Question about Foxconn Computers & Internet
Update to bios for MCP61M05 series 846f1p07
Is there an update to the MCP61M05 series motherboard?
MJS_1
  • 150 Answers
SOURCE: motherboard BIOS softwere for update
The process of upgrading the BIOS on a computer is also
called "FLASHING" the BIOS.
On very old computers (486 and older) the BIOS may be
permanently programmed into read-only memory chips,
which are not flash-able, although it may be possible to
replace the chips, or re-program them using special
equipment by a qualified technician.
On virtual all modern computers, the BIOS can be updated
using new data and a special FLASH program available via
download from the manufacturer.
This is a very dangerous procedure that can destroy the
motherboard if performed incorrectly, and should not be
performed unless absolutely necessary, such as when
you computer or software will not run properly without it.
Most mother board manufacturer's (for example Asus) offer
software patches and downloads on their web site, as well
as BIOS upgrades.
Note that the BIOS is 100% board specific, installing the wrong
BIOS can permanently destroy *********** board, so make sure
that you download the correct one for your board.
Once you have the downloaded the BIOS upgrade, there are 3
possibilities:
1) The downloaded file is self-installing, either from Windows,
or it creates a boot-able diskette, which in turn contains all
the files needed to update (FLASH) the BIOS.
2) The BIOS comes with a a separate installer (.exe) which
either runs from Windows or via a boot-able diskette.
3) The existing BIOS has a "built-in" flash utility, accessable
through the BIOS settings. This utility runs at a very low
level without any operating system to self-update the BIOS
from your download binary file, located on the hard drive or
on a diskette.
This is by far the best and safest way to do the job, but only
if your motherboard and (existing BIOS) has that capability.
In any event, the first step is to visit the manufacturer's WEB
site, then go to SUPPORT or DOWNLOADS.
Find the exact model and version number of you motherboard
in the manufacturer's list, and download the latest BIOS
update, and any installation (or flashing) utilities that come
with it.
1) Follow the manufacturer's instruction exactly !!!!
2) Do not turn off the computer until the BIOS update is
complete, and you are instructed to do so !!!
N.B.
The computer BIOS is the lowest level program on your PC,
without which the computer CANNOT read the disk drives or
perform the lowest necessary functions.
If the BIOS is damaged, or
If the wrong upgrade is installed, or
If the upgrade is performed incorrectly, or
If the upgrade is interrupted or crashes before finishing,
the computer may become unable to repair itself, and
the mother-board may become permanently unusable.
(This depends on the actual mother-board and BIOS design,
and on the damage done by the failed installation)
Good luck,
Please rate my answers,
Martin
Posted on Aug 04, 2008
zohail
  • 1223 Answers
SOURCE: System not rebooting after BIOS update
may be u have flasshed a wrong bios to ur mother board u have to take it to service centre it basically bios dead can be repaired at cost , try removing RAM and then re install them see if it works
Posted on Feb 21, 2009
Daholk
  • 41 Answers
SOURCE: no processor bios update
Sounds like you need to flash the BIOS (UPDATE the BIOS).
Do you know how to do this? The way I do it is by setting up a USB key as a boot device and have the FLASH utility on there....
HERE IS A LINK
which contains files to create the FLASH utility either on:
FLOPPY
CD (via ISO IMAGE)
... as well as some guides on what to do and other helpful stuff.
Its worth noting that if you have made any changes to BIOS, they will be restored to the 'factory' settings when you FLASH in the updated BIOS.
This should work, let me know if it doesn't.
Posted on Mar 27, 2009
RPFinney
  • 385 Answers
SOURCE: ibm motherboard pro300a_afp bios update
Go to the Bios's Manufacturer's website, they will have it, get the update, and instructions to update.
there is a Specific procedure to follow.
Hope this helps
Regards.
Posted on Apr 17, 2009
preachw996
  • 1179 Answers
SOURCE: BIOS update for Asus A7V-ML
For branded computers like HP, Compaq, Dell the only place you can get the correct bios updates would be your computer manufacturer website under the support link. These companies do not use industry standard motherboards so it could corrupt your system to update from any other source. Hope this helps.
Posted on Apr 27, 2009
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
I want bios update
Go to the following address and look for the update you're looking for
http://www.foxconnsupport.com/download.aspx?models=en-us0000341&category=C000000001&series=en-us0000002&keywords=&sort=BIOS
Dec 23, 2010 | Foxconn 45CMX socket LGA775 motherboard...
I've AMD Athlon 64 bit processor 2800+ Motherboard Asus K8S-MX Series SiS 760 Fx series chipset BIOS version: 08.00.11 How can I save my current bios and update bios??
you must plug in your pc with ups
do step by step from internet and alwayas choice last date
http://support.asus.com/technicaldocuments/technicaldocuments_content.aspx?no=714
for download =http://drivers.softpedia.com/progDownload/Asus-K8S-MX-Bios-1013-Download-13287.html
1st thing you'll need to do is go to the motherboard manufacturer's website & download the new BIOS file & the flashing program. These 2 files will have to be copied to a bootable floppy, then you'll have to boot off it & do the update from DOS. The motherboard website should have a detailed explanation on how to perform a flash...print out the instructions & follow them exactly & you should have no problem
Nov 12, 2010 | ASUS K8S-MX Motherboard
Where can i get the bios update for my gigabyte S series model
http://www.gigabyte.com.tw/products/product-page.aspx?pid=1922&dl=1#bios
there is a link to the bios update downloads.
May 24, 2010 | Intel Gigabyte 8I845GVM-RZ 82845GV GMCH...
Wrog BIOS after Live update... MSI K8N Neo v2.0 Series (MS-7030) MS-7030 VER:20C
every bios update program makes a restore point for the previous version just roll back the update
Jul 01, 2009 | MSI Computers & Internet
BIOS update
It is not necessary to update your BIOS if everything is working correctly.
Jun 29, 2009 | ASUS A8N-VM Motherboard
We want to update bios for motherboard asus (p4bgl mx) model please let us know how we can procced and where we can find the bios drivers for motherboard.
Just follow the link below
http://support.asus.com/download/download.aspx?SLanguage=en-us
In product select motherboard
In series select socket478
In model select your model P4BGL-MX
click on search then select your oerating system and then download the BIOS and run the file to update the BIOS
Apr 12, 2009 | Computers & Internet
Mother board bios update
From datasheet on Intel 82865GV: > The 82865GV does not support AGP. ECS use selfmade "AGP-express" port, which isn`t "real" AGP. It is answer that this motherboard need to support videoadapters by BIOS. Recommendation - do not use this motherboard (and other on i865GV chipset) with "external" graphic.
Aug 03, 2007 | EliteGroup 865G-M Deluxe (865GMV50)...
Computers & Internet Logo
195 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
