Question about Staples SPL770M Shredder
No auto shred need to hold button down Anyone know how to fix this problem ??
  • Ronald Hall
    Ronald Hall Jan 24, 2013
    Have two one works on auto and one does not. I can't see how to take the motor area off of the basket to see if I can locate the eye. Thanks for any help you might give me.
How do I fix my auto feed, which has stopped working?
Use a flashlight to examine the shredder from the top and look for a shred of paper blocking the slot. The shred may also be blocking the sensor. If you don't find anything, turn the shredder upside down to examine the shredding mechanism from the bottom.
Mar 05, 2015 | Staples SPL770M Shredder
My shredder is stuck in auto cool down mode. Can you help me figure out how to fix it?
Be patient it will cool down and the light will go out, and resume operating.
Feb 20, 2015 | Shredder Office Equipment & Supplies
Shredder is Wilson Jones 130 auto. I believe staff shredded to many sheets at one time. No no lights no power forwards or backwards. Is there a reset or fuse, can't find one
Oddly, my Wilson Jones 130 auto just did exactly the same thing. I'm the only one that uses it (that I know of) and one day it worked, the next it didn't. There is no paper stuck in it. There are no power lights, nothing works. Does anyone know the location of a reset button or something?
Jun 21, 2011 | Office Equipment & Supplies
A hair pin was put through our shredder by mistake and it became jammed. We cleared out the shredder and removed the hairpin however now the shredder does not operate. It will operate in reverse if you...
Yes small shredders don't like to shred metal.
You have probably blown the pcb inside the machine...would need to know make and model to provide further access for parts.
Aug 11, 2010 | Office Equipment & Supplies
The basket full light comes on even when the basket is empty. if you hold the shred button down it will shred as long as it is pressed
needs bag full retorfit kit available from fellowes if under warranty or we have the part for sale if not under warranty cooksmobileshred@bellsouth.net
Mar 19, 2010 | Fellowes Powershred 220CC Shredder
Runs in reverse, but no on auto.
check and see if there is a jam of paper inside the unit or around the sensors
Jul 20, 2009 | Royal 10X Shredder
Screw for my Waring PJE50 juicer to hold shredding disk
Try this link, sorry only just saw your message
http://www.nisbets.co.uk/products/ProductList.asp?TopGroupCode=C14&ParentGroupCode=S312&GroupCode=5573&page=3&ppc=
Feb 22, 2009 | Waring 6001 Commercial Juice Extractor
Disabling Auto Flash
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Nov 21, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Samsung 731N Auto Adjustment
Hold menu button for 5-6 sec.
Enable od disable this funnction.
Nov 18, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Staples SPL770M Shredder Logo
37 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
