Question about Proform Exercise & Fitness
No lights on the top panel of Treadmill Pro-Form 345s
Pro-Form 345s CrossWalk has no lights on the displays of the top panel, however the button for the Power Incline works fine. The belt inclines and declines, but it will not run...no light...no run!. What can be wrong? Please help.
    Top Expert:
  • Proform Master
  • 12,223 Answers
1) replace the old batteries by new ones. clean the contacts batteries very well
2) tight the ribbon cable for keypads and clean it
3) tight the upper connector vs lower connector
4) adjust the REED switch, see the diagram clean it, test for open or faulty and tight the connector.
God bless youNo lights on the top panel of Treadmill Pro-Form 3 - 1_23_2013_12_32_44_am.gif
Posted on Jan 23, 2013
  • 4 more comments
  • Paul Kim Jan 23, 2013
    Thanks for the reply, but I don't see any batteries in this unit. Where ?
  • ernesto cuadra
    ernesto cuadra Jan 23, 2013
    read your instr. manual or download from www.fitness.manualsonline.com and see the comments.
  • Paul Kim Jan 25, 2013
    I have readjusted the reed switch, but still no light...no run.
  • Paul Kim Feb 01, 2013
    More questions...1) I see one battery (16V - 1 1/4"tall) on the Power Board which seemed to be attached (glued) on the board very tight...is this the one to be replaced?. 4) In order to clean well, may I sand both Reed Switch and Magnet? Thank you so much for your help.
  • Paul Kim Feb 12, 2013
    Do you have a same problem If you're not comfortable working around electricity and have a treadmill that has an electric problem, it can be rather frustrating and you may have to ask some `dumb` questions. Unfortunately, I could not find the right answer from FixYa, although I was able to find the solution to the exact same problem on another website. With it, I was able to replace the right part by myself, and it took care of the problem right away. If you have a problem with a Sears product, you might try asking the Manage My Life website. I have attached a link below for your information. http://www.managemylife.com/mmh/question...
  • Paul Kim Feb 13, 2013
    Do you have a same problem?......... If you're not comfortable working around electricity and have a treadmill that has an electric problem, it can be rather frustrating and you may have to ask some `dumb` questions. Unfortunately, I could not find the right answer from FixYa, although I was able to find the solution to the exact same problem on another website. With it, I was able to replace the right part by myself, and it took care of the problem right away. If you have a problem with a Sears product, you might try asking the Manage My Life website. I have attached a link below for your information.http://www.managemylife.com/mmh/question...
3 Suggested Answers
SOURCE: Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Posted on Jan 06, 2010
SOURCE: I have a proform j8li treadmill, all 4 led lights
I have the exact same problem with the very same treadmill that i bouth 10 years ago and it has been sitting for 5 years unused. The last time it was turned on it worked but now that I plug it in and try to start it, everything works but the belt drive motor. Any ideas?
Posted on Feb 09, 2010
Proform 345s stripes on the walking belt. Powdery residue on the floor below the belt. Everything functions normally, and the belt is properly aligned.
1) this a normal problem. However you must know that you must LUBE the deck belt every 5hours aprox, in according with the use.
2) You must check the tension in deck belt aprox 3- 4"High aprox from the middle.
God bless you
Nov 14, 2012 | Proform Crosswalk 345s Treadmill Walking...
My proform 345 stops almost every time i get on it. i usually have to let it warm up 10 minutes before it runs ok. whats going on?
1) you must LUBE THIS Happen because the machine has special design for to protect the electronic system. Maybe you have NOW WORN deck belt, time to replace.
2) Lube the rollers bearing too
3) test the bearing for the main motor. and repair
God bless you
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
My pro-form crosswalk 397 the track will not work. The lights display and it makes a sound but the track stays in place. I bought this on Black Friday and have only used it 3 times. Help!
INMEDIATELY LUBE the deck belt, maybe is WORN. and adjust the roller bearing see the diagram attached.
2) Test the input voltage motor, if there are the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.
sincerely. God bless you
Apr 23, 2012 | Proform Crosswalk 397 Treadmill
I need screws to reattach control panel to my pro-form 590-ls crosswalk treadmill
Dear Sir:
You need to check you user manual. Anyway you must need 6 long screws philips for attach plastic-iron about 1 -1/2"-to 3/4" you can buy in any hardware.
You can download your user manual free http: //fitness.manualsonline.com or+go
www.proform.com go customer service and then parts & manuals put you model and serial number and download and ready.
sincerely.
Oct 08, 2011 | Proform Crosswalk 500 Treadmill
Is there a reset button for the pro form treadmill?
Yes the reset button is the breaker, is inside of the equipment
or to side the main switch. If you have problem with tripped the breaker better you can do it some diagnostic, if the faulty is inside or outside.
If is inside, you must see the power cord,controller motor, motor, transformer. or some loose cables, or bad contact, corroded conections. sincerely.
Aug 24, 2011 | Proform Crosswalk 500 Treadmill
I own a pro form Crosswalk model 405 and the instructions were lost in a move. How can I obtain a new copy?
This is probably not your ideal solution but just in case it is helpful here is a list of the models of the proform crosswalk 405, if you select your exact version you can purchase a new owner's manual.
Jul 20, 2011 | Proform CrossTrainer Treadmill
Jerky treadmill
Please check out this tip I wrote. Please let me know if you need anymore help.
Apr 08, 2010 | Proform Crosswalk 500 Treadmill
Pro-Form Crosswalk Plus Treadbill back leg extension
iconservice.com has free pdf downloadable manuals for proform.
Nov 12, 2009 | Proform Crosswalk 500 Treadmill
Exercise & Fitness Logo
130 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
