Question about WMU The Aviator 5 in 1 Wooden Music Center
My woode music cnter modell itrr-5o1cd player won't play
Door won' open all the way and it won't read cd
Cd recorder won't read blank cd
If it is a older CD Recorder, You have to use disc,s that stay music on the label. Disc,s for burning music from a computer will not work in them,
Dec 04, 2012 | Tascam CC-222mkIII CD Player / Recorder
I used a program to "clean" my system and now my DVD/CD player will not play music CDs. It reads data files all right and I can still play music files that are on my HD. How can I fix it as it is not
Go to Device Manager.
(WinXP example; Start > Right-click on My Computer > Left-click on Properties > Left-click on Hardware tab > Left-click on Device Manager)
Left-click on the + sign next to - DVD/CD_ROM drives.
Right-click on the NAME of the CD/DVD drive.
Left-click on Uninstall.
(A 'Squawk Box' will come up, "Warning you are about to uninstall this device. It is OK. Click on OK)
Close all windows, go back to your desktop screen, restart your computer.
(WinXP; Start > Turn Off Computer > Restart)
When Windows fully loads, there should be a 'pop-up' out of the system tray, "Found new hardware device", and perhaps another one, "Found CD/DVD drive xxxxx"
This 'slaps Windows around', and makes it find the address to the optical drive drivers.
No? Didn't work?
Then suggest you post the motherboard manufacturer name, and model number.
Or; post the computer manufacturer name, and model number.
(Model number is on the back of the computer, next to the Windows product key; or up on the side of the computer tower.
Some older models have a swing door in the Front Panel, and once opened the model number is down in there)
Also post what Operating System you are using.
(Windows XP, and Windows 7 are two examples of an O/S)
I'll see if optical drive drivers are available, and guide you in downloading AND installing.
Post back in a Comment.
Regards,
joecoolvette
Nov 10, 2012 | Computers & Internet
NEED operators manual for ITRR-501 retro 5 in 1. lost mamual. NEED TO KNOW how to record to CD Disc. Also will it record fro records to disc and record cassett to disk. PLEASE SEND me a manual. OR a zerox...
The unit will record to CD from the turntable, cassette or the AUX port. Place a blank CD-R or CD-RW in the CD tray. (Note: CD-RW discs may not play on other CD players.) Press the Phono, Tape or Aux button to select your audio source for recording. (For Aux, you will need to connect the source device to the AUX port in the back of the ITRR-501.) Wait for the CD disc to load and check for any indicator lights (you should see the "NO TOC" and "CD" or "CD-RW" lights lit). Select your Track increment (or Auto Manual for unattended track formation).Press Record button and the up arrow to adjust the recording level.
If you are recording from an LP, put the tone arm down on the record. For all sources, press Play. Press Stop to end recording or Pause to temporarily break the recording. Press the Track Increment button to advance the track number if you are doing so.
To finalize your CD-R to make it readable on all players: after stopping the recording, press the Finalize button.
The manuals for Innovative Technology products are available here: http://www.ithomeproducts.com/support . The products are listed in alphabetical order. The direct link to the ITRR-501 manual in English is http://www.ithomeproducts.com/sites/default/files/pdf/ITRR-501.pdf .
I hope this helps.
Sep 19, 2011 | Innovative Technology ITRR501 Audio Shelf...
My polaroid plays cd but does not play dvd. Response to a dvd is "no disk" How do i fix it? Mike
THERE ARE 2 DIFFERENT LENSES FOR READING A CD AND DVD. SO THE DVD LENS SHOULD HAVE GONE. SO PLS GET IT REPLACED FROM THE SERVICE CNTER ( HOPE ITS IN WARRANTY YET.)
May 15, 2011 | Polaroid 7'' Portable DVD Player
I have just purchased an HP Desktop computer and when I burn a Cd for music, everyting seems to work ok but when I try to play that CD on another player in my home, it won't play. Is there a setting...
Check the type of the blank CD/DVD you are using. Certain players won't be able to play CD-RW for instance.
If that doesn't solve the problem you might try to slow down your burn speed for a better quality CD/DVD. Sometimes a faster burn speed will lower the quality and other devices can have trouble reading these.
May 10, 2011 | HP Computers & Internet
I have a teac x-9, and during cd play, the cd doors randomly open and close causing me to restart cd play all over again. it does this on its own, and i don't push any buttons for it to occur. is this...
clean your eject button or check it 2 see if it is broke. if u have a remote try 2 play a cd with the cd player with the batterys out of the remote. last 1. the cd door could be off trak witch wood make the cd off balance when the eye goes 2 read the data on the disk it misses its data an will cause your cd player 2 open.
Mar 15, 2011 | Teac Audio Players & Recorders
Cd player won't play discs
Maybe you should try cleaning the lens by opening the shelf TOP, and cleaning the lens? I had that problem. Take a Q - Tip with alcohol on it and it will do the job. Careful to not touch any components, and unplug first! The system can electrocute you even if unplugged, so don't touch any electronic component else than the lens inside.
Nov 28, 2007 | JVC MX-K30 CD Shelf System
WMU The Aviator 5 in 1 Wooden Music Center Logo
23 people viewed this question
Top WMU Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a WMU Audio Player and Recorder Expert? Answer questions, earn points and help others
