Question about Canon PowerShot SD880 IS Digital Camera
How to fix a canon powershot lens
The camera was dropped, The lens is supposed to go back in once the camera is shut off but it now does not, the lens appears to be slightly canted and jammed. Does anyone know I can fix it? any videos or manuals? I can take it apart but I don't really want to wing it. Thanks any help is appreciated!!
  • Canon Master
  • 4,738 Answers
Here are troubleshooting steps for a lens error. Since the camera was dropped, and the lens is canted, suggest proceeding directly to Fix 7. And here's a video summary of the steps.
Posted on Jan 23, 2013
  • 164 Answers
SOURCE: Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Posted on Jul 22, 2009
  • 3 Answers
SOURCE: Canon PowerShot SD870 IS camera - Lens Does Not Fully Retract
Canon SD870 IS. Lense Error. Would not retract on power-down. Lense error reported when retracting zoom.
Noticed the rectangular frame about the lens was rotated off center. Manually rotated (squared-up) the lens rectangle while repeatedly powering the camera on and off. Modulating the power allowed for easier rotation of the rectangular lens frame.
Once the lens frame was square with the body of the camera, the lens completely retracted on power-down, and also zoomed in/out without error.
Posted on Dec 23, 2009
  • 102366 Answers
SOURCE: Canon PowerShot A720 IS - "Lens error, restart camera".
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 14, 2010
t00nz
  • 4738 Answers
SOURCE: Canon Powershot A510 - lens covers stuck
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it. There are many non-invasive techniques that people have come up with to accomplish this. Some may be seen on this blog article. You can also open the lens barrel up to fix the covers, but only as a very last resort. The article also gives examples for this type of procedure.
Posted on Jun 06, 2010
Testimonial: "Hey thanks heaps! My favourite little camera is now working well again."
  • 85 Answers
SOURCE: Blank screen on Canon Powershot S2is camera
hi.if you are telling both viewfinder and lcd are blank or black the problem is in the shutter that you found inside of the lens are not open.sometimes the cuase of the is humidity or moist goin inside of the shutter thats why it will not work properly or stuck up.if you can open your camera and adjust the shuuter from lens unit its better .but if not its better you bring to service center and request for adjustment.
by the way try also to reset your camera to default setting maybe it will help you.
thank you
Posted on Jul 08, 2010
Testimonial: "Thank you so much for taking the time to help me, i will try your suggestions tonight, really appreciate your help, thanks again"
Lens wont go back in
The mechanical rectactors are probably worn out. Try turning it on and off again. If that doesn't work, try pushing gently the lens with your palm while shutting it off, maybe the rectractors need a bit of help or are just stuck and may fix themselves after you help them rectact the lens once.
Mar 05, 2014 | Canon PowerShot A580 Digital Camera
Hello, I have a Canon Powershot A2000IS. It was dropped whilst on and now once turning it on it beeps and says "Lens error. Restart camera". What can I do to fix this. Thankyou very much
If the camera fell down in most cases it is that the lens shifted slightly..The best solution is for this is to have it opened and fixed manually. Please try a Mechanic it you are not sure of the Camera Systems and Hardware.
Mar 17, 2011 | Canon Powershot A2000 IS Digital Camera
Canon Camera Error E32. Camera Error Camera will shut down automatically. Please restart your camera. Please help me. I am using Canon Powershot
The most common problems in these small tiny cameras is the lens alignment. If you drop the camera with the lens extended this alignment will ****. If you are a handyman you can fix it by yourself by oppening it inside and realign/putting the lens in right position. Sometimes you can do that by forcing them to extednd manualy but that is very risky. If not handyman I recomand you to take it to a repair shop.
Jan 27, 2011 | Canon PowerShot SD1400 IS IXUS 130...
My daughter dropped our A520. The power comes on for a second and then shuts down. The lens is stuck open. Is this worth fixing?
I had this problem once. The lens was stuck open and the power would not go on. I took out the storage card and the lens retracted.
Aug 23, 2010 | Canon PowerShot A520 Digital Camera
I dropped my Canon PowerShot SD750. the lens comes out half way
Sorry, but there is no DIY fix for the lens problem, and any attempts at homebrew repair will likely worsen the problem. The camera needs professional repair, so I suggest that you take it to a camera shop (not the camera department at a large store) or contact Canon customer service via the Canon.com web site. Be sure to get a firm price before committing to repairs -- the cost to fix it may be close to the price of a new camera, and repairs typically only carry a 30-day warranty.
Dec 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Describe hi, i have a canon powershot a520 that was left in someone's purse when she gave it back to me the lens is now sticking half way out and when i push the power button it blinks on for a split...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 22, 2009 | Canon PowerShot A520 Digital Camera
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon G9 dropped
I was told it happens when the battery is low
Aug 20, 2008 | Canon PowerShot G9 Digital Camera
Canon powershot A560
you need to get camera serviced-usually lens jumps off track or is crooked and gets jamed-did camera get dropped?if older model than 1 yr usually 100-125 to repair-if new model still in warranty they will tell you someone broke it and it's not covered-as a last resort if you are going to toss camera anyway put pressure on lens as you try to zoom in and out or put lens between teeth and try to force back in place
Aug 12, 2008 | Canon PowerShot A560 Digital Camera
Canon PowerShot SD880 IS Digital Camera Logo
154 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
