Question about Samsung Audio Players & Recorders
There is a "whirrring" sound coming from the unit when turned on
By turning the unit off and on the "whirrring" sound will disappear.
Of late I must repeat the action up to 20 times before the sound disappears
    Scholar:
  • 144 Answers
Try a different power socket, there might be some other equipments connected on the same powergroup that cause this.
Posted on Jan 28, 2009
When i turn my key in my car every mourning it makes this noise thats goes erinn and then starts is this the starter or bad pulley its 98 lincolin continal
If it sounds like a squeeling, it would be the belt. If it sounds like a whirr with sounds of metal, it will be the stater.
Mar 25, 2011 | 1998 Lincoln Continental
My Wii has a red light when plugged in, and a green one while turned, on, the problem is, nothing is displayed on the tv or heard, also, the disk drive whirrs for a few second after turning on. The tv...
If the light is red, it means WiiConnect24 is turned off. Green means the system is turned on and it's normal for the Wii to whirr a bit when it's initially turned on.
Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
That said, Nintendo recommends calling them if this doesn't fix your problem. Hope this helps.
Jan 06, 2011 | Nintendo Wii Console
Printer has not been used in long time. when i set it up and turned it on, it whirrs, but no lights came on nor does it do anything
That sound like a formatter issue. Its the motherboard of the printer. You can try an NV RAM (its a reset): Turn it off and press and hold the down arrow and cancel. Then turn it on and wait for the message ''permanent storage init'' then release the keys and will get back to ready. If the issue persist the unit will need service
Aug 26, 2010 | HP LaserJet M1522n MultiFunction Printer
My Carrier hvac does not come on.
that sound was the contactor closing, check the outside wires make sure they haven't been cut or ripped off unit. Buy a generic a/c contactor and connect it to the low voltage wires and see if it will click. if so install it the same as the old one after shutting off high voltage. If it doesn't click it is in the wires 90% of the time!
Oct 29, 2009 | Carrier Heating & Cooling
2002 5 SPEED FORD FOCUS RATTLING SOUND.
it sounds like valves tapping or valve tap, im wondering if Lucas oil stabilizer might help in this situation any other opinions? the fact that it is recommended by so many people including myself, i use it alot
google Lucas Oil / 32 oz. heavy duty oil stabilizer
Aug 20, 2009 | 2002 Ford SVT Focus
Strange straining sound
Either compressor is going bad or the fan is rubbing. There is a condensor fan that comes on only when the compressor starts. So check the fan out first to make sure that it is not rubbing or moving around. If that is not then check the compressor by letting it run for about 5 minutes then touch the top of the compressor. BE careful as it can be extremly hot that will show you one of two things either bad compressor or condensor is dirty and a garden hose with a jet blast of water will solve the problem. If that doesnt work either compressor is bad and will either need to be replaced for about 250 dollars or unit will need to be replaced
May 30, 2009 | Haier Mechanical Air Conditioner HWF05XC7
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
Sound Disappeared for Samsung LCD - Unit is only 8months Old
this would be the pre amp. transistor , audio second pre amp volume control chip or audio amplifier , they will need to be tested to determine which one or ones should be replaced
Oct 15, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Sound card
my pc is not comeing sound . but some some come sound .what ia m do
Sep 04, 2008 | IBM ThinkPad T23 Notebook
35 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
