Question about Panasonic KX-T7730 Corded Phone
I CAN'T TRANSFER CALLERS TO MY VOICE MAIL. I PRESS THE "TRANSFER" BOTTOM AND MY EXT BUT SCREEN SAYS "NOT VALID"
  • 2 more comments
  • yvette_conle Jan 27, 2009
    DOESN'T MATTER WHAT PHONE I'M ON IN THE OFFICE. IF FROM ANOTHER EXT IT WILL ONLY RING BUT NOT INTO VOICEMAIL.
    yes. from outside line voicemail works. just not internal.
    when tranfering from another phone in office, my line will ring and ring then bring caller back to originated ext.
    I'm sorry but what is PBX?
    President:
  • 1,214 Answers
Most phone systems will not let you transfer to voice mail if you are on the extension that you want the voice mail to go to, which is the reason for the "Not Valid" message.
The logic is, if your talking to them on the phone, why would you want them to leave a message on your voice mail. Your talking to them directly already.
Posted on Jan 27, 2009
  • 1 more comment
  • Mark Egan Jan 27, 2009
    Does voice mail work when someone calls in direct from an outside line?
    There is nothing in the manual about this functionality. The transfer button is intended to be used to transfer to another extension, just as you indicated you have done.
    Unless you know that functionality to be an undocumented feature, I don't think you have it, or, if you are hooked to a PBX, that may be a function that the PBX can be programmed for.
    A PBX is a central telephone control switch installed in an office environment to control all incoming and outgoing calls through a central controller.
Im trying to set up a voice mail box, a separte one I can transfer callers to when they want to leave a message for the person not in the office
My dear , It is impossible, becous your voice mail cannot identify your office calls and home calles
Jul 21, 2011 | Cell Phones
Newbie- never posted- so please take it easy- Have Partner Plus Phone system. With Partner Mail VS- release 1. Need to change the MAIN message callers hear before entering the extension number. Have...
The part your missing is pressing 9 after 99# password #. It doesn't tell you about the option (it only tells you about 5 to change the password or to transfer to another ext. press *8)
Then press 3 for greetings and so on.
Aug 26, 2010 | Avaya Corded Phone avaparp18d
Callers are not getting transferred to voice mail when I can't answer my blackberry pearl 8100
This might happen's because the voice mail number in you're Handheld might be wrong, Please check with that.
If the number is correct you your call will be transfered to voice mail, If the voice mail number is wrong then you need to contact you're service provider.
To find the voice mail number follow the step's:-
1) Go to call log.
2) Press menu key.
3) Select Option's
4) Select voice mail.
I hope I was able to help you today.
Thank you for using Fixya.
Nov 01, 2009 | RIM BlackBerry Pearl 8100
AVAYA Phone System: Lucent Partner Mail
press feat 00. touch btn to program dial feat14. this is now a voice mail transfer button. to program an ext button, touch btn to program, press left intercom dial 2 digit extension. Can you dial 777 and get voice mail?
Aug 26, 2009 | Lucent PARTNER18 Corded Phone
Message light blinking. LCD has myext-voicemail#
I received a voice mail which seemed to correct the problem. Sort of the same solution as when an actual extension is displayed. (you connect/disconnect)
Jun 18, 2009 | Toshiba DKT2020SD Phone
Call Pilot voicemail Nortel
Depending what number your extensions start with, you need to go to the programming for the auto attendant and "undefine" the number in the menu. More than likely, it is built as a "thru-dial" and allows callers to punch in the extension. If you remove this, callers will have no other choice but to use the options in the menu. I can walk you through these changes if you want.
Apr 16, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
CAN'T TRANFER CALLERS TO VOICE MAIL
A Panasonic system and Pana branded voice mail has a VM Transfer key that lets you send a caller to voice mail. It's programmed by picking a button down the left side of the keystrip (CO) and pressing PROG, the button, 94+ the VM extension, and STORE. (In a TA-824 system it would be either 107 or 115).
The TRANSFER button would work if the extension has CF set (All Call or Busy/NoAnswer), but there would be a delay. At the very least, when you tried yours, you were either dialing the VM extension which is probably not vailid because it won't let you transfer to yourself, or an invalid extension.
Carl
Jan 27, 2009 | Panasonic KX-T7730 Corded Phone
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Delete old voice mail - program new voice mail
You can usually access the system voice mail setup from any extension.
Press Speaker
Dial ext 200.
When asked for security code, dial *,2,# (dial it twice if there is no code).
When main greeting begins, dial 632.
Using the soft keys under the display, press MORE, then MGR, then CHBX or, follow voice prompts if non-display phone.
Follow voice prompts. Remember, 1=Yes, 2=No.
Mar 10, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
378 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
