Question about Chicago Faucets 733-OHCP Urinal Valve....
How to adjust a chicago urinal flush valve push button style
Hard to push in ,not long enough cycle . if a young adult was to use the button they would not be able to hold it down to flush it
2 Suggested Answers
  • 127 Answers
SOURCE: water run on in chicago 732 urinal valve
valve is sticking inside....need to get repair parts or replace valve.
Posted on Oct 18, 2009
Put new valve in the urinal, flushes fine, but loud groaning noise in the wall after every flush, didn't happen until new valve put in. What can I do?
air chamber shock absorber ,wrong pressure take cap off adjusting screw and adjust.it the big silver cap on top just screws off.
May 26, 2015 | Sloan 180-1 Exposed Urinal Flushometer -...
Roca dual push button Toilet will only flush when holding the push button continuously down until the cistern is empty. It won't completely flush like it should when pressing the button once.
allow tank to fill a little more by adjusting fill valve. When there's not enough water flowing from tank the stopper can over-power the water flow and cause the flush to stop by re-sealing.
Feb 28, 2015 | Home
How do I increase the water pressure when flushing a wall-mounted urinal?
I don't know witch valve you're working with but most volume control adjustments are located under a screw off cap on the front of the valve. Remove that cap and there will be a small slotted screw that when you turn in it reduces the flush time and out increases it.
Feb 08, 2011 | Eljer 161-1190-00 White Bedfordshire Wall...
Have a urinal flush valve which has insufficient water discharge. Unit is supposed to dispense 1 gallon, but I would estimate only about a half liter flush. Any suggestions?
The guts have worn and the hadle does not push the internal plunger far enough. Check your local plumbing supply house for a rebuild kit. The kit can be installed in a couple of minutes.
heatman101
Aug 20, 2010 | Sloan 3010100 110 Water Saver 3.5
Push valve for urinal adjustment. How do we
HI im Rossouw
Most sisterns with 2 buttons 1 for urin 2 for bouls have have a button on top of the sistern
Remove the lid of the sistern by thast lifting it or unscrew the head of the bottem
After the lid is of iets easy, wear the arms are of the indevidual bottons u mist thast find the 1 u want to be urin and turn it right for less water and left for more water
Plz rate mt advice thanx
Jul 12, 2010 | Mansfield Plumbing Products Mansfield...
The flush valve does stay open long enough after flushing
Which style of flush valve do you have? If it is the dual-flush option (solids/liquids) I do not know how to adjust those. If you have a traditional style, then the flapper or ball is closing too soon. You need to adjust the guide arm (flush ball) higher or shorten the chain between the flapper and the handle. Adjust this carefully or you will have it fail to seat and the toilet will constantly run.
I hope this helps.
(who needed to replace the fill valve and the flapper at her home earlier this week)
Feb 19, 2010 | Kohler - Toilet - Two-piece - Highline -...
I have a Sloan urinal that will not stop flushing. I have rebuilt it with a total rebuild kit. I cleaned the inside of all surfaces and I flushed the entire piping system to no avail. It will not stop...
The rubber vacuum relief needs to also be changed if you have not. It is located in the tube that runs down to the urinal from under the flush valve. The handle could be hanging up.....or there could still be sediment stopping the diaphragm from working properly.
Nov 21, 2009 | NRS 180-1.5 Sloan Exposed Urinal...
I need a blue print on how a sloan urinal flush valve works and how the water flowes through it. if posable exactly how it works.
SLOAN FLUSH VALVES ARE SIMPLE. IT DEPENDES ON THE PROBLEM. IF THE VALVE KEPS RUNNING AFTER IT IS FLUSHED THE RUBBER DIAPHRAM IS DIRTY OR OLD AND THE RUBBER DIAPHRAM IS GETTING HARD. AND STICKING. THE VALVE WORKS ON A VACUME TO CLOSE THE DIAPHRAM TO STOP THE FLUSH PROCESS. WHEN YOU PULL ON THE FLUSH HANDLE YOU BREAK THE VACUME THAT FORM ON THE TOP OF THE DIAPHRAM WHICH ALLOWS THE WATER TO FLOW AS THE WATER FLOWS IT IS ALSO STARTING TO PULL A VACUME IN THE TOP OF THE DIAPHRAM TO CLOSE THE DIAPHRAM AND STOP THE FLUSH.
AS THE DIAPHRAM GET OLD AND WORN IT GETS HARD AND DOES NOT MOVE AS FREELY AND STICKS OPEN AND WON'T LET THE VACUME CLOSE THE DIAPHRAM AND THE URINAL WILL CONTINUE TO FLUSH. HOPE THIS ANSWERED YOU QUESTION
Oct 01, 2009 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Water run on in chicago 732 urinal valve
Sep 29, 2009 | Chicago Faucets 733-OHCP Urinal Valve....
My V and B toilet suddenly stopped flushing today, what's the problem?
It won't drain? Is the tank draining? Is the water turned off? Or is it just plugged up?
Jun 19, 2009 | Villeroy & Boch 6610 11 Subway...
Chicago Faucets 733-OHCP Urinal Valve.... Logo
178 people viewed this question
Top Chicago Faucets Plumbing Experts
Donni Steen
Tom Chichester
Are you a Chicago Faucets Plumbing Expert? Answer questions, earn points and help others
