Question about HP Photosmart C7280 All-in-One Printer
I have a clear plastic strip that is about 10 to 12 inches long that came out of my HP C7280 all in one.I am not sure where it goes.It has something to do with my cartrige carrier, and moving it.Can s
Or if i can get a diagram, or fix it book, or even a repair manual. So I could fix it.
4 Suggested Answers
rockfixya
  • 679 Answers
SOURCE: psc 2110 carriage jam
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
  • 24 Answers
SOURCE: Long 20 inch plastic was taken out of a HP 1220 C Printer.
This plastic strip is probably the so called "encoder strip", it has many fine black lines that the carriage sensor counts to find out where the carriage is located on the paper.
This encoder strip is attached directly to the printer's frame on the right, and to a leaf spring on the left side. It also runs through a slot on the back side of the carriage.
It can be treaded back and reattached if you're nimble-fingered, but in many cases it's broken and needs to be replaced. As far as I remember HP doesn't sell these parts separately (correct me if I'm wrong!) so if it's broken the printer most probably has to be turned in for service.
But if the encoder strip is intact, there's no right or left side - or up/down - of it, so it can be attached any way you want - as long as you get it back properly. Usually it's best to first hook it up on the leaf spring, then attach it on to the small hook on the right side. Being able to slide the carriage back and forth eases the operation. You can get it back without disassembling the printer; it's fiddly but it's possible.
Good luck! :)
//Al
Posted on Mar 10, 2009
SOURCE: 0xc05d1281 HP-C7280 Ink System Failed -- tried
printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
Posted on Oct 20, 2009
The printer was working fine, then I moved and it was packed up. Now the printer turns on but paper goes thru and crunches up and creates a paper jam every time. Is there something I can do to fix. I...
Hi, sounds like the feed thingy at the rear is misaligned.
Open rear compartment door to reveal the thingy !!
Remove by releasing clips either side pull clear, while out just check there is no paper jam, locate back in making sure the thingy relocates with an obvious click on securing . Hope this solves problem.
Sep 08, 2011 | HP Photosmart C7280 Printer
My C7280 will no longer print black. Here is what
Same issue on my C7280 - just stripped it down and cleaned all the ink lines - forcing ink through the black line by manually actuating the pump and it appears to be working again but not sure for how long. Not something everyone would tackle as you need torx drivers and ability to take it apart which is tricky.
Apr 10, 2010 | HP Photosmart C7280 Printer
0xc05d1281 HP-C7280 Ink System Failed -- tried clearing the error status still same problem, also noise from the print head sounds like plastic gears sliping, print head moves back and forth gears slip and...
Oct 19, 2009 | HP Photosmart C7280 Laser Printer
I have an HP C7280 All-in-one printer. I was
Well, I took the printer apart(as much as I could w/o removing any screws)and copied something onto card stock. I was looking for any extra business cards that I'd missed. The copying worked. I then unplugged everything and took the printer off of it's stand. I then noticed a piece of plastic from the feed in the back lying on the stand. I somehow managed to get it back on the printer where it belonged and voila! the printer worked! Don't know if the plastic piece was the culprit, but at least the printer works now.
Oct 02, 2009 | HP Photosmart C7280 Laser Printer
HP c7280 scan 2 vertical lines
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00899181&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3204785
this fixed it for me
Sep 20, 2009 | HP Scanjet 8250 Flatbed Scanner
Photocopy has black band at end of the page
well ithink tou are using the ADF to copy something...you will have to clean the scanner glass(not the scan bed but when you lift the ADF cover you will see a scanner glass about inch wide)...it should resove your concern...
Mar 27, 2009 | HP Photosmart C7280 Printer
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
HP All-in-One 3210 Carriage Jam
e cycle for sure ... unless the little plastic part was off tha cartridge
Apr 10, 2008 | HP Photosmart 3210 Printer
HP F370 PSC
One possibility is. look toward the back of the printer, there is a strip of clear plastic, about a quarter inch wide and clear. It runs the length of the print head area. That contains the stop strip. That strip or the sensor on the print head itself may be dirty and not sensing the strip, therefor not knowing when to stop.
Mar 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Child damaged HP6110 - Help
It stretches from left to right behind the cartrige assembly and the assembly slides on it. It's a sensor strip for positioning the cart. asm. I'm not sure how it attaches, but you'd have to take the unit apart to do it.
Good luck...
Geno
Mar 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Photosmart C7280 All-in-One Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
