Model 165DT Reddy Heater won't start
This heater has set all year and it had a mouse nest in the tube and when i turned it on it started a couple time and smoked like crazy, plus it burned up the mouse nest. But now it doe not want to start. each time I try tostart it all it does is shut right back off.
Buffalo12980
  • 625 Answers
SOURCE: reddy heater model 28725
propane heater uses a hot surface ignitor. this operates off 120 volts and glows red/orange when actuated. it stays lit throughout the heater on operation.  on the backplate of the combustion chamber is a high limit with two wires coming off it.  these two wires connect to the spade connectors on the flame detector cappillary.  Once you establish a fire, the flame detector generates a 750 millivolt signal which is applied to the pilot/main valve assembly.  My diagram will show this. 1fa8284.jpg
Posted on Oct 15, 2007
tbugger
  • 232 Answers
SOURCE: reddy heater won't start
The heater shuts off after 5 seconds because the photocell fails to see a correct flame, in your case any flame at all. That's the photocell's job.
What you are going to have to do is troubleshoot the unit to see if the problem is fuel related or electronics related.
Go to the ReddyParts.com website for troubleshooting tips. This is a good place to start.
http://reddyparts.com/pressure.htm
Posted on Feb 13, 2009
  • 9 Answers
SOURCE: Heater Burner ignites but main blower motor will not turn on.
it sound like the blower motor may be seizing up. try spining the blade by hand to see if it feels free or not. the motor could be trying to turn but can then tripping itself out on overload. (most motors have built in safety overloads which will trip during an overcurrant event. aka too many amps.) you may have to replace blower motor
Posted on Mar 22, 2009
  • 188 Answers
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Posted on Jan 28, 2010
heatman101
  • 43501 Answers
SOURCE: reddy heater runs too rich,starts smokeing and
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
Reddy heater runs but not consintently shuts down and have to restart it. model 165DT
Shuts down in 5 seconds? If so, it is supposed to. If the flame is not perfect. Read on..
The ignitor (glowbar) only glows for 5-7 seconds- just long enough to create combustion. Once the flame starts- the flame must keep itself going. So if at anytime the flame goes out- it stays out- there is nothing to restart it.
What most people don't realize is that the photocell is looking for a flame with perfect color, which means the heater is not emitting pollutants. If the flame runs too rich or too lean (polluting) the photocell shuts the unit down. No self re-start.
Start troubleshooting by setting the pump pressure. Pump pressure is directly related to fuel delivery. Poor fuel delivery equal poor flame equals shutdown.
Troubleshooting tips
Oct 25, 2011 | Heating & Cooling
Heater used once 3 yrs ago. Now wont start.
When the heater hums is the fan turning. If it is I would add more Kerosene. There is no shut off but the Kerosene is sucked out a tube from the top of the tank. This tube does not reach quite all the way to the bottom of the tank. Your heater should hold about 9 gallons if it is empty. A couple of gallons would give it plenty to run though. Let me know.
Jan 02, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
When plugged in the heater makes a noise like it may be trying to start but shuts off after about 5 sec. Heater has not run in several years
If it were mine- and the heater has been inactive for several years, I'd check for a rat's nest inside. If clear, it's time for some serious troubleshooting. Remove the top cover. Is the fan turning?
Oct 05, 2009 | Reddy R60A Utility Heater
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
