Question about Speed Queen AWS52NW Top Load Washer
Speed queen top load washer leaks
Believe from main seal water pours from bottom
    Problem Solver:
  • 13 Answers
Is it a bad leak like it will not fill up with water or just a small leak.
If it will not fill up it most likely is the tub seal. If it is a small leak it might be the water pump seal. There are two screws at the base of the machine that takes a 5/16" or a 8mm socket to remove them.
remove the front cover and start the machine filling and watch for the water DO NOT STICK YOUR HAND IN SIDE THERE WHILE THE MACHINE IS ON!!!! Here is the repair manual for your machine.
If I was you I would repair the machine instead of replacing it. these are awesome machines I have 20 of them in my laundromat that are 19 years old and still trucking every day. the seal is some work you will need some tools and a 3 jaw puller to replace it but you can rent them at most auto parts stores. If it is the pump that is a simple fix just remember to clean and grease the end of the shaft .
here is the repair manual for your machine and the number should be AWZS52
http://www.partsking.com/pdf/201142.pdf
here is the seal kit
http://www.partsking.com/mm5/merchant.mvc?Screen=PROD&Store_Code=pk&Product_Code=766P3A&Category_Code=
here is the water pump
http://www.partsking.com/mm5/merchant.mvc?Screen=PROD&Store_Code=pk&Product_Code=201566P&Category_Code=
GOOD LUCK
Posted on Jan 23, 2013
  • 12 Answers
SOURCE: At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Posted on Apr 09, 2009
  • 142 Answers
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
Posted on Sep 14, 2009
  • 84 Answers
SOURCE: My speed queen top loader is leaking water during
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
Posted on Jan 12, 2010
  • 254 Answers
SOURCE: Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Posted on Feb 03, 2010
BIKER T
  • 909 Answers
SOURCE: Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Posted on Jul 21, 2010
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Speed queen Marathon top loading washer- Water leaks into drum when not in use??? Shut off valves in the basement.
The problem is the water inlet valve has failed. There is a video on checking this at www.appliancehelponline.com/servicemanual.html it's a different model but the testing procedure will be the same.
Mar 28, 2010 | Speed Queen AWS52NW Top Load Washer
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
My speed queen top loader is leaking water during the washing period. Water is coming out of the bottom of the washing machine while it is washing
Easy repair.
Nov 08, 2009 | Speed Queen AWS52NW Top Load Washer
Water leaking through main shaft bearing?
Worn main seal...major job.
Do not use machine.....240volts + Water = Morgue
Oct 19, 2009 | Speed Queen AWS52NW Top Load Washer
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
Speed Queen AWS52NW Top Load Washer Logo
115 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
