Question about Brother ML-300 Typewriter
My e and o are not fully printing unless I go over it 2 times.
My ribbon still shows quite a bit through the window on the ribbon case.
  • Brother Master
  • 3,594 Answers
If nit is only these letters I would try a new printwheel
DickyO
Posted on Feb 04, 2013
Evolis Pebble 3 cannot set ribbon type to other than black k - Expert assistance required
Make sure the primary ribbon setting in the driver is on the appropriate setting (graphics tab when accessing via Windows' "Printing preferences". Also, when checking/changing this setting via Windows, be sure your logon ID has Windows Admin rights - standard users are blocked from making driver adjustments.
The only other things I can think of, and that we've seen, is that the main logic board on these printers can begin to exhibit erratic behavior with age. The Pebble3 is a VERY old printer, and is fully out of support now by the manufacturer. If it's a failing/failed logic board, it may be time to consider a replacement.
May 22, 2017 | Evolis Pebble Office Equipment & Supplies
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
Needs to be restarted after every print command
You can always try a tailor made driver for free at www.nicelabel.cl ( you will need to enter your data), that's how we solve ss.ss. bad drivers issues for our customers
Oct 16, 2012 | Argox R-400 Thermal Printer
My brother mfc 440cn had a paper jam & after i removed the paper "unable to print 50" & "unable to print 30" showed on the screen. i went to brother web site & went to the...
You have to open the printer and set it back into the ph carrier.
1) Remove Plastic wire covers from inside printers, and release plastic stay on lower edge, tilt cover to 90 Degrees 2) make a note of where each connector goes 3) release the Ribbon and 3 Multicolor cables, removing grounding screw, then remove scanner module by sliding it off the hinges at 90 degrees. 4) Remove Three Front Panel Screws, carefully leaver front panel upwards releasing front side clips.5) Remove front panel by disconnecting ribbon and wiring on both sides.6) Remove 6 Screws (2 on back, three at front and one middle right7) Carefully remove speaker cable (Red Connector) and lift up plastic casing, leaving printer uncovered.8) Re-Seat Encoder Strip.9) Re-assemble in reverse.
Nov 08, 2011 | Brother MFC-440CN InkJet Printer
Hi There. I have Tally T2265 Serial Matrix Printer. It shows "Hardware Alarm & Check Ribbon Error" after printing 2 or 3 pages. Sometime it prints 7-8 pages and sometime it prints 2-3lines...
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Before suspecting other components check the printer model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribbon should be 062471.
If the correct ribbon is used the problem could be the timing strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be caused by the timing station on the carriage, the carriage motor.
Mar 10, 2011 | TallyGenicom 2280 Matrix Printer
The striker appears not to strike the Daisy wheel letters firm enough to produce a dark and clear letter. Many times the result is a letter not fully printed and it appears to be lighter along the left...
Please check the ink ribbon. There are two types of ribbons. The plastic one can be used once and if you try it the second time then there is no guarantee that all letters will appear fine and legible. (as may be happening in your case). The other is the cloth ribbon. This can be reused and it keeps fading as you keep repeating it. But in this case all letters are faded and nor selective.
Nov 22, 2010 | Lexmark Wheelwriter 1000 Typewriter
I added 2 mb memory to my 2 mb dell dimension c521 but it only shows 3.25 mb memory on my desktop when it should be 4.00
This is normal. You need a 64bit Windows if you want to see a bit more. The graphics can take up quite a bit of memory space.
Jan 03, 2010 | Dell Dimension C521 PC Desktop
The battery light remains on unless the power
If the computer will run on battery alone, and you cannot fully charge the battery, it's probably time for a new battery. The life expectancy is 2-3 years if treated right. Some people get a lot more life than others.
Here's a suggestion: when you run your computer, let the battery run fully down at least once a month. Do not leave it plugged in to line power all the time. Do not keep charging it when it is only a little bit discharged.
Jul 01, 2009 | Dell Inspiron 6400 Notebook
4 GB RAM showing up as 3 GB
If your operating system is running in 32 bit it will only use 3+gb of your memory it cannot fully utilize its full capacity before use 64 bit if you can.
May 03, 2009 | Sony Computers & Internet
Characters do not print.
The print solenoid plunger has a plastic cap on the end of the plunger it is probably broken. They are available but you need a bit of mechanical ability to install.
DickyO
Mar 18, 2009 | IBM Office Equipment & Supplies
Brother ML-300 Typewriter Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
