Question about General Electric WHDSR209DWW Top Load Washer
As washing machine cycles, the water never completely stops
Our pipesburst in the wall near the washing machine. Ever since this happened when we start a load of wash the water enters the tank and it goes through it's cycle but the water never really stops coming into the washer. So when it's time to drain and spin the washer never stops because there is always water.
It seems like a valve isn't closing all the way...maybe when the pipes burst it cracked a vlave or something?
  • 1heathermaxw Jan 27, 2009
    water never stops unless I turn it off.
    is there an online site that shows me the inside of my washer so I can find out how to get to the solenoid?
    i need to know 1) why is the water still running and 2) how do i fix it?
  • 565 Answers
The following link will show you the diagrams for your machine:
Here's the user manual:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90295-1.PDF
In particular see the last page (p.12)
The valve in question may be the automatic temperature control valve.
Posted on Jan 27, 2009
  • 1,031 Answers
Check to see if there are any kinks in the hose. Are the hot and cold water valves open fully? If you think the water fill valve is stuck open, disconnecting the power to either the solenoid or the appliance should prevent water from flowing through the valve. If this doesn't stop the water flow, the valve itself is probably bad and should be replaced.
There is a water level switch that controls the water fill valve by sensing how much water pressure there is in the wash tub. It's usually operated by water pressure in a tube with air in it. When the air in the tube compresses as the wash tub fills, the pressure gets read by this device. If the tube or diaphragm in this device has a slow leak, your washer may act oddly. An example would be that it fills and starts to agitate, fills more, goes back to agitate, and so on, leading to an overfill or overflow problem.
If the tube or diaphragm in the water level switch has a really bad leak, the water level switch won't detect any pressure whatsoever, and will not stop the water flow.
On occasion, the washer doesn't stop filling, and the water level falls or won't fill up. This can be caused by a household drain problem. If this drain system backs up, it can cause a back-siphon situation which can actually pull water out through the washer pump. To correct this, either rooter out the drain system (recommended), or install a drain valve called a Vacuum Break Valve in the drain line. This will relieve the vacuum, and will usually allow proper drainage of the system. Also, make sure the washer drain hose is not under the level of water in a utility sink during draining.
  • Starnley Johnwells
    Starnley Johnwells Jan 28, 2009
    check the water level switch that controls the valve and also valve if possible replace
    Brigadier General:
  • 8,619 Answers
Hi
This can be fixed by :
Tighten hoses at the faucets and turn the water off after to the fill hoses at the each use.
water source • Check condition of the fill hoses; they should be replaced every 5 years.
  • Rylee Smith
    Rylee Smith Jan 27, 2009
    Hi
    water source •
  • Rylee Smith
    Hi
    Insert free end of drain hose A into drain opening of your home. If water valves and drain are built into wall, fasten drain hose to one of water hoses with cable tie B provided (ribbed side on inside). If your drain is a standpipe, fasten drain hose A to standpipe with cable B provided.
    Note: If drain hose facility does not meet 30” minimum height requirement, thread drain hose through supplied antiphon clip C and mount to cabinet back as shown.
    Guru:
  • 859 Answers
Inside the machine near the drum is a float like device that shuts the water intake off when the float reaches the level set by your dials. That part probably cracked or was affected in some other way by the cold temperature as its never does go dry completely.
You can lift the lid off the washer. There are release pins in the front a flat head screwdriver can release. Life it up and look over the condition of the device that responds to water level. You should see the plumbing for this and follow it with a flashlight until you see the issue. Check for anything out of the ordinary in that area. This is likely an area that has failed since you had a hard freeze.
Worldvet
    President:
  • 1,990 Answers
Welcome to Fixya! He has no Clue. Open the Part of the Washer Where the Water line Goes into the Washer. There is an Inlet Valve. Where the Water comes in. Remove this Valve and Wiring, Make sure to Diagram how it comes off for Install. This is going to be your Problem. Please Rate my Response, I need all the Help That I can Get! Thanks!
    President:
  • 2,559 Answers
The solenoid is located right where the water line connect to the washer
  • Randy Hough
    Randy Hough Jan 28, 2009
    1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off an on a few times. This small jolt might unstick the water valve. If not, it will need replacing.
    2) There could be a problem with the water level switch.
    3) There is a pressure switch hose that is attached to an air dome. This switch tells the washer that there is water in the tub and allows the agitator to start.
    - Remove the control panel and you will notice a small hose. See if it popped off of the air dome. If it did, secure it with a zip tie.
    If water flow continues, but drains out immediately, then raise the drain hose above the highest water level line of the tub. Do not seal the drain hose to the discharge pipe. This could cause a siphoning action.
    President:
  • 1,214 Answers
Does water ever stop entering the washer? Or do you have to turn the water off to make it stop?
If you have to turn the water off, then it sounds like there may be a piece of trash in the solenoid valve in the washer. Either remove and see if you can clean out, or replace.
  • Mark Egan Jan 27, 2009
    Yes.
    I just looked at it on SearsPartsDirect.com. Water valve is on the other side of the panel where the water hoses screw into the washer.
    Turn water off.
    Disconnect hoses.
    Slide washer out.
    Get screwdriver/nut driver, remove panel.
    Remove valve assembly.
    Please don't forget to rate me on this. I hope I've given you enough information to honor me with a FixYa!
    And if you have any additional questions, please feel free to ask.
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    My Roper washer will run through wash cycle then stops. Nothing will work for 40 minutes then I can put it on rinse then the cycle will complete. What could cause the stopping with nothing working then...
    It could be that the machine is trying to heat the water in the drum, but is not able to for some reason. The timer is waiting for the water to reach temperature before advancing. Posssibly a broken heating element. This can happen even on a cold cycle as most machines prefer to heat all soaping water to about 30C regardless of the temperature setting.
    Sep 13, 2013 | Roper Washing Machines
    I have a Maytag Bravos top loader washer and it seems to agitate during the washing phase but when it comes to the spin cycle the water drains but the clothes are still soaked at the end of the cycle, as...
    This happens to me to. It is because it believes it has gone out of balance and has stopped and gone ahead and timed out making you think it has completed it's cycle. I do not have a solution to this other that I am thinking of chucking this washing machine out the door and buying an older machine.
    Nov 20, 2012 | Washing Machines
    Washer wont complete cycle
    Sound like the control board is bad
    Jul 25, 2012 | AEG Lavamat 72640 Front Load Washer
    I am washing clothes in a borrowed Kenmore washer. It's probably 10 years old. It stops short of completing the Rinse cycle and never makes it to the Spin cycle. The bowl will start filling up w/ water,...
    This is a typical problem with the "lid switch" on the washer. The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    Jan 26, 2011 | Kenmore Washing Machines
    Machine dot draining, not completing cycle.
    check pump filter may be blocked . Pump always got water in it even when empty put towels down and if possible lean machine back wards .and always remove plug from wall before doing any repairs .
    Feb 11, 2010 | Washing Machines
    Kenmore washing machine fills with water then stops
    turn the motor to see if it moves it sound like the motor
    May 02, 2009 | Kenmore 24032\24036 Top Load Washer
    Keeps flashing SE
    I recently had this happen but with no error message on my model, the rinse symbol just kept flashing and nothing was happening. I tried running a spin cycle or rinse and spin. The rinse & spin started but stopped when it got to spin. I finally determined that the water was not draining out. I ended up emptying a bucket and a half of water out of the emergency valve near the floor (which spills water everywhere) and found a lint ball that was plugging it. After this I tried running just a spin cycle and it worked.
    Mar 30, 2009 | Samsung Washing Machines
    F & P washing machine GW709AU not competing rinse cycle and then beeps and flashes light.
    My Whirlpool washing machine is not stopping after completion of wash cycle instead it is repeating the cycle again. It is not consistent, but out of 3 washes 1 wash is happening that way...we are manually stopping machine by gaurding carefully when timer shows nearer to completion.
    Sep 15, 2008 | Washing Machines
    Water leaking from wash machine
    It is probably a seal that is on or near the bottom of the tub. Dirt and grim wears at this seal over time. The leak is slow so it is hard to visually see.
    Dec 09, 2006 | Frigidaire MWS939Z Top Load Washer
    General Electric WHDSR209DWW Top Load Washer Logo
    887 people viewed this question
    Top General Electric Washing Machines Experts
    Dan Webster
    Dan Webster
    Paul Bade
    Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
