Question about Vehicle Parts & Accessories
Coolant system of 97 park ave - Vehicle Parts & Accessories
  • 427 Answers
Refer to manuel cooling system
Posted on Nov 08, 2013
1997 Buick park ave why is my coolant brown
It should be orange if it Dexcool. Which all aluminum head GM engines switched too. If typical (green) antifreeze is added to dexcool, it goes thru a reaction that will not let it flow thru the cooling system fast enough or properly which causes hot spots in the block and burns (cooks) the antifreeze. have the system flushed and refilled with the correct coolant and you engine will love ya for it
Feb 11, 2015 | 1997 Buick Park Avenue
Where is the fuel filter located on a 97 Buick park ave
The fuel filter is located under the hood on the passenger's side of the car. It is mounted to the frame rail near the lower engine area.
Read more : http://www.ehow.com/how_6715346_replace-park-avenue-fuel-filter.html
Aug 03, 2014 | 1997 Buick Park Avenue
97 Buick Park Ave. Non-Ultra. Mileage 200K. Was squeaking at morning cold start for about 5 to 10 min. Replaced Serpentine Belt, belt tensioner, alternator, and PCV Valve. STILL squeaking at cold start....
How's your engine coolant level? If you've got a water pump leaking coolant, your belt will squeak, as the pump will leak the coolant directly onto the belt. You'll see the spray pattern under the hood if it's been going on for a while.
Oct 18, 2013 | 1997 Buick Park Avenue
My engine on my 1998 buick park ave ultra sounds like it's revvin up when i have it in park
Clean your IAC.
FYI, you also could have a VACUUM LEAK
The Gen II 3800 Engines have a HORRIBLE ISSUE with the INTAKE. They are made from Plastic and Warp. Waiting for the Engine to Get Hydro Locked (Coolant in the Cylinders)
Apr 12, 2013 | 1998 Buick Park Avenue
96 park ave temp only gets 160 replaced stats twice
If the temp gauge is reading 160 when the engine is warmed up, the problem could be air in the cooling system, a faulty sending unit, or gauge.
Dec 09, 2012 | 1996 Buick Park Avenue
I can't find a diagram of the belt installation for my 97 Buick Park Avenue. Can you help?
I can help, a belt diagram for a 1997 park ave, some of these cars come with a super charger, heres a diagram that list both the regular belt and then the charger belt, use what is needed, hope this helps.cfccfd3.gif
Sep 09, 2010 | Buick Park Avenue Cars & Trucks
Oil mixing with coolant.Car is overheating, coolant is tan.Had radiator tested.It's not trans fluid.Oil level fine and no coolant in oil.Oil on top of heads look fine.Buick park ave 150,000 miles 1998...
If this is a 3800, Upper Intake Plenum or Lower intake gaskets are an inevitability. Head gaskets on these engines rarely go out! Seriously, don't get duped. I am doing the job on my grand prix right now. Google it for further explanation.
Jul 30, 2009 | 1998 Buick Park Avenue
Cd player
Chech the fuses quite possible 1 is blown
Apr 17, 2009 | 1997 Buick Park Avenue
32 things wrong with my baby!!!! 94 park ave
sounds like water damage to the control panel. also the things u listed are together on the same fuses check the fuse also.. if one goes out it can mess up more
Mar 28, 2009 | 1994 Buick Park Avenue
Vehicle Parts & Accessories Logo
23 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
