Question about Microwave Ovens
My sound leisure mini jook selects a disc from the stack, puts it on to the disc turntable, but does not spin. After about 5 seconds, it retrieves the disc and places it back in the stack. The motor has been checked and is ok, and everything else seems ok. This fault happened out of the blue, and the system has been trouble free for the 2 years i have owned it. Any help or ideas as to what this problem may be would be much appreciated. Thank you.
  • 3,904 Answers
This sounds like a belt broke. It is very easy to miss this and I would take another look.
Posted on Jan 22, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave runs on its own
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: it appears that the noise is coming from the the turning or spin-
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
You probably have a bad motor.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Nov 23, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave - fans & turntable not working
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or a problem on the control panel.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Feb 15, 2009
  • 52 Answers
SOURCE: NN-A574SBBPQ - Microwave fans & turntable not working
2 fuses in a panasonic does not sound enough.
have you checked the main incoming power protection fuse normally 10amp or higher.
most panasonics have approx 4 fuses so keep on looking
Posted on Feb 21, 2009
  • 2501 Answers
SOURCE: doesn't heat anything
It sounds like the micro generator has died.
Yes, you should buy a new one as the cost of repair is likely to be high.
Posted on Jul 01, 2010
Testimonial: "Thank you for your quick response!! I truly appreciate it!!"
I have a CMW-100 microwave. The turntable has intermittently stopped spinning. Now, it has stopped spinning entirely. Is there a part I need to replace to fix this problem? Judie Snivley
Sounds like the turntable motor has stopped working.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Dec 15, 2010 | Cuisinart CMW-100 Microwave Oven
Turntable will not turn
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Aug 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
G.E. Spacemaker microwave turntable won't turn
Dec 16, 2008 | Microwave Ovens
The turntable does not rotate on jy Wirlpool vt 251/wh. Any advice please?
Dec 13, 2008 | Whirlpool Microwave Ovens
GE Spacemaker microwave - 5 yrs old..started to make loud sound when the turntable was on..been using it like that for the past 3 years by shutting off the turntable..Yesterday it stopped working...
The original problem was probably a bad turntable motor, which is pretty easy to replace.
Now I'd say you have a bad door switch (whether upper or lower depends on the model number) or a problem with the door switch mount.
This is a pretty simple problem to fix, too: http://www.microwavedisplay.com/doorsw.txt
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven Model JVM1440BD: turntable doesn't work. When we press start, turntable make semi-loud noise while oven is cooking, but it does not turn. We can stop noise by pressing...
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave turntable will not turn
KHMS 147KWH-0 TURNTABLE DOESN'T WORK
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can download Kitchenaid / Maytag / Whirlpool owner's manuals and installation instructions here.
Nov 20, 2008 | KitchenAid Microwave Ovens
It appears that the noise is coming from the the turning or spin-
Nov 20, 2008 | GE XL1800 1100 Watts Microwave Oven
Turntable does not turn
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
Sep 04, 2008 | Maytag Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
