Question about Gateway 300 C PC Desktop
What does this mean?
What does a blue screen with this written mean?
self test G
sheck your pc and signal cable R
monitor is working B
does it mean my hard drive is dead?
    President:
  • Gateway Master
  • 1,314 Answers
No, that means either your video card or video cable is bad; most likely the video card. Assuming, of course, that the computer is turned on and seemingly running when you get that message. Basically it is telling you that the monitor is fine, it's just not receiving any input from your computer provided the computer is on. Thanks, and please take a moment to bive this solution a fixya rating. :c)
Posted on Jan 27, 2009
  • 3,940 Answers
It means that the monitor is not receiving a signal from the video card of the computer.
Possible failures are as follows:
1. The monitor input cable is no longer connecteds to the video casd.
2. The computer is not powering on
3. The video card has failed
4. The input Select option of the LCD is set wrong
When i plug up the L1975NW lcd monitor what should show up ?
"no input" means that there is no signal from computer or the monitor cable is unplugged. When you first turn on monitor it usually does a self test and then looks for signal. Not connected to PC will give a no signal. If it is connected but PC is off (not unplugged) then it should go into standby as you vid card will be sending a standby signal to any monitor connected. Sometimes the Plug and Play monitors need to register before it will recognize a standby signal from PC, so plug it up and boot up PC. Then shutdown normally, your monitor should go into standby when the PC shuts down.
Nov 11, 2013 | Westinghouse L1975NW Monitor
Screen monitor self diagnostics show
that means no incoming signal, but some problem i encountered related in vga cable and lost connection on ckt board. as long that the cpu is working and the monitor show (no signal) focus trouble shooting on that parts. replace cable if possible( same port configuration)
Apr 20, 2010 | Princeton Digital VL2018W Monitor
The screen is black and there is no charging. No
If the screen is black, itis always recommended taht you do a Monitor self test by unplugging the PC from the Monitor and turning on the Monitor.If the If we see that "Video cable unplugged/Check Video cable", that means the Monitor self test is passing.We need to t/s on the PC...We can open the tower and take out the RAMs and the BIOS battery and do a m/b self test..If we hear a beep sound from the m/b, that means the m/b is good.We can go ahead and reseat the video card(if any) on the m/b and check again..Hope this works.
Mar 19, 2010 | Lenovo ThinkPad R61i Laptop
Monitor is on but screen is black. green light for switching it off/on does not do anything when pressed
Your monitor power supply has several capacitors going bad. You’ll need to have these replaced by a reputable repair person or check my website www.micromendllc.com. Thanks
Mar 01, 2010 | Dell E173FP 17" LCD Monitor
My computer is showing a floting box which say self test feature check, wit red,green blue and white box.What do this mean
its showing u monitor self test feature screen issue either with the monitor cable or monitor or the graphic card
Nov 19, 2009 | Dell Dimension 2400 PC Desktop
Computer powers up, but monitor shows a self test
Your video output is bad. Either the video card, or the onboard video built into the computer. You need to swap out the card or add a card to bypass the built in video port on your computer.
Thanks and please take a moment to rate as fixya.
Feb 11, 2009 | Gateway 550GR PC Desktop
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
No signal on first boot
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
Gateway 300 C PC Desktop Logo
182 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
