Question about Toshiba Satellite X205-S9349 Notebook
Satellite won't power on all the way after over night charge
I got a used Toshiba satellite .and after formating the hdd and loading a new OS. it was all working fine.. then i left it to charge over night when i woke in the morning it had woke up all by its self but the only thing that was running was the cooling fans no lights no screen nothing but fans so i try pulling the power and runing just off the battery.. no go still wont work (JUST FANS) so i take out the battery and just plug it in ..same thing (JUST FANS) some one pleas help !!
Toshiba satellite pro a60 How can I use a ssd 128gb on this laptop
Exactly the same way as any other hdd. initialise it. Format it and load your OS.
Sep 30, 2015 | Computers & Internet
How to upgrade a toshiba L305 to a 500gb hard without hardware failure error
I'm a bit confused? You are trying to install a HDD with Windows 7 on it from another computer in a Toshiba L305 laptop? If that's correct, it will not work, first, you must format the 500GB SATA HDD, then load the Windows 7 OS to get a clean install. Clarify the question if I am incorrect.
Jul 03, 2013 | Toshiba Satellite L305-S5875 Notebook
After my toshiba laptop has been reformat, the manufacturer in the basic computer information has changed,it became PANASONIC. Why?
Have you formatted with the OS which came along with your laptop( pre loaded OS CD). I feel you have Formatted your laptop with PANASONIC OS CD.
Aug 07, 2012 | Toshiba 14.0" L745-s4235 Satellite Led...
Hi i am Syed Tarique Anwer,From Yamaha India,i having a Toshiba Laptop(Portege S100),there was some problem with OS ,so i formatted the HDD on diffrent system and reinstalled the HDD again in this...
It sounds like the HDD controller may be bad.When you thought it was the OS having a problem it sounds like the controller was going out.Unless the HDD you were connecting to it was bad.
Oct 24, 2010 | Toshiba Portege S100-S1133 Notebook
My Toshiba Satellite A105 laptop keeps hanging up. It locks the screen up and just stops working. It happens in different programs and really randomly. Control alt delete does not fix it. I use a hard...
Indeed it could be the hdd. I would backup all files that I couldn't afford to loss ASAP. Then, I would do a fresh reload of your choice of OS. Be sure to do the full format NOT the "Quick" format. This will allow the system to recognize any bad clusters that might be on that hdd.
Hope this helps.
Jan 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
Not letting me put new os system on new hard drive?
Start from scratch. format your HDD and re install the OS via recovery disc.
Hope this helps.
Dec 19, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Windows XP won't see C drive after formatting and erasing vista on Toshiba Satellite P200-AB1 laptop
I had a Toshy A25, not with that issue, but I did erase Malware infected Vista from an Acer Aspire. The system is locked to boot from the HDD, so it needs an OS, I formatted an easy swappable Windows 98 OS onto the HDD. I was told Linux will work too. Get the BIOS settings to allow boot from the system's own CD/DVD drive! That is key to new installs, and getting the drivers loaded like they should
Oct 07, 2009 | Computers & Internet
Not boot from factory CD -where is CMOS battery?
Appreciate the direct "Ask Me".
Based on your post/description:
  • Toshiba Satellite 1415-S173;
  • new HDD;
  • would install WinXP.
Your concerns are:
  • media/cable fault;
  • CMOS battery;
  • laptop battery.
  • will not complete format;
  • will not install OS (WinXP).
Proposed course of action and other ideas:
  1. double check the new HDD, verify that the pins are not bent and are seated correctly. If all else fails, return the new HDD and have it replaced;
  2. try partitioning/formatting the new HDD in another PC using a 2.5 IDE to USB external adapter;
  3. clean the lens of the DVD/CD ROM drive;
  4. remove the dead laptop battery and use only the AC power when installing;
  5. most current laptops do not use a CMOS battery;
  6. if you want to revert CMOS/BIOS settings to default, it could be done by pressing on ESC or F1 or as indicated in the display (depends on the version) and set all possible settings to default. Verify that it is set to boot from the CD drive.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 02, 2008 | Toshiba Satellite 1415-S173 Notebook
Computer Shut off after 20 to 30 seconds
Have you reloaded the HDD. If not backup your data and put the OS or orignal factory load. Corruption in the system file or bad HDD.
Jul 30, 2008 | Toshiba Satellite M45-S265 Notebook
Fail to load files during text mode setup
Maybe its a software problem, have you tried putting in a bootable XP installation CD? After the bios boot and it asks you to boot to CD, press R for repair, it will try to repair your OS, and if it is an OS problem ,then it will boot once again... If not you can try formatting your HDD and reinstalling windows...
Mar 10, 2008 | Toshiba Satellite A65-S126 Notebook
Open Questions:
Toshiba Satellite X205-S9349 Notebook Logo
249 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
