Hotpoint WMF 720 programme selector dial turns but no longer selects different programmes.
SOURCE: programme dial again
yes thats your problem,the reason it wont unscrew is because of things caught inside ie coins gunk you will have to take out machine turn on side,there are two sometime four screws at front of machine where black dail is remove these,when machine is on its side you can acess pump from underneath,there is a black rubber hose which goes from drum to pump which is held on with a circlip remove this at pump end you will need a vicegrip,remove all gunk coins ect, refit all back to machine ,,problem solved......the reason dail was turning was because it was looking for progam to release water which it couldnt because of blockage,after tou unblock you will find that black srew on cover on front can be removed(always better to check for blockages every few weeks hopes this helps
Posted on May 23, 2008
SOURCE: Programme Selector knob keeps turning. - Airston Margherita AB95
turn knob to solid dot then leave it for a little while to reset then turn it onto the desired cycle
Posted on Jun 20, 2008
  • 193 Answers
SOURCE: h20 error on hotpoint
Lift the lid and check that clear hose is connected to the pressure switch.
Posted on Nov 02, 2009
SOURCE: Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Posted on Jan 03, 2010
  • 160 Answers
SOURCE: Hotpoint washing machine model WF620, keeps
depending on which version you have to
Press the 'Start / Cancel' button until ALL the console LEDs illuminate.
then either
1.Press both 'Start / Cancel' and 'On / Off' buttons together until 'd OFF' appears.
or
2. Press 'On / Off' and 'Start / Cancel' together with the top left option button (Spin) until 'd oFF' appears.
Posted on Mar 21, 2010
Hotpoint 720 part fills but goes no further and no faults show
Hotpoint 720 incorporates a fill pressure switch, it monitors the fill level and passes instructions that sufficient water level has been reached, and instructs the programmer to continue to the next stage of the cycle.
Accepting, that enough water has entered the drum, the level switch could be faulty, however it is most likely to be the programmer.
To test any of the fault finding to cure this fault requires removing panels and I would not recommend you doing this unless you are qualified.
If you are however qualified and satisfied that you can proceed safely, with concerns for your own safety, I will send you, a process on how to proceed, checking out weather it is the pressure switch or the programmer.
Trust you find this answer helpful
Adam
Jan 14, 2018 | Hotpoint Washing Machines
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Err code displayed and fails start
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
Hotpoint 7kg aquarius + WMF 720 model.
Can you please advise how you fixed this problem as I have the same one!
Jan 29, 2012 | Washing Machines
I have a Hotpoint BWd129 washer/dryer. When I
I have a similar Hotpoint model to this, that does something very similar now and again, usually when trying to set a delayed start.
The only way I have found to "fix" it is to turn the machine off for at least 5 minutes, and then try again.
Hope this helps.
Jan 13, 2010 | Zanussi WJD1257W Front Load Washer
Dial won't move automatically
The dial is not a timer that moves through the prog, it is a selector switch, which selects the programme you require, and therefore does not move round
You need to check the filter re the spin prob.
Remove rear panel, remove large black hose from bottom of tub, remove filter, and clean.
Refit filter and hose.
Test for leaks
Plz rate my solution.
Thanks
Jan 11, 2009 | Hotpoint First Edition WMA20 Front Load...
Programme not going through cycle
Hi does the machine fill with water? If the machine programme dial does not move then it is more than likely to be the heat cycle that needs looking at!
If you are local to me then we can arrange a visit to repair.
Good luck.............................
Dec 28, 2008 | Hotpoint WMA54 Front Load Washer
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
