Question about Dell ST2010 20" Monitor
How to open the monitor case dell st2010 - Dell ST2010 20" Monitor
  • Dell Master
  • 998 Answers
2 Suggested Answers
  • 152 Answers
SOURCE: HOW DO I OPEN THE CASE OFTHE DELL FLAT MONITOR
tonylad, Remove the pedestal by taking out the 4 phillips screws on the back. The back plastic cover will now be able to be pried away from the front bezel along the seam on the bottom of the monitor or sides. You may want to go to YOUTUBE to see how it's done. you need to search under LCD monitor repair or somthing similar. Yes I have seen some there that are about 8 to 12 minutes view time. If you get it apart please be very careful when handling the LCD/FPD . Next you will need to inspect the the large SWITCH-MODE-POWER-SUPPLY board. Look for any swelling of the tops of electrolytic capacitors. If you find any, mark them with a marker. With magnifying glass or a inspection microscope check the bottom of the board for thermal and or vibration FRACTURES surounding the leads of large THROUGH-HOLE components soldered on the board. Also look for any really FROSTY looking solder joints. Well, anyway good luck guy. Get back to me if you find anything out. I'm louie12fix on fixya or lmistyrel @aol BYE
Posted on Mar 26, 2009
Line across bottom. Appears to be repeat of top of screen.
Try opening the monitor disconect the display panel from pcb power on amd then connect ur display panel. Hopefully display will be remaped when u restart the monitor
Jan 07, 2015 | Dell ST2010 20 inch LCD Monitor
Dell monitor too dark; Blinking
Monitor sounds like it's dying
Sep 02, 2017 | Dell ST2010 20" Monitor
I have a DELL ST2010 flat wide screen computer. The brightness has shut down since 2 weeks and I was told the 2-CCFL edgelights should be replaced. is it easy to do so and where can I find this lights...
Lamps: http://lcdparts.net/
But are you sure it is the lamp assembly problem not the power supply or backlights inverter problem. You should do some in-depth troubleshooting first, replacing the lamps on these new LCD panel is not as simple as the old model where you just remove the mounting screws and slide the assembly out, you may have to do complete tear down to get the lamp assembly out and it should be done in the clean-room.
Please read my guide first:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 19, 2011 | Dell ST2010 20" Monitor
I don't get sound. Should the sound plug be connected to the back of the monitor to audio in, or audio out?
cable should be inserted in the audio in port at the back of the TV and on the audio out of whatever device you want to hear sound from - DVR, DVR, VCR, cable box, etc...
hope the above helps.
Jul 28, 2011 | Dell ST2010 20 inch LCD Monitor
My dell moniter 2010f flickers all the time. I have another moniter on that uses the same card by does'n flickers. I also pugged the dell in by its self and it still flickered. l also down loaded...
Sounds like an issue with the backlight in the monitor. Usually the backlight is built in to the LCD panel so there really isn't a way of fixing this unless you replace the panel.
Please rate my solution to show your appreciation!
Jun 02, 2011 | Dell ST2010 20 inch LCD Monitor
I want to hook my xbox to a Dell? ST2010B with an HDMI. I was wondering if there is a way to get sound? The xbox displays but I get no sound.
My research indicates that that the Dell ST2010B monitor is equipped with a sound source, but there is an optional 'sound bar' that is or was available for it. see
does 20 Dell ST2010 Black High Definition Monitor have built in speakers
and
ST2010 Monitor Has No Sound
8.March.2015
Dec 26, 2010 | Dell 1800FP Monitor
My 20 inch dell monitor is only using the left corner the screen and you can only see part of the desktop is visable and the text is upside down.
mcdevito75 here, Press the AUTO button on your monitor, if this does not work, press the MENU button, there you should see a square box with 4 arrows, these are used to center your picture on your monitor, use the left / right arrows also on your monitor to adust the screen picture with this box woth the 4 arrows from Menu.
Jul 16, 2010 | Dell ST2010 20" Monitor
My 20 inch Dell Monitor keeps shutting down..
mcdevito75 here, Sounds like the monitor itself, contact Dell for rep[lacement on warrantee if warrantee applies.
Jul 14, 2010 | Dell ST2010 20" Monitor
Dell ST2010 20" Monitor Logo
416 people viewed this question
Alun Cox
