Question about HP ProLiant DL385 G2 (438815-001) Server
HP DL385G2 RHEL 6 install fails
RHEL 6 install fails after installer boots
4 Suggested Answers
Tech Jenkins
  • 359 Answers
SOURCE: New memory installed in a HP Pavilion dv6000t Laptop-Booting Problems!
I have had bad memory straight out of the "box". Just becuase it's new memory does not mean it's good.
Take it back and get another stick.
Posted on Sep 02, 2008
SOURCE: NIC card not detecting in dx2280 in RHEL / Linux
if it is not or if you don't know, then just go into setting when you first boot up your computer by either pressing F2 or the Delete button.then go into your bios and find where the plug and play is and enable it then save and exit. reboot and then see if it detects the nic card. if that doesn't work then you would need a pro to install for you. let me know if that helps or if you have any other questions.
Posted on Jun 25, 2009
  • 214 Answers
SOURCE: HP compaq NX9420 fails to
Hello Dear,
If you tried to install the windows XP on a failure HDD then it will behave like this.
You need to check your HDD first, Go to your BIOS and run the HDD Self test.
If it successful then Just format your HDD before installation it should work.
If it failed then you need to replace your HDD.
With regards
FIXYA team
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Posted on Oct 11, 2010
Steps to install linux through server?
Hi..
Let me show some basic steps which will help you to install RHEL through server or Network
Before we start, i would like to point out some informations
  • Steps shown here are explained with RHEL 5. But the procedure is same for all versions of RHEL which supports Network installation
  • For the Convenience to take snapshots, i'm installing RHEL on a VMware (Virtual Machine). So to me, some hardware resources are limited like physical memory, hard disk space, Graphics adapter ..etc
  • My Server which contains RHEL images is " LinuxServer " and its address is 192.168.75.100
  • Location of RHEL5 Installation Image on this server is: /home/nightflare/Test/RH5/i386
    Shared folder is: RH5/i386
    So if we want to access this folder through network, then the address would be : 192.168.75.100/RH5/i386
  • Due to limited hardware resources of my machine, i would proceed with TEXT MODE installation which is no different than the Graphical Mode.
So lets start.
I have a bootable CD of RHEL which i will need to start with. You can use any live CD or DVD of RH ( which support network installation ) to start the system. I inserted the Disc and set system to boot with it.
1. START THE SYSTEM TO BOOT FROM THE LIVE MEDIUM
If you successfully able to boot from the live CD / DVD, you probably will get a screen like this
Type next to the boot: linux askmethod text and press
The option "askmethod" will set the installer (anaconda installer is default installer for RedHat) to ask us for which installing method should be used. RedHat Linux supports many installing methods like
  • CD or DVD (Local CD / DVD are supported. If you want to use Remote CD/DVD, you will have to mount it in a shared folder and proceed with network installation method)
  • Hard Drive (installation files stored)
  • NFS Image (images stored in Network Filesystem Partition over a network)
  • FTP (Installation files stored on FTP Server)
  • HTTP (Installation Files stored on HTTP Server)
The option '" text " will tell installer to use TEXT MODE installation. If you prefer Graphical Mode installation, you can skip this option.
After pressing Enter Key, the anaconda installer will load necessary files and drivers to memory and start the second level of installer. You will see,
2. SELECT LANGUAGE AND SET LOCATION BASED PREFERENCE
After essential drivers and files are loaded, installer will ask for installation language, keyboard etc.
I select English as my installer's Language
On this screen, Choose the layout of your keyboard. In Most cases, The Keyboard Layout is USA, so is mine. But if your layout is different, choose appropriate Keyboard Layout.
I Choose US
3. SELECT INSTALLATION METHOD
Since we start the installer with askmethod , installer will ask for the method of installation.
I chose HTTP, since my RedHat Server is HTTP server.
4. CONFIGURE NETWORK
When we chose Network Based Installation, Installer will prompt for configuring the network.
On this screen, Select what all IP technologies we want to be supported by the installer.
After selecting the IP configurations on previous screen, the installer will look up and resolve IP addresses.
After resolving IP Addresses, Installer will ask you for location of installation files on the network
Since we selected Installation over HTTP , we need to specify the server (Host name of server) which contains the binaries or installation files. And we needed to specify the location of the installation files in the server. Remember this location is relative to server and web accessible directory
ex.: in my case Server Hose name is LinuxServer and IP of server is 192.168.75.100.
Installation image is located under /home/nightflare/Test/RH5/i386
But the location should specify on this screen is /RH5/i386 NOT /home/nightflare/Test/RH5/i386 or 192.168.75.100/home/nightflare/Test/RH5/i386
After entering the details necessary to find the installation images, it will try to get those files.
If everything went fine, then it will try to pull the files from server.
If you see this screen, you can relax. System successfully found the installation files on server and retrieves it.
5. SET INSTALLATION
Rest of Installation is just same as Installation by Local CD/DVD
Just Skip this window. RHEL also comes in CDs which spans over many CDs each with a installation no. like DISC 1, DISC 2 ... etc. This is not our case, so we can skip it safely.
This screen ask to confirm our option to Skip. Choose Skip
Searches our system for any previous installations of RedHat
If Any previous installations were found, installer will ask for whether to Upgrade the previous installation or we need to Reinstall. I choose to reinstall
On next screen, we are requested to specify the partitioning. We can either accept the Proposed Partitioning or proceed with Custom Partitioning.
I Choose Custom Partitioning as it will provide more control over how the spaces are alloted ..etc.
Since I go with Custom Partitioning, I can edit, create and even modify partitions according to my needs.
Remember, I'm working on a VMware. In real cases you may dealing with larger disks or able to set up LVM or RAIDs
Select Whether Need a Boot Loader or not
On This screen, we can choose have extra boot options or not. Booting options are like typing single will cause kernel to log in to single user mode rather than multiuser mode
[ Sorry, fixya says this post exceeds max message lengh ]
Feb 19, 2011 | Red Hat Enterprise Linux ES Basic Edition
I got a dell inspiron 1525 laptop..i'm unable to instal RHEL 5...it is showing the error that no hdd is found..how can i install RHEL 5
Since the Redhat install is not seeing the HDD controller, you'll need a sata controller driver to load at boot. You can try this one
http://support.us.dell.com/support/downloads/download.aspx?c=us&cs=RC1084719&l=en&s=k12&releaseid=R129572&formatcnt=1&libid=0&typeid=-1&dateid=-1&formatid=-1&fileid=172694
Nov 25, 2009 | Dell Inspiron 1525 Laptop
RHEL 5.3 fails to boot at "bringing up interface"
I found the solution.
Take in accunt that I'm a total newbie on Linux boxes.
1 - Previous to any change, following RH deployment guide, I backed up the network config on a file called "network-config-10.1.1.5" with:
"system-config-network-cmd -e > /root/network-config-10.1.1.5"
2 - After the Server refuses to complete boot sequence, I rebooted the server and entered on interactive mode pressing "I" just after RHEL splash.
3 - Then I accept all options with "Y" but "Bring up interface bond0".
Then hit "C" to complete boot sequence.
4 - Login normally as root and revert the changes with:
"system-config-network-cmd -i -c -f /root/network-config-10.1.1.5"
5 - Reboot the server and all return to normal.
Oct 07, 2009 | HP ProLiant DL360 G5 Server
Jun 24, 2009 | HP Computers & Internet
Installing RHEL 5 on ACER ASPIRE 4530
1) Get SATA drivers for Windows (whatever flavour you use)
For you who want to get driver AHCI for Acer 4530, the driver can be download here:
http://rapidshare.com/files/196616727/Driver_AHCI_Acer_4530_-_Windows_XP.rar
2) Control Panel, Add New Hardware.
3) Yes, already connected, browse to the bottom, hit “add a new device”
4) No, point it to the directory of your SATA drivers
5) Choose your driver from the list that returns. (Mine was the nVidia SATA controller)
6) Uninstall other standard IDE controllers (Not Primary nor Secondary)
7) Reboot and enter your BIOS
8) Change to AHCI mode
9) Boot to Windows… , if you success you will not meet the Blue Screen and Windows will install and find the driver automatically.
10) Windows wants to reboot. Do that.
11) Go to Device Manager and then uninstall the AHCI controller that you installed (there will be two or more now, but must Uninstall the one with the exclamation mark)
12) Success!
Jun 04, 2009 | Acer Aspire 4530-5889 Notebook PC
How to connect two hard disks
Japanese Pantyhose Foot **** & Asian Footjob Nylon DVD http://www.avleg.com
Dec 09, 2008 | Gateway 310S (2900621) PC Desktop
RHEL %
change HDD mode in bios setup and try.
it seems that RHEL is not supporting your SATA hardisk.
Aug 01, 2008 | Acer Aspire 5610-4648 Notebook
No gui during installation of RHEL 5 on acer 5920 notebook
Hi Jay
may be the following link helps u
http://www.linuxtopia.org/online_books/rhel5/installation_guide/index.html
Jun 21, 2008 | Acer Aspire 5500 5570-2609 Laptop
Not able to boot RHEL5.1
which ver of red hat is it? x86, etc?
Mar 31, 2008 | Intel D102GGC2 Motherboard
HP ProLiant DL385 G2 (438815-001) Server Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
