Question about Crosley Cr1701a Ijuke Juke Box Ipod Dock
Juke Box. My sound leisure mini jook selects a disc from the stack, puts it on to the disc turntable, but does not spin. After about 5 seconds, it retrieves the disc and places it back in the stack. The motor has been checked and is ok, and everything else seems ok. This fault happened out of the blue, and the system has been trouble free for the 2 years i have owned it. Any help or ideas as to what this problem may be would be much appreciated. Thank you.
3 Suggested Answers
SOURCE: everything works on my record player but my turntable doesnt spin
This happened to me tonight. I had the same problem, to activate the player on you need to move it to the right until you hear a click. If you don't do it it won't start. Even if all the power is on. This should fix everything!
Posted on Oct 12, 2009
Grubhead
  • 5449 Answers
SOURCE: Turntable has stopped working, possible belt stretch
I don't think it's likely that the motor is in trouble just by having the belt wrong. It would require more physical damage to cause the motor to play up. Having said that the motor could have been in trouble before you touched the belt. But you do need a new belt, all you need to do is measure the diameter of the belt in mm. You might also need to measure the width. To find a new belt put the words "turntable drive belt XXmm" into Google. You can add Crosley to the start, but many belts are universal. Your measurements don't need to be spot on with the diameter, so if you have measured it at say 95mm, a 90mm to 100mm belt will do the job. However fitting the new belt is a different matter. You need to know the correct way, or the speed might be wrong. I can't help you with the fitting of it, so you will need to check how to do it. Some makes have YouTube videos of the fitting. I would just look for Crosley and see if any look like your model.
If fitted correctly and there's a problem with speed still, then you should look more closely at the motor.
Posted on Mar 26, 2014
What causes an amplified ramble sound on a worlisterzer 1970s juke box when selecting a record while the music is playing?
Usually the rubber grommets under the turntable have gone hard with age so there is more noise from the motor
May 17, 2014 | Audio Players & Recorders
Hi. I have a Crosley CR40 mini turntable. When I turn on the power, the vinyl spins but when the needle is placed on the vinyl, the vinyl doesnt move anymore while the spinner underneath it is still...
It sounds like you have too much pressure on the tone arm. Check the underside for springs. You might be able to remedy the problem the old fashioned way. Tape a coin onto the top of the tone arm, as far to the rear as possible. This will eliminate some of the downward pressure onto the record.
May 07, 2011 | Crosley Stack-O-Matic CR40 Turntable
Wurlitzer juke box "Rave ON"
IF U REQUIRE THE SERVICE PROGRAMME EMAIL ME I HAVE IT ON DVD DISC philhemmings@hotmail.com
Jun 22, 2009 | Wurlitzer Jukebox 1015 One More Time...
NSM Hyperbeam Wall mount Juke box
if you get error 61 it means check cd and exchange,or cd changer or at the most it could be the decoder board you could try jukeboxworld good site for manuals etc
Jun 03, 2009 | Wurlitzer Jukebox CD Player
Juke box (seeburg 480 serieswill take coins but won't play record
YOU ARE SAYING THE MOTOR DOES NOT SPIN. TRY TO SPIN THE DRIVE SHAFT ON TOP OF MOTOR . DOES THE SHAFT TURN EASY. IF NO THEN YOU HAVE A MOTOR OR LUBRICATION.
PROBLEM.
DOES THE SCAN SWITCH, WHEN PUSHED TO SCAN DOES IT SCAN. IF IT SCANS BACK, AND FORTH 2 TIMES, YOU THEN HAVE A COIN CREDIT PROBLEM (MOST LIKELY )
ANSWER THE TWO QUESTION, OR STATEMENT. TO GET A MORE INTELLIGENT REPLY.
YOU HAVE OVER 2000 PARTS IN THAT MACHINE. YOU HAVE GIVEN A (WHY DONT IT WORK
QUESTION.)( there is no answer to the question. because of limited problem info)
DOCTOR FIX
IN-HOME JUKEBOX REPAIR
6362273300
May 09, 2009 | Audio Players & Recorders
Wurlitzer follow up question.........
Ok a few things it could be.
Firstly as it is spinning it could be simply be that the optical assembly is wrongly adjusted or even dirty.
The other least likely scenario is a progamming error - did you do any programming to the jukebox when you received it for things like how many cds it is holding and free play etc?
The reason I favour the first scenario is because I had exactly the same problem (although mine was not even spinning). The two things I did were to toggle the service switch on the S&CC board then switch the power on and off then give the magnetic clamp above the turntable a bit of a tap and voila it started working again! Not exactly scientific I know.
BTW do you have the manual - if not then here is the link for it to help you further.
http://www.flippers.com/pdfs/OMT_CD_Operating&FieldService_22.pdf
This will also help you do any functional tests (chapter 13) to help you get to the bottom of the problem.
Mar 17, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 OMT Disc spins, then stops....
When the disc is taken from the carousel and put on the player how long does it take for it from the time it is placed onto the player to being returned to the carousel? Also is the cd spinning when its on the player or not spinning at all. The answers to these questions should help in pinpointing the actual problem.
Mar 16, 2008 | Wurlitzer Jukebox 1015 One More Time...
Jukebox
Plug your MOSMP036 into your USB port on your computer. Find it in "Device Manager". Double click on it then go to "Driver". Click on "Update Driver", then on "Next" then "Next" again and again to search for suitable driver. DO NOT INSTALL the driver it says is nearest match but click on the "Install one of the other drivers box and click "Next". Select the driver for USB mass storage device and click next. You will now be able to find your MP3 player's disc in Widows Explorer where you can create folders and copy and move files at will. Just remember when you have finished to go into MOS Jukebox, click on Sync the on File and then on Exit, otherwise your player menu will not display your songs as you have installed them. Iuse my MOSMP036 to back up my important computer files!
Aug 09, 2007 | Ministry Of Sound MOSMP036 MP3 Player
Crosley Cr1701a Ijuke Juke Box Ipod Dock Logo
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
