Question about Dryers
Roper dryer rgd4440vq1 will not start
Will not start, makes no sound
TheMobilian
  • 8220 Answers
SOURCE: roper dryer
One of them drum wheels is bad.To get to it: Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Get the drum out and inspect the wheels.
Posted on Dec 31, 2008
  • 686 Answers
SOURCE: Roper gas dryer makes a loud humming sound when
motor going or gone bad
Posted on Feb 27, 2009
hunter19_46m
  • 7482 Answers
SOURCE: roper dryer will not tumble when start button is
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
Posted on May 14, 2010
The_lRipper
  • 116 Answers
SOURCE: My Roper Dryer REX4634KQ1 will not start. It makes
Your motor is locked down possibly somehting in the blower hoising and I have seen socks get past the drum and get wedged inbetween the motor shaft and belt tensnoir. Quickest way to find out remove the two top screws where the lint trap is then take a flat head and pop the lid up slide the flat head in between the slot where the top meets the front about a inch in from the right and then the left slide the top back. Then remove the two 5/16 bolts holding the front on then remove door switch wire it will be on the right and the only one there with a quick disconnect harness once done slide the front back a little and lift up on it till the bottom comes out of its hangers the drum will drop a little. Then look towards the back right of the dryer under the drum where the motor is if theres no sock or anything other material or item wedged there put the front back on the same way you took it off. Once done remove the back panel off the dryer if you can lay the hole dryer on its front it will make it easier also leave the two lint screws for the top out. Next look at the lower left of the dryer that is the blower housing remove the 4 or 5 1/4" screws or 5/16" screws once done you should be able to slide the housing up and away enough to see if there is something on the blade wedging it. If so remove the item reasemble the dryer will run fine as long as the motor didnt sit to long on when it got jammed if its still making the humm noise and not coming on you have a bad motor which will run $125 to $150. After all that and you find nothing jammiing it up you have a bad motor could be the bearing went bad with it but the hole motor will have to be replaced. Hope this helps and sorry for the troubles.
Posted on Jan 14, 2011
jyackle5
  • 8197 Answers
SOURCE: brand new roper dryer MOD
According to the roper site you may not change to LP gas yourself. You will need to get a licensed LP technician to make the conversion. The reason why is that they will need to adjust the flow of the Lp so that the dryer will work right. If you do not get a Lp technician to do the work then you will for fit the warranty on the Dryer.
Posted on May 28, 2011
Roper dryer makes a buzz sound then shuts off sounds like its trying to turn but does not what could this be
Might be something in the blower housing bogging down the motor. My home movie shows how to replace a belt and check for objects heat etc.
ROPER DRYER
Jul 31, 2012 | Roper Dryers
Brand new roper dryer MOD RGD4440VQ1, Its gas and has a LP fitting how to change the LP fitting to PRopane. I have the conversion kit but can't find out how to install it
May 28, 2011 | Roper Dryers
My Roper dryer suddenly won't start. Was running
Is it gas or elec?
Have you checked the breakers?
Does the outlet have power?
Model# ?
Try setting timer in a different cycle.
Make sure door is completely closed.
Push door switch in manually does it click?
Please update lat me know what else I can do to help.
Ken
Mar 17, 2010 | Roper Dryers
My Roper dryer worked fine until my basement flooded about 6 inches of water on floor. Now my dryer just hums when I try to start the dryer. The heat does come on. When I spin the drum and hold in the door...
It sounds like the motor was damaged in the flood. You may be able to salvage it by spraying both ends of the motor shaft with penetrating oil several times moving it in between, but you may not be able to salvage it.
Dec 30, 2009 | Roper REX4634KQ Electric Dryer
Loud noise when running
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
Apr 16, 2009 | Roper RGX4634KQ Gas Dryer
Roper gas dryer will not start
hi that sounds like a bad motor.
Jul 14, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
