Question about Nikon D80 Digital Camera
D80 will not turn on...battery fully charged
Our D80 suddenly without error warning or anything stopped turning on. The battery is ok, and has been used in another camer. Another battery installed has same effect. We can not figure it out is there a reset button somewhere we could have hit?
    Novelist:
  • Nikon Expert
  • 357 Answers
Do you get any numerals in the TOP LCD? Say a flashing ERR?
Or just no power and nothing works?
Posted on Jan 25, 2013
jackboy
  • 2985 Answers
SOURCE: My camer won't turn on!!
Wet ingression - turning on killed it. This is not going to get repaired. Put in a warm dry place for a couple of days with the batteries and card out. But don't put your hopes too high.
Posted on Aug 30, 2007
SOURCE: D80 shutter is stuck
Followed the mirror lock procedure as outlined in the manual for cleaning the sensor. That solved the problem.
Posted on Nov 13, 2008
SOURCE: Nikon D40 will not take a picture.
I fixed it!! Turn the lens to Manual mode (moving to M). Twist the very tip of the lens till it unlocks.
If you twist the lens on the end far enough on the end to the right you will find it "locks". This is what is causing the screeching sound,, it's locked and can't auto focus. Twist the very end to the left till it releases. This fixed it for me.
Posted on Nov 27, 2008
  • 19 Answers
SOURCE: Error message on my Nikon D80
I have the same message r07 on the same camera & lens combination. It is an lens error message that the lense will not focus. You can manually focus the lens in the auto mode and the camera will allow you to take a picture. I have been told it is the MR unit and cost of repair around $135.
Posted on Jun 01, 2010
LongPockets
  • 1177 Answers
SOURCE: I have a nikon coolpix
I think you should return it under warranty.
Posted on Nov 21, 2010
I would contact Nikon tech support at www.nikon.com. They may be able to give you some suggestions. It appears from what you said that the camera is not seeing the battery and that may indicate that your contacts in the battery compartment are dirty and need cleaning.
Jan 22, 2013 | Nikon D80 Digital Camera
My compaq presario v3500 wont turn on again. i was using it, watching movie then it suddenly shutdown. my battery is fully charge and the charger was connected. so i try to turn it on and it wont start....
Remove the Battery and press power on for 1-2 minutes with out AC power .
Please turn on the laptop with only AC POWER (without battery ). Check it. it may turn on your laptop.
If display ok, then insert battery and use it...
Jun 18, 2011 | HP Compaq Presario 2200 Notebook
Camera suddenly stopped working--an error message flashed, then camera shut off-put new battery in--nothing happens. (kodak c360)
Usually when the camera shows an error mgs. it needs a repair
However Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 23, 2009 | Kodak EasyShare C360 Digital Camera
When I load fully charged batteries it comes up with the 'battery low' warning and sometimes 'zoom error'
Believe it or not, the batteries are not fully charged.
1. Use alkyline batteries to test if camera is ok.
2. Carry a spare set of alkyline batteries
3. Don't mix battery types or mA sizes
Sep 01, 2009 | Olympus SP-310 Digital Camera
Error Message with Nilon D80
Have you been to the Nikon website to check for firmware updates?
Aug 27, 2009 | Nikon D80 Digital Camera with 18-135mm...
Won't turn on
look for reset near the battery compartment. should need a paper clip to push.
Jun 02, 2009 | Cameras
Nikon D80
Your question is not much clear. When the camera shut off?? eg, after pressing shutter, etc. Did you use original battery?? What is your camera age?
PROBABILITY :
Your camera might be have on/off button problem.
EXPLANATION :
I had experience this with my coolpix 8xxx (could not remember exact model). The problem is with nikon on/off switch and shutter design. After a few years of usage, then the on/off switch with start losen a bit. These will cause autofocus activated without you pressing the shutter yet, and it will shut off without warning.
SOLUTION.
There is no DIY solution for this problem. For temporary, try your luck with pressing the on/off swith a bit harder. But that is for temporary + a bit of luck. Best solution is to send the camera to Nikon Centre.
Oct 24, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
