Question about Whirlpool GFG461LVS Stainless Steel Gas Range
Whirlpool GFG461LVS oven shuts off during pre heat
Turning on the oven to lets say 425. the unit begins to pre heat the temp rises but later shuts off. leaving food uncooked sometimes when temp level is reached to cook. does this on convection oven as well.
  • 1462 Answers
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Posted on Apr 03, 2007
  • 146 Answers
SOURCE: Gas oven not heating to temp
You more than likely have a defective oven sensor. For some reason the sensors tend to go after a few years of use. It is in the upper right or left hand corner and looks like a probe sticking through the inside back of the range. When you open the door you just look towards the top back left or right corner there are 2 screw securing it to the back. Gently pull it forward. You will see a couple of small wires feed into as you pull it in. On most you will see a plug in connector come through the hole if not you may have to just splice the new one in.
Posted on Dec 21, 2007
  • 409 Answers
SOURCE: whirlpool gs475lems range oven problems
it means bake range over temperature.
have a technician check out the oven temp sensor. you may have a short in wiring or it may need to be replaced.
if problem still persists, replace the clock.
Posted on Sep 13, 2008
SOURCE: Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Posted on Nov 24, 2008
  • 10865 Answers
SOURCE: Whirlpool Super Capacity 465 Electric Range not heating properly.
Here are two instances of when food "bakes poorly:"
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Posted on May 29, 2009
Oven won't pre-heat or reach bake temp?
Could be the oven thermostat, that's the long skinny tube with the thin copper pipe coming off it follow it back to the oven knob. Test it by putting a putting an oven thermometer in and compare the difference they only cost a few dollars at good home ware shops.
May 07, 2014 | Maytag MGR5751AD Gas Kitchen Range
Runaway oven temp
What is the make and model number of your unit?
Feb 14, 2013 | Kitchen Ranges
Samsung oven error codes
you need the service rep or repairman
Jan 12, 2012 | Ovens
My Sharp microwave convection oven (R-967M / R96STM) cuts out during convection pre-heating and cooking, It appears it stops heating after 1 min. If the START button is pressed again the oven starts...
Also the fact it is a convection oven could mean the oven temperature sensor is not picking up the oven temp. it is not telling the machine it is there by the board seeing its resistance, the unit will shut off as a safety feature. The oven sees temperature by reading the value of a temperature dependent resistor. As the temperature changes so does the value of the component ( oven temp sensor) that way the unit determines the temperature inside the unit. Sometimes those sensors will break since they are in the area with the heat and moisture, they get old and break.
Aug 17, 2017 | Sharp Microwave Ovens
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
Oven not heating up
Problem with oven sensor or control board (ERC). Oven sensor at room temperature should have resistance about 1080 Ohms, and it rises with temp rise.
Nov 26, 2009 | Kitchen Ranges
Oven won't pre-heat
This is a failed oven temp sensor. the control is not receiving a proper resistance signal from this sensor at this time. the control will shut down the unit if this is the issue. check the oven temp sensors connections form the control to the sensor housing for loose or worn contacts, if the wiring is ok, replace the temp sensor.
Sep 24, 2009 | Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Oven Temp
After it drops temperature, how do you get it back to the desired degrees? It sounds like the thermostat isn't keeping up.
Nov 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool GFG461LVS Stainless Steel Gas Range Logo
117 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
