Question about Cameras
Nikon coolpix l1 not working with the memory card
Hi, just got this camera out of the box, and it works fine without a memory card. but when i put one in, and try to take a photo, the camera makes a bleeping noise and does nothing else. the memory card isn't locked, and none of the buttons work with the card in. the camera then goes onto standby, but the shutter release button doesn't work so i can't turn it off. Ive tried new batteries. Please help!
  • santanarose Jan 27, 2009
    Hi, it says in the manual SD (Secure Digital) and the one i have is SanDisk, but i thought that was an SD card?
    Hi, you're right, I just tried my friends 'Secure digital' memory card and it works fine! Thanks for your help and very quick response!! :D
    Brigadier General:
  • 5,158 Answers
I suspect that memory card is not compatable with the camera... if you have the manual check it to see... if you don't have the manual i'll find it for you
Robert
Please rate this solution thanks
Posted on Jan 27, 2009
My Nikon Coolpix L1110 whenever i turn it on with memory card the camera message THIS CARD CANNOT BE USED.. but without the memory it is find and ok.... I put the memory on my laptop and it is working all...
Don't be so quick blaming your camera for everything. :)
Maybe that message means the memory card is either full or nearly full.
When did it start saying that? Did you try another memory card in the camera?
Jun 20, 2011 | Nikon Coolpix L11 Digital Camera
When memory card is inserted a message apears on the screen saying this card cannot be used. the card is formated, unlocked and is working fine in my other nikon camera, please help. i cant even acess...
Hi , when you insert other memory card the error is still remains? If your answer is yes ,the camera needs to inicialize try to do this in camera menu without a card. Err remains after initialize contact Nikon service.
Greethings
Feb 17, 2011 | Nikon COOLPIX P100 Digital Camera
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Camera works with standard SD memory card, but not SDHC
There are hardware incompatibilities between SD and SDHC cards. They're upward compatible in that SDHC devices will accept SD cards but not the other way around. You will have to hunt down SD cards, 2GB and smaller.
Apr 28, 2010 | Nikon Coolpix L1 Digital Camera
Nikon Camera does not accept any memory card
Try formatting the card in the camera, not the computer.
Apr 14, 2009 | Nikon COOLPIX L4 Digital Camera
SDHC memory card
The L1 is an old camera, before the SDHC standard. There is no forward compatibility (SD devices can't use SDHC cards), only backward (SDHC devices can use SD cards).
The latest version of the firmware is available at http://support.nikontech.com/app/answers/detail/a_id/13783
That still won't let you use SDHC cards.
Dec 28, 2008 | Nikon Coolpix L1 Digital Camera
Memory Card Capacity for Nikon P4
you can put a 16 gig in without any trouble
Dec 20, 2008 | Nikon COOLPIX P4 Digital Camera
Sandisk memory card for nikon digital camera 6megapixals
It's Nikon's file system.
You must use cord/charger/station to access memory card.
Without it, your computer doesn't recognize it and ask you to format the card.
Mar 01, 2008 | Nikon COOLPIX S5 Digital Camera
Nikon coolpix 4100
I've heard the camera "STALLS" when any sd card larger than 256 is installed, how big is your card?
Feb 21, 2008 | Nikon Coolpix 4100 Digital Camera
No memory card will work in my Coolpix camera
Nikon has tested the following cards and approved their use in the Coolpix 3200:
SD memory cards:
SanDisk 16/32/64/128/256MB
Panasonic 16/32/64/128/256/512
Toshiba 16/32/64/128/256MB
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
Multi Media cards (MMC) are not recommended and should not be used.
Jan 23, 2008 | Nikon Coolpix 3200 Digital Camera
Cameras Logo
93 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
