Question about Toshiba Computers & Internet
Laptop has an error message that says boot manager is missing press contrl alt delete to restart computer
If you go to this link it will walk you through the steps of being able to reprogram your boot manager. Its a software issue, not hardware. If you have your windows cd (windows 7 or Vista) you should of got when you bought the computer, it will walk you through all the steps & help you repair it for free.
http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
If you don't have access to the disk another possibility is that you can turn your computer on, while it is turning keep pushing down F8 button continually during start up. That should take you to the internal computer operating system, where you can select safe mode. When it opens you will be asked if you want to continue in safe mode or reboot computer to a date that worked you know of. It will restart it from that point, before you got a virus.
Hope either help, not sure if reboot way will work without a boot manager but worth a try. I've done it when I got infected with a virus on my dell laptop.
Posted on Jan 23, 2013
sexymax15
SOURCE: Compressed boot manager
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529
More Info MS KB 927391
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
  • compact /U C:\bootmgr
  • compact /U C:\ntldr
Posted on Sep 29, 2008
  • 62 Answers
SOURCE: PREINST6.SWM missing; PREINST9.SWM missing; Error:10-FC06-0002
The fact that you have an error of missing file whit the restore DVD indicate that the problem could be hardware. Especially if you already did a restore whit the same DVD.
I would suggest that you have a faulty memory issue (RAM), you can run a memory diagnostic whit memtest86 http://www.memtest86.com/ download the bootable cd and run it if you see RED readings your memory is defective if not let it run for a couple of loops to make sure.
I'm pretty shure you will see red results, if so take it to your local computer specialist to get it replace or order yourself some.
Posted on May 27, 2009
gambit3rogue
  • 106 Answers
Means pre-installion is missing. Which means yoou either have to Reinstall a fresh copy of your windows or your can reinstall your windows by just repairing the files. Its always good to make a recovery disk after every install. If you haven't tried it already restart your pc press f8 as the scene pops up and go to Last good configuration.
Posted on May 30, 2009
Geekman
  • 32281 Answers
SOURCE: acer 5515 backlight not working also bootmanager missing
You need to fix the boot manager problem first by connecting an external monitor to the laptop so you can see and do a system repair.
As for the backlight problem :-
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info
Posted on Aug 15, 2009
mahhek
  • 657 Answers
SOURCE: trying to boot up a toshiba laptop and getting
SOLUTION 1
- Get your Vista installation DVD and pop it into your drive.
- Then restart your computer.
- Set your computer to boot from DVD or CD in your BIOS.
Vista will ask you for language and keyboard layout information, after which you will be asked if you want to re-install Vista or repair your existing installation.
Select Repair. After which Vista's System Recovery Tool will start.
Select Startup Repair and let Vista do its thing! That really is all there is to it!
If that doesn't work try this:
SOLUTION 2
If the previous method does not resolve the problem, you can rebuild the BCD store by using the Bootrec.exe tool in the Windows Recovery Environment. To do this, follow these steps:
- Press a key when you are prompted.
- Select a language, a time, a currency, and a keyboard or another input method, and then click Next
- Click Repair your computer
- Click the operating system that you want to repair, and then click Next
- In the System Recovery Options dialog box, click Command Prompt
- Type bootrec /rebuildbcd and then press ENTER
• If Bootrec runs successfully, it will present you with the installation path of a Windows directory. To add the entry to the BCD store, type Yes . A confirmation message appears that indicates the entry was added successfully.
• If Bootrec cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order shown below: (Remember to press ENTER after each command)
bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
bootrec /rebuildbcd
- Restart the computer.
Posted on Sep 24, 2009
Hey, i hv lenovo ideapad s110. there is a error showing while restart my pc " BOOTMGR is missing" nd there is a instruction tht press ctrl+alt+delete.. i hve done tht bt its not showing any progress. ...
The Boot Manager is the fi;e that allows Windows to boot and looks like it may be missing.
Try pressing F8 just before it tries to boot and select Repair or Restore System if available.
Nov 30, 2013 | Computers & Internet
Error message on laptop that says boot manager is missing press ctrl alt del to restart computer
it is looking for windows boot manager need to run a repair from disc on boot
Jan 22, 2013 | Toshiba Computers & Internet
Dell inspiron 1440.boot manager missing. asking to press contrl+alt+delete.tried but nothin happen. plz let me knw wht shd i do? thnx
TURN THE COMPUTER OFF BY PUSHING THE POWER BUTTON OFF LET SET FOR 5 MIN REMOVE THE BATTERY AND THEN PLUG IN THE POWER CORD SEE IF IT WILL BOOT IN SAFE MODE THIS CAN BE DONE BY PUSSING F8 WHILE THE COMPUTER IS BOOTHING UP USE SAFE MODE WITH NETWORKING IF IT COMES UP YOU HAVE A SMALL CONFLICT SOME WHERE WHEN YOU SHUT DOWN AND REBOOT MOST OF THE TIME IT WILL CORRECT
Feb 15, 2011 | Computers & Internet
I hit "contrl, alt, delete"
For that you need to start computer in safe mode. For that when you power up the computer press F8 key then enter in safe mode. Remove temp files from computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive. Then you can use it again. If still same then you need to create new user account .from start menu->control panel.You can create it on safe mode too with default administrator account. Let me know if you need further assistance. Thanks for using FixYa.
Nov 23, 2010 | Computers & Internet
Compressed hrd drive now it won't boot up error mess says compressed boot manager press alt,contrl,delete(win7)but just comes back to same screen
boot from Windows 7 disc, and Repair Windows 7. When it comes up it will ask u the language, pick your language, then in the bottom left corner of that box that says Install now, you will find repair my computer :)
Apr 13, 2010 | Acer Aspire 5100 Notebook
My screen on my norcent computor says NTLDR is missing press contrl alt delete to restart I did all this and takes me back to this screen everytime. This computor is not here with me it as at my sisters...
See here. and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 29, 2009 | Computers & Internet
Windows Vista Will not load correctly
sounds like you have some corrupted files in the boot sector. 2 options.
1. using a vista dvd: let it boot from dvd and when it is loaded select the repair my computer option. once you get up and running use malwarebytes and superantispyware to remove any nasty bugs that you may have caught.
2. using your recovery partition do a system recovery this option restores your pc back to when you bought it.
Aug 29, 2009 | Toshiba SATELLITE Notebook A205-S5813
Aug 28, 2008 | Computers & Internet
BOOTMGR is missing Press Ctrl+Alt+Del to restart
first u go to bios settings and change first bootdevice cdrom and reboot system u put winxp cd in cd drive
u will see this message
press any key to boot from cd
u press any key
winxp setup start automatically
and repair winxp
som case hardisk partition probelm , that case u will format drive and re install winxp
Jul 12, 2008 | Computers & Internet
Computer crashed and will not restore.
if u tried installing windows from a CD onto the HDD and it still says missing ntldr. seems like a Bad hard-drive.
you can restart by pressing control-alt-delete.
then, try booting from windows CD and repairing the windows installation. if it gives u file copy errors.then, it is a HDD failure. get a new HDD.
Mar 30, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
