Question about Technics Audio Players & Recorders
When I turn on my SL-MC300 dusc changer, it shows checking discs and the goes to error. Turning off and back on does no good. What's wrong?
This is a Model SL-MC300 110 Disc changer that gives error report after going through checking discs. It makes a humming noise but nothing happens.
  • slucru_2 Jan 25, 2013
    The problem was a worn out drive belt that I replaced with a #33 1 1/16 OD x 15/16 ID -1/16 Wall O Ring.
    Genius:
  • Technics Master
  • 1,054 Answers
Loading mech is out of alignment. Should take it in for a trained person to look at.
Posted on Jan 23, 2013
  • slucru_2 Jan 23, 2013
    I took cover off and found drive belt had come off. I went to hardware store and bought a #33 O ring that repaired the unit very nicely. Thank you to MelaciousMel who suggested the O ring at the hardware store.
SOURCE: Looking for a drive belt
A rubber "O" Ring as a belt solved the problem.  At our local hardware store:  1 1/16 OD x 15/16 ID - 1/16" wall  $0.39!
Posted on May 21, 2009
SOURCE: Panasonic SCAK16 5-Disc CD Changer Problem
You need to clean up the cd sistem and put it on time again
Posted on Nov 04, 2008
localwonder
  • 6784 Answers
SOURCE: Technics SL MC60 reading error
Hi, this will occur when the optical lens assembly becomes unstable or, damaged. this Assembly incorporates many gears and levers and motors as well. the lens assembly works together with the loading dock.
The laser rides on a rail that is used to allow proper scanning of the inserted media and, if this optical assembly becomes misaligned or unstable, it will not read or track properly as you are experiencing.
I recommend replacing the optical lens assembly asap if possible. it is damaged. We recommend contacting a service depot fro this type of repair.
Posted on Jun 18, 2009
donnydo77
SOURCE: technic sl-mc7 110-disc cd changer
The problem is likely the carriage drive belt. The player is well over 10 years old so the belt gets stretched with use. Then it is unable to transfer power for moving mechanisms.
If you feel comfortable about opening the cover using proper electrical safety procedures then you can observe what the carriage is doing upon turn on. Unplug the player, remove the cover by unscrewing four fasteners (I think, but you can easily figure it out), plug in and power up. The carriage should go through a positioning calibration and disk checking sequence (simply, it moves out of the home position, travels across the player and repositions itself to await front panel input).
Yours probably doesn't so look at the belt on the top of the carriage. If it is off the drive wheels, remove electrical power, then simply put it back on, power up, and recheck.
If the belt is spinning on the wheels and seems loose then it needs replaced. Fortunately, here is an inexpensive and attainable replacement courtesy of another FixYa poster
http://www.fixya.com/support/t1616894-looking_drive_belt
Also, a clean up and lube of the mechanisms would be a good thing to do. That takes some technical know how to clean without damaging and applying the correct lube in the right amounts to the appropriate mechanism components. Some general references are available in electronic service books or online. I should probably launch a site!
Otherwise, without knowing the conditon of other components in the drive assemply, a service manual is required to proceed with further troubleshooting specifically for the player.
Hope that the K.I.S.S. approach helps you enjoy your player again.
Posted on Aug 06, 2009
SOURCE: Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Posted on Nov 03, 2009
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya
www.fixya.com > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
Dec 29, 2015 | Technics SL-MC4 61-Disc CD Changer
When i turn my technics cd player all i see is error
Technics CD Changer SL-MC400
The ERROR Is Cause By The Belt Drive
Remove The Cover And You Can See if
The Belt is Lose or slip of In Any Case
You Must Change That RUBBER DRIVE BELT.
Dec 31, 2013 | Technics SL-MC400 110-Disc CD Changer
Tech SL-MC410. Continously displays "Checking Disc"
When the unit is saying "Checking discs" and neither goes further nor turns off (just says "Off" but doesn't), the reason is still the main belt (accessible from the top as soon as you lift the cover) that is too loose. When the belt is way too loose, the unit doesn't move at all, if the belt is little too loose, the player-unit will move a bit, but there is not enough torque on the gears to reach the end position (where the player unit is secured against movements).
May 07, 2012 | Technics SL-MC400 110-Disc CD Changer
I have not played my cd changer for a year and when I just try to play a cd now the system appears to look for cd but the word error comes up on the display. Just the word error not number. Any ideans...
Hi!
I dont't think that your cd-changer is broken. It may only need some cleaning. One year is time enough for dust to set on optical reader. I suggest to use a cleaning disk, available on every store selling optical media.
Hope it helped,
Bogdan
Sep 23, 2011 | Technics SL-MC70 60-Disc CD Changer
SL PD887 5 disc CD changer was working one day but not the next day - does not read the CD - goes from one CD to the next but unable to read each CD in the changer. Have changed the CD's and cleaned the...
I have a model sl-pd847 and experience similar problems to many other submitters. I checked the main pcb and found discolouration around what appear to be 2 (power?) transistors and probably a voltage regulator. After about 4-5 minutes after switch on these get really hot. I suspect that may be the reason why it doesn't work anymore. Worth fixing? I don't think so. This one didn't even play CD-R let alone CD-RW! Get something a bit more up to date I say.
Jan 16, 2011 | Technics SL-PD887 5-Disc CD Changer
When i turn on my technics cd player model number sl-mc409 it comes accross the screen f-26 and won't do anything. what does f-26 mean
I've just bought a used changer, that shows the same error. The instuction says " unplug the changer from its outlet, replug it in an turn the changer ON again"
That doesn't help in my case.
Have you found a solution?
May 01, 2010 | Technics SL-MC400 110-Disc CD Changer
Display reads No Disc despite all the discs checking out.
Hi, the optical lens assembly has failed. this is triggering the (no disc) error code. you will need to replace this failed optical assembly.
May 29, 2009 | Pioneer Car Audio & Video
10 disc changer shows error code or no cd
maybe the lens in covered with dust , try to clean it , or it is broken. Who knows , break the device and see it for yourself. good luck
Apr 02, 2009 | Sony CDX-2250 CD Changer
Looking for a drive belt for a SL MC300 Technics 110 CD changer
Jan 29, 2009 | Technics SL-MC7 110-Disc CD Changer
CD Changer won't read CD
cd changer showing message display ERROR 2 . i CHECK THE MANUAL AND COMPLIED WITH ADVISE TO NO SUCCESS, WHAT IS WRONG
Nov 12, 2007 | Panasonic CX-DP801 8-Disc CD Changer
335 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
