Question about Canon Office Equipment & Supplies
Canon Copier NP6412F Error Code alternate flashing E8 then 03
When attempting to make a copy the paper appears to catch at 1st entry position (pivoting paper guide mechanism) and machine stops and displays error message. Have repeatedly tried clearing, unplugging from power source, etc.and occasionally can make a copy or two before problem repeats itself. Any suggestions on how to fix the problem will be appreciated.
  • 208 Answers
SOURCE: How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
Posted on Dec 20, 2007
SOURCE: Canon 850 E001 Error
I entered service mode and it fixed itself.
With the front panel open and the copier lid/carriage lifted up, I used a paperclip and stuck it in the small hole on the center of the front grey panel (the covering of the DC controller) . I simultaneously used a pen to hold down the tab in the slot on the lower left edge that makes the copier think the lid is down...then I hit the power button. It reset the error code and all is OK now.
Posted on Apr 24, 2008
  • 47 Answers
SOURCE: canon ir-c3100 copier error code
The ITB or Intermediat Transfer Belt is slipping or not being driven properly. It is NOT fun to take out, particularly if you have a finisher attached. If you have proffessional experience with copiers and are really determined, let me know and I may be able to set you up with a manual. Otherwise, call a pro.
Posted on Jul 26, 2008
SOURCE: changing the drum
I fixed the problem (following the user's guide).
1. After reinstalling the new drum unit into the printer, keep the front cover open.
2. Press "Clear/Back" on the machine
3. Press "1" and when the LCD shows "Accepted", close the front cover.
Posted on Aug 07, 2008
SOURCE: canon ir6000 error codes E000061-0001..
error E061 poblem
Posted on Dec 02, 2008
Need help. Flashing E2 and 61 codes. The paper is not jammed and it has a new carterage.
Canon PC-920 Black and White Copier E2 error - Questions ...
www.fixya.com > ... > Canon > Canon PC-920 Black and White Copier .. error code e7 & e2 Cannon pixma mp145 printer error code e7 & e2 E2: Reload the paper correctly and press [Black] or [Color]. E7: The cartridges are not ..
Jul 21, 2015 | Canon PC-920 Black and White Copier
Canon ir 2270 having a problem of paper jam but it doesnt show any error code can you help me solve this problem. by Fredy Gabriel
if it has a paper jam. it should show on the display/panel which the position jammed.
then you open up the cover of it..
Jun 08, 2011 | Canon imageRUNNER 2270 Copier
D1120 IMAGE CLASS CONTINUOUS PAPER JAMS ALTHOUGH NO PAER ACTUALLY JAMMED. APPEARS THAT PAPPER IN PAPER TRAY IS NOT FEEDING OR CATCHING UP TO BE COPIED.
first of all try to clean trays picked up rollers and also look for a piece op paper or something else in internal paper path
pifonski
Feb 20, 2011 | Canon imageCLASS D1120 Copier
Hi, I have a "dead"
APP position error or Error Code 6A80
Condition: An error occurred in the APP motor.
Problems and Solutions:
  • Check for foreign material or paper debris around the purge drive system unit
    - remove foreign material.
  • Check for foreign material or paper debris around the ASF unit
  • If other solution fail, replace one off the following part
    - Purge drive system unit
    - Logic board
for more info visit: http://pcmediks.blogspot.com
Dec 28, 2010 | Canon Pixma MP450 All-In-One InkJet...
Error Code 540 on Canon ImageRunner 400s - Have non profit agency and this copier was donated to me. I plug it in and keep getting this error code when I attemp to runa copy - any help out there? Didn't...
E540 Cause : The shift tray home position sensor fails. Description : The home position detection signal does not turn on within 5 sec when making a shift tray home position search.
turn the copier off and disconnect the finisher plug and turn back on the code will go away. if you dont need the finisher take it off and use an exit tray.
Mar 22, 2010 | Canon Office Equipment & Supplies
Error message E 904 flashing alternately on screen
Cassette Feeding Module E904
  • The waste toner box swing cam home position sensor is faulty.
  • The cassette relay PCB is faulty.
  • May 29, 2009 | Canon C210 Copier
    Canon Copier Model C122F - error light flashing
    A common mistake is that people think that the waste toner needs to be emptied and instead the toner needs to be replaced --- and vice versa. Check to make sure that the toner bottle is not empty. Also, if you made copies that took ( used ) more toner then the machine was able to replenish, the machine has not had a chance to catch up. Place a white sheet of paper on the platen glass and make blank white copies. You may only be able to get 1-2 copies at first but as the device catches up with the toner replenish you should be able to make more. The blank copies you make -- do NOT put that paper right back into the machine. Lay it flat and let it cool, this will help prevent unwanted jamming due to heat build up in the paper. IF you have good amount of new toner in the machine, gently tap the front line ( or rear line) that feeds the used toner into the waste bottle. Sometimes the waste toner will clog and back up into the machine giving false 'waste toner full' message.
    Jan 04, 2009 | Canon Office Equipment & Supplies
    PC745 error code - what is it. Source for manual?
    that is the symbol for a paper jam. the figure 8 represents the rollers and the zig zag is the crumpled paper.
    Dec 27, 2008 | Canon PC-940 Black and White Copier
    Side Paper Deck Not Working
    first is the paper deck activate in service mode if not activate it, your feed , pickup and devilary rollers needs changing
    Oct 26, 2008 | Canon imageRUNNER C3200 Copier
    41 people viewed this question
    old marine
    old marine
