Question about Microsoft Corporation Xbox 360 Live Marketplace 1600 Points - Minecraft: Xbox 360 Edition for Xbox 360
In minecarft what does this mean: hs_err_pid#
Please note this is for computer not xbox, they didnt have the computer one for the products..... This is what the document said: # # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_PRIV_INSTRUCTION (0xc0000096) at pc=0x4ab1a98c, pid=8056, tid=6068 # # JRE version: 6.0_27-b07 # Java VM: Java HotSpot(TM) Client VM (20.2-b06 mixed mode windows-x86 ) # Problematic frame: # C [tsvxiesl.dll+0xa98c] # # If you would like to submit a bug report, please visit: # http://java.sun.com/webapps/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # --------------- T H R E A D --------------- Current thread (0x4a57e400): JavaThread "AWT-Windows" daemon [_thread_in_native, id=6068, stack(0x4a950000,0x4a9a0000)] siginfo: ExceptionCode=0xc0000096 Registers: EAX=0x00160570, EBX=0x4a99f36c, ECX=0x00050001, EDX=0x4a99f3f4 ESP=0x4a99f310, EBP=0x4a99f340, ESI=0x00050003, EDI=0x00000003 EIP=0x4ab1a98c, EFLAGS=0x00010246 Top of Stack: (sp=0x4a99f310) 0x4a99f310: 761d2336 00000003 000804a8 4a99f36c 0x4a99f320: 4a99f3b0 4a99f38c 00000000 7ffaf6cc 0x4a99f330: 00050000 00000000 00000003 00000000 0x4a99f340: 4a99f374 761c9ac6 00050003 000804a8 0x4a99f350: 4a99f36c 4ab1a98c 00050000 7ffaf6cc 0x4a99f360: 00000000 00000034 4a99f3b0 4a99f3b0 0x4a99f370: 00000000 4a99f460 778f5c0e 4a99f38c 0x4a99f380: 000000b0 4a99f700 778f5bc0 000000b0 Instructions: (pc=0x4ab1a98c) 0x4ab1a96c: 38 61 b2 6c 00 81 26 00 3d 00 e5 fe 0e 00 0a b0 0x4ab1a97c: 00 46 e5 97 50 00 37 00 04 86 d1 16 24 61 00 c7 0x4ab1a98c: e6 6b e2 a5 44 a6 00 e4 20 00 5c 7a 00 9b 68 00 0x4ab1a99c: 4b 00 69 4d 00 e3 61 23 9a 4c 00 4f 00 d4 49 00 Register to memory mapping: EAX=0x00160570 is an unknown value EBX=0x4a99f36c is pointing into the stack for thread: 0x4a57e400 ECX=0x00050001 is an unknown value EDX=0x4a99f3f4 is pointing into the stack for thread: 0x4a57e400 ESP=0x4a99f310 is pointing into the stack for thread: 0x4a57e400 EBP=0x4a99f340 is pointing into the stack for thread: 0x4a57e400 ESI=0x00050003 is an unknown value EDI=0x00000003 is an unknown value Stack: [0x4a950000,0x4a9a0000], sp=0x4a99f310, free space=316k Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code) C [tsvxiesl.dll+0xa98c] NVCoInstaller+0x2b1c C [USER32.dll+0x29ac6] CreateDialogIndirectParamW+0x64 C [ntdll.dll+0x65c0e] KiUserCallbackDispatcher+0x2e C [ASOEHOOK.DLL+0x2a5a] DllMain+0xe07 C [USER32.dll+0x8e2d] IsCharAlphaNumericW+0x5ca C [USER32.dll+0x2c538] OpenClipboard+0x21b C [ntdll.dll+0x65c0e] KiUserCallbackDispatcher+0x2e C [USER32.dll+0x112d5] CharNextW+0x42e C [USER32.dll+0x11338] CreateWindowExW+0x33 Java frames: (J=compiled Java code, j=interpreted, Vv=VM code) j sun.awt.windows.WToolkit.init()Z+0 j sun.awt.windows.WToolkit.run()V+9 j java.lang.Thread.run()V+11 v ~StubRoutines::call_stub --------------- P R O C E S S --------------- Java Threads: ( => current thread ) =>0x4a57e400 JavaThread "AWT-Windows" daemon [_thread_in_native, id=6068, stack(0x4a950000,0x4a9a0000)] 0x4a57dc00 JavaThread "AWT-Shutdown" [_thread_blocked, id=6412, stack(0x4a900000,0x4a950000)] 0x4a57d400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=4360, stack(0x4a860000,0x4a8b0000)] 0x01b04000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=7852, stack(0x4a460000,0x4a4b0000)] 0x01afec00 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=6604, stack(0x4a410000,0x4a460000)] 0x01af9c00 JavaThread "Attach Listener" daemon [_thread_blocked, id=7244, stack(0x02360000,0x023b0000)] 0x01af8c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=7204, stack(0x01b90000,0x01be0000)] 0x01acec00 JavaThread "Finalizer" daemon [_thread_blocked, id=6968, stack(0x01b40000,0x01b90000)] 0x01aca400 JavaThread "Reference Handler" daemon [_thread_blocked, id=5736, stack(0x01660000,0x016b0000)] 0x023d9800 JavaThread "main" [_thread_blocked, id=6304, stack(0x002d0000,0x00320000)] Other Threads: 0x01ac6400 VMThread [stack: 0x003a0000,0x003f0000] [id=7316] 0x01b15c00 WatcherThread [stack: 0x4a4b0000,0x4a500000] [id=528] VM state:not at safepoint (normal execution) VM Mutex/Monitor currently owned by a thread: None Heap def new generation total 157248K, used 5591K [0x043e0000, 0x0ee80000, 0x19930000) eden space 139776K, 4% used [0x043e0000, 0x04955c58, 0x0cc60000) from space 17472K, 0% used [0x0cc60000, 0x0cc60000, 0x0dd70000) to space 17472K, 0% used [0x0dd70000, 0x0dd70000, 0x0ee80000) tenured generation total 349568K, used 0K [0x19930000, 0x2ee90000, 0x443e0000) the space 349568K, 0% used [0x19930000, 0x19930000, 0x19930200, 0x2ee90000) compacting perm gen total 12288K, used 4245K [0x443e0000, 0x44fe0000, 0x483e0000) the space 12288K, 34% used [0x443e0000, 0x448055a0, 0x44805600, 0x44fe0000) No shared spaces configured. Code Cache [0x023e0000, 0x02468000, 0x043e0000) total_blobs=197 nmethods=41 adapters=93 free_code_cache=33019072 largest_free_block=0 Dynamic libraries: 0x00400000 - 0x00424000 C:\Program Files\Java\jre6\bin\javaw.exe 0x77890000 - 0x779b8000 C:\Windows\system32\ntdll.dll 0x767e0000 - 0x768bc000 C:\Windows\system32\kernel32.dll 0x76360000 - 0x76426000 C:\Windows\system32\ADVAPI32.dll 0x776a0000 - 0x77763000 C:\Windows\system32\RPCRT4.dll 0x761a0000 - 0x7623d000 C:\Windows\system32\USER32.dll 0x76790000 - 0x767db000 C:\Windows\system32\GDI32.dll 0x77680000 - 0x7769e000 C:\Windows\system32\IMM32.DLL 0x774b0000 - 0x77578000 C:\Windows\system32\MSCTF.dll 0x77580000 - 0x7762a000 C:\Windows\system32\msvcrt.dll 0x77ae0000 - 0x77ae9000 C:\Windows\system32\LPK.DLL 0x76430000 - 0x764ad000 C:\Windows\system32\USP10.dll 0x7c340000 - 0x7c396000 C:\Program Files\Java\jre6\bin\msvcr71.dll 0x6d7f0000 - 0x6da9f000 C:\Program Files\Java\jre6\bin\client\jvm.dll 0x74bf0000 - 0x74c22000 C:\Windows\system32\WINMM.dll 0x76640000 - 0x76785000 C:\Windows\system32\ole32.dll 0x77a50000 - 0x77add000 C:\Windows\system32\OLEAUT32.dll 0x74bb0000 - 0x74bee000 C:\Windows\system32\OLEACC.dll 0x75d80000 - 0x75dac000 C:\Windows\system32\apphelp.dll 0x6d7a0000 - 0x6d7ac000 C:\Program Files\Java\jre6\bin\verify.dll 0x6d320000 - 0x6d33f000 C:\Program Files\Java\jre6\bin\java.dll 0x6d7e0000 - 0x6d7ef000 C:\Program Files\Java\jre6\bin\zip.dll 0x6d000000 - 0x6d14c000 C:\Program Files\Java\jre6\bin\awt.dll 0x70c70000 - 0x70cb2000 C:\Windows\system32\WINSPOOL.DRV 0x74d30000 - 0x74ece000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_none_5cb72f2a088b0ed3\COMCTL32.dll 0x75f50000 - 0x75fa9000 C:\Windows\system32\SHLWAPI.dll 0x718c0000 - 0x718cc000 C:\Windows\system32\DWMAPI.DLL 0x74cf0000 - 0x74d2f000 C:\Windows\system32\uxtheme.dll 0x60c40000 - 0x60ca9000 C:\PROGRAM FILES\NORTON 360 PREMIER EDITION\ENGINE\4.4.0.12\ASOEHOOK.DLL 0x6f960000 - 0x6fa03000 C:\PROGRAM FILES\NORTON 360 PREMIER EDITION\ENGINE\4.4.0.12\Microsoft.VC90.CRT\MSVCR90.dll 0x6fba0000 - 0x6fc2e000 C:\PROGRAM FILES\NORTON 360 PREMIER EDITION\ENGINE\4.4.0.12\Microsoft.VC90.CRT\MSVCP90.dll 0x4ab10000 - 0x4ab7a000 C:\Users\Carroll\AppData\Local\Apple Computer\Akamai\tsvxiesl.dll 0x764b0000 - 0x7663a000 C:\Windows\system32\SETUPAPI.dll 0x6ce40000 - 0x6ce43000 C:\Windows\system32\LZ32.dll 0x75230000 - 0x75238000 C:\Windows\system32\VERSION.dll 0x76910000 - 0x77421000 C:\Windows\system32\SHELL32.dll 0x75f40000 - 0x75f47000 C:\Windows\system32\PSAPI.DLL VM Arguments: jvm_args: -Xms512m -Xmx1024m java_command: C:\Users\Carroll\Desktop\Thomas\Minecraft.exe Launcher Type: SUN_STANDARD Environment Variables: PATH=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Program Files\Common Files\Ulead Systems\MPEG;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\HP\Digital Imaging\bin;C:\Program Files\HP\Digital Imaging\bin\;C:\Program Files\HP\Digital Imaging\bin\Qt\Qt 4.3.3;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\IVI Foundation\VISA\WinNT\Bin;C:\Program Files\Java\jre6\bin USERNAME=Carroll OS=Windows_NT PROCESSOR_IDENTIFIER=x86 Family 6 Model 23 Stepping 10, GenuineIntel --------------- S Y S T E M --------------- OS: Windows Vista Build 6002 Service Pack 2 CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 23 stepping 10, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1 Memory: 4k page, physical 3009780k(1532576k free), swap 6236936k(4012092k free) vm_info: Java HotSpot(TM) Client VM (20.2-b06) for windows-x86 JRE (1.6.0_27-b07), built on Jul 19 2011 01:04:42 by "java_re" with MS VC++ 7.1 (VS2003) time: Tue Jan 22 17:20:35 2013 elapsed time: 0 seconds
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 20 Answers
This error could be related to two things, a corrupt java installation or an issue with the graphics driver.
Try first to reinstall the java engine first, if that fails try to reinstall the graphics driver.
Chances are it is a Java issue.
Good luck.
Posted on Mar 02, 2013
How can I get 6 hs-err-pid13944-Notepas deleted please?
Try going into Control Panel and find Programs and Features. See if it is listed and uninstall it.
May 24, 2014 | Computers & Internet
Minecarft
Can you be more specific about your problem?
Nov 08, 2013 | Suck Uk Toys
I need an install disk
Hello i hope you mean the mainboard drivers:
http://www.gigabyte.com/products/product-page.aspx?pid=3499#dl
Version 1,3:
http://www.gigabyte.com/products/product-page.aspx?pid=3483#dl
Select first your windows.
Next the type of driver you need.
And click on the download link.
The files maybe needs to be unziped
before you install it.
Good luck
Nov 18, 2012 | Computers & Internet
Gigabyte model ep43-ud3l install disk download
Version 1,3:
The files maybe needs to be unziped before you install it.
Good luck
How do i get the real activation link for my xbox 360
Please check on the link below and register your product and you can find all help :
http://support.xbox.com/en-GB/?xr=shellnav
Dec 30, 2011 | Microsoft Xbox 360 Console
Need owners manual for A ctm hs 740 mobility scooter.
go onto ctm homecare website and into rescource centre then dowloads and click on 740, regards, Bill.
Jun 14, 2011 | Ctm HS 890 4 Wheel Heavy Duty Power...
Gigabyte GA-8I945GZME drivers needed , pls help me
Go to this website
http://www.gigabyte.com/products/product-page.aspx?pid=2304&dl=1#dl
Download type = Driver
Choose your operating system = The operating system you have
Near the bottom you will see a blue hyper-link for a program that will automatically scan your computer for other drivers you could use.
Be sure to read all of the "notes" in red at the bottom of the screen.
Hope this helps!
Dec 16, 2010 | Gigabyte GA-8I945GZME-RH Motherboard
I want dimensions of speakers &woofer of model hcs200 but i didnt find on any site of JBL &specs for speakers set & avr134. the entire model no is HCS200.5...
http://www.harmankardon.com/EN-GB/Products/Pages/ProductDetails.aspx?PID=HS%20200/230&accT=1&tsT=0&ovT=0
If this link does not work just look up harmankardon.com where you are
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | JBL 5.1-Channel Home Theater Speaker...
Microsoft Corporation Xbox 360 Live Marketplace 1600 Points - Minecraft: Xbox 360 Edition for Xbox 360 Logo
339 people viewed this question
Top Microsoft Corporation Video Game Consoles & Games Experts
James Wishart
Are you a Microsoft Corporation Video Game Console and Game Expert? Answer questions, earn points and help others
