Question about Microwave Ovens
How to replace interior light
How do you replace the interior light in this microwave?
  • myron hancock Jan 26, 2013
    Well thanks for the help, I ended up studying the microwave manual and found out from that and the internet that I take off the control panel and there was the light socket. I removed the bulb and it looked fine put it back in and made sure all was tight and bingo light works. Remember to unplug the unit first. Thanks again.
  • Jerry Kramer
    Jerry Kramer Jan 26, 2013
    Super to hear and also good to hear you no longer have to take off the outer shell.
  • 3,904 Answers
I would imagine that like most you will have to take of the outter shell of the unit and it will be accessible from there. Should be about 8 screws.
Posted on Jan 22, 2013
  • myron hancock Jan 22, 2013
    Wow, was hoping there would be an easier fix. Hadn't really planned on taking it out of the cabinets, but will try and let ya know what I found. Thanks.
Ge microwave interior light bulb replacement. model #PVM1970SR1SS
Open the cover n you will see the bulb open it by turning it sideways
Sep 12, 2014 | GE Microwave Ovens
Interior light bulb burned out
make this test and fix it. GOD BLESS YOU
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Oct 31, 2013 | Samsung SMH8165STE Microwave Oven
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Replace interior light on a model 8921
To replace the interior light, remove all screws holding case together. There are screws on the back at the top, down the sides, and possibly underneath. Once all screws are removed, slide the outer case off and you will then be able to access the bulb.
Jun 16, 2010 | Montgomery Ward MW8997BEC MW8997WEC 900...
Kenmore micowave oven interior light
THe microwave has to be removed from the wall and then the outer cabinet has to be removed to get to the bulb. Do not do this with the unit plugged in and do not do this if u don't know how to work on a microwave as there is a shock hazard.
Jan 26, 2009 | Kenmore Microwave Ovens
JennAir microwave JMC7000ADW lightbulb replacement
their is a panel up near the top on the right hand side of the interior cabinet just remove the screws and put in a new bulb
Jan 28, 2008 | Jenn-Air JMC7000 Microwave Oven
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Dec 23, 2007 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
119 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
