Question about Jada Option D Kenworth T2000 Truck Trailer
KENWORTH T2000, WIPERS not spraying windshield wiper fluid
Windshield wipers were working and fluid was spraying. Windshield wipers still working but no fluid coming through. WHAT CAN IT BE?
  • Jacy Perry May 11, 2010
    check that the resivior is full. If it is then what makes it flow threw must be broken.
  • Bernie Thames
    Bernie Thames May 11, 2010
    Have you checked the fluid?
    Problem Solver:
  • 19 Answers
One of two problems i make sure the pump is working or the ends on the sprayers are pluged up if so take off and run a small pin in the hole to clean them
Posted on Aug 15, 2010
WINDSHIELD WIPER FLUID NOT SPRAYING
Check fuses or washer pump. .replace.
Jan 07, 2018 | Cars & Trucks
In my 2007 Saturn Vue there is what I think is an air pump which is cracked that one port is not connected to anything.
There is a electric motor that pumps washer fluid . Located in the bottom of the washer fluid tank .
Wash Operation (Front and Rear Wipers)
The front and rear washer systems use the same windshield washer fluid pump. When either the front or rear wiper is in the washer position voltage will be supplied to one side of the windshield washer fluid pump (depending on whether it is front or rear), while the other side of the pump is grounded.
At this point, the windshield washer fluid pump sprays solvent onto the windshield. When the front or rear washer is activated, the BCM receives an input from the switch that is activated. The BCM will control the wipers while in the WASH mode. The BCM will control either the front wiper relay or the rear wiper relay to turn on the wipers. The windshield wipers operate at low speed for 3 swipes and returns to the park position.
When turning on the washers do you hear the motor run ? Have some one try it while you listen at the washer fluid tank ! These pump motors do go bad .
turn OFF the ignition.
Disconnect the harness electrical connector of the windshield washer fluid pump.
Connect a test lamp from the windshield washer pump control circuit to a good ground .
Turn ON the ignition, with the engine OFF.
Press the front washer switch.
Does the test lamp illuminate?
YES or NO !
Nov 18, 2016 | Saturn Cars & Trucks
Windshield Solvent doesn't spray.Wipers work. I can blow air thru lines.But no spray..any suggestions? 1995 Chevy Luminia
Does the pump motor run when turn windshield spray?
Might be home in line.
Might be wrong fluid(too thick)
Might be wiper fluid motor broken.
Nov 03, 2016 | Cars & Trucks
My 2006 Dodge Dakota windshield washer fluid does not spray. I checked the washer pump and it works. The fuses are all good. And the wipers work. When I press the windshield washer button inside the truck...
If the pump works, something should be flowing thru the hose to the spray nozzles.
And if the pump works, everything electrical is working.
How do you know the pump works ?
Apr 14, 2013 | 2006 Dodge Dakota
Windshield wipers won't work after removing battery to get to the windshield wiper pump that squirts fluid to clean windshield
Sometimes disconnecting the battery does more damage then you want it might have trip a fuse or relay check those if thats not it, maybe wiper motor or transmission went out.
Nov 30, 2012 | 2005 Saturn VUE
My wiper will work but it will not spray washer fluid anymore. Any suggestions?
CHECK WIPER FLUID LEVEL FIRST ALL IS GOOD CHECK FOR POWER AT WIPER WASHER PUMP MOTOR.IF NO POWER AT WIPER WASHER MOTOR.CHECK 15 AMP FUSE IN THE ENGINE COMPARTMENT FUSE RELAY BOX.IF YES YOU ARE GETTING POWER AT WIPER WASHER MOTOR.WIPER WASHER MOTOR FAULTY.
Dec 31, 2010 | 2004 Chevrolet Suburban
Jada Option D Kenworth T2000 Truck Trailer Logo
840 people viewed this question
Top Jada Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Jada Toy Expert? Answer questions, earn points and help others
