Question about Fisher Paykel ActiveSmart Fridge - French Door 36
Fisher paykel fridge e381t water leaking from inside
Water leaks from under the freezer and runs down the back and onto the floor when the door is opened.fridge and freezer run at correct temp.seals good,even floor.fridge stands alone so good air circulation.would like to see if drain tube is blocked at the and the method of removing the interior back panels. thanks
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Water leaking bottom of crisper.
You may just have to manually defrost it.
Dec 16, 2014 | Fisher Refrigerators
Fridge working perfectly... water leaks onto floor over night seems to be from underneath..
I would check that the water catch tray is on the compressor, this item collects the water from a defrost, it may be missing.
Dec 04, 2011 | Fisher and Paykel RF201ADUX Bottom Freezer...
Water leaking from inside the fridge
Clear ice build up from drain plug using hot water in a syringe. Works well I just did mine. Located behind access panel inside fridge. Blue tube running down the back. Pull down and remove ice from the drain at the top.
Jun 22, 2010 | Refrigerators
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
Fridge Leak
We fixed the leak by putting a pipe cleaner down the hole inside the fridge, at the back. This cleared the tube as it had gunk and grime blocking it. Now the water can run freely down the tube and into the drip tray which is at the back of the fridge above the motor.
Jun 12, 2009 | Fisher Refrigerators
Water leaking from freezer into fridge
there are several things to check for. The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchangertubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
click this link for more help  http://www.applianceaid.com/refrigerator.html
Mar 31, 2009 | Kenmore Refrigerators
Water leaking
Hi
There are several things to check for: The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Please revert for any clarification.
A Fixya rating would be appreciated if you found this to be helpful.
Thanks
Rylee
Feb 16, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Fisher and Paykel fridge buttom freezer with water dispenser
Please advise where the dispenser is leaking? If it is dripping out the front of the door, then I suggest you run the water dispenser to flush about 3 liters of water. Does the noise stop when you open the fridge door?
Jul 01, 2008 | Fisher and Paykel Active SmartĀ® E522BR...
Fisher Paykel ActiveSmart Fridge - French Door 36 Logo
95 people viewed this question
Top Fisher Paykel Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Fisher Paykel Refrigerator Expert? Answer questions, earn points and help others
