Question about Walkera QR Infra X Sensing Quad
QR Infra X Sensing Quad is flying backwards and in circles. The quad was flying great yesterday and now out of control. I am using the Devo 7 as the controller and it has been reset. The controller is not the issue its something to do with the quad itself. Any suggestions will be appreciated.
The starter on my cfmoto 500cc quad turns but does not turn the engine
If the battery is low then the gear on starter will not FLY in fast enough to turn the motor over
Jan 23, 2016 | ATVs
Instruction manual for Tagital® T7X 7 Quad Core Android 4.4 KitKat Tablet PC
Tagital® T7X 7" Quad Core Android 4.4 KitKat Tablet PC ...
www.amazon.com/Tagital®-T7X.../B00RLEKHVA
Amazon.com, Inc.
Rating: 3.6 - ‎132 reviews
Amazon.com : Tagital® T7X 7" Quad Core Android 4.4 KitKat Tablet PC, Bluetooth, Dual Camera, Play Store Pre-installed, 2015 Newest ... 1x User's Manual
Tagital® T7X 7" Quad Core Android 4.4 KitKat ... - YouTube
? 1:44
https://www.youtube.com/watch?v=bux7EbSlAKM
Aug 12, 2015 - Uploaded by Ritz Flash
4 GB Storage (Supports Micro SD card extension) Package: 1xTagital Android 4.4 Qual Core 7" Tablet 1x ...
Tagital® T7X 7? Quad Core Android 4.4 KitKat Ta
Jan 05, 2016 | Tablets & eReaders
My X350 will not power up
if you have multi tester check if there's a power output to the battery..or check battery connector....
Jun 02, 2014 | Walkera QR X350 Quadcopter BNF WALQRX350
Quad copter won't lift off ground
Maybe battery is not accepting charge. I would try using a new battery.
Apr 20, 2014 | Protocol Manta 4-Channel Radio-Controlled...
DV04 not recording video
I have the same problem. The video records on the SD Card (Kingston). It records for only 1-2 seconds then stops. The transmitter to the radio unit is fine as I can see it on the screen at all times. It is the recording function that is the problem.
Apr 03, 2014 | Walkera DV04 FPV Recording Video Camera
Estes quadcopter does not fly up; only left, right, back and foward
How old is the quad? Maybe the gear shafts are dragging. (Not spinning at full potential)
Jan 10, 2014 | Estes Dart Quad Copter RTF ESTE4605
Missing manual, batteries not charging, quad copter not taking off
Go to this page: http://www.helipal.com/faq.php
and scroll down to the technical FAQ and the Walkera FAQ
Feb 09, 2013 | Walkera QR Ladybird Z-02 Canopy
Disney princess quad will not go foward
the polarity is reversed, just switch the wires around on the motor
May 29, 2012 | Disney Toy Story 6-Volt Quad Ride-On
HAVE CODE 26--CHECK RESISTANCE ON INJECTORS, EGR SOLINOID & PURGE SOLINLID--REPLACE PCM. STILL HAVE SAME PROBLEM. CAN YOU HELP? LARRY
There's a lot of information regarding your problem here:
http://www.saturnfans.com/forums/showthread.php?t=284
My suggestion would be to contact a local dealer and have them run the diagnostic (usually under $100), then if the part is easily replaceable, do it yourself. If it's more involved, then bargain with the dealer on a good price to have the problem fixed.
I truly hope that the Quad Driver itself isn't what's causing the code.
Nov 02, 2009 | 1993 Saturn SL2
Walkera QR Infra X Sensing Quad Logo
26 people viewed this question
Top Walkera Toys Experts
Michael Galve
Michael Galve
aldwin weng
aldwin weng
Are you a Walkera Toy Expert? Answer questions, earn points and help others
