Pool and Spa Expert? Answer questions, earn points and help others
