Question about Whirlpool Refrigerators
Whirlpool ET21GK ice maker not making ice
Unsure if connection is right..turned off to check for leak in frig
  • 5 Answers
SOURCE: Whirlpool Ice Maker Won't release ice
Jetguy77,
I have a 1993 year (16 years old now) Whirlpool side-by-side with icemaker, Model ED22PW. I have had similar problems with the icemaker - water goes in, freezes, but ice does not eject from tray. It has happened to this unit 2 times since 1993. It turns out the problem is not the thermostat. It is the icemaker motor module. The icemaker has a small synchronous (clock) motor that rotates the ice ejector. When it goes bad, the ejector does not rotate, either because the module timer had failed or the motor itself has failed. The solution is to go to your nearest applinace parts dealer and by a new "icemaker motor module" for Whirlpool Model (your model here). Mine cost $58.85 the last time I replaced it in 2006. To install the new module, you will need to remove the icemaker from the refrigerator. Mine has 3 screws that attach it to the side. Also unplug the power & control cable. The water tube slides out when you pull the unit forward. When you get it out, it is then easy to remove the motor module and insert the new one. You may have to reset the timer on the module to get the tray to fill completely.
Posted on Jan 18, 2009
SOURCE: Leaking water under frig and ice-maker is not hooked up?
The problem you are experiencing is normally a blocked evaporator drain line. Whether you have a side by side model or a top mount freezer the solution is relatively the same. Most top mount freezer models have a rear evaporator panel covering the aluminum evaporator coils. There are some instances where the evaporator coils are on the floor. These instructions are for top mount freezers where the rear freezer panel covers the evaporator coils. First of all, if there is an ice maker in your unit, this will have to be removed. Normally there are two screws which can be loosened and the body of the ice maker can be lifted off the screws leaving only a plug in harness to disconnect. Remove the harness either from the plug at the left wall or rear of the freezer and set it to the side. Next, remove all the screws securing the rear panel. Remove the rear panel exposing the aluminum evaporator coils. Be careful not to damage these coils as they contain the freon that cools your refrigerator. If you look closely underneath these coils, there will be ice from frozen defrosted water. Using a hair dryer and not a heat gun, melt all the ice and sop up the water with a towel. Now you will see a drain hole which is normally still blocked with ice. Pour hot water in this hole and sop it up. Keep doing this until you pour water down the hole and it drains into the evaporator drain pan either under or behind your refrigerator. Once you have unblocked this drain line, reassemble and plug the refrigerator back in. Set all controls to the middle settings and within 24 hours, your unit will be functioning correctly once again. If you need further assistance, we are here. Eric Campion
Posted on Feb 20, 2009
tborn6
  • 700 Answers
SOURCE: WE have replaced our ice maker in our Whirlpool
If the fill tube gets choked up with ice, (Figure S-4) it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut.
Posted on Apr 04, 2009
  • 531 Answers
SOURCE: Water spurts/leaks from below frig when ice maker starts its cycle.
yes
Posted on Apr 05, 2009
SOURCE: leaking water on floor only happens when making ice
I wonder if you just notice the noise now because the leak has you more aware? First things first. Lift up the arm on the ice maker (a few hours prior to attempting service) to stop it's operation. You need to roll the unit forward to give you access to the back. You'll see a plastic tube that runs from the bottom compartment (water valve) to the ice maker fill tube. Lower the arm of the ice maker and observe the plastic tube for the location of the leak. The most likely spot would be at the top. A hose clamp can be put on the fill tube after making sure the plastic supply tube is completely inserted into the fill tube. The fill tube is the piece that goes through the rear bulkhead and delivers the water to the icemaker. It may be neccessary to remove the icemaker to thaw out the fill tube using a hair dryer.
Posted on Apr 28, 2009
We recently had a water supply connected to our Whirlpool refrigerator model GB2FHDXWB02. After ~ 18 hours no water has entered the ice maker? What is the problem? Can I manually initiate water going into...
Make sure you actually turn the icemaker on, there is a arm that you have to trip in side that will activate the solenoid that make water enter the ice marker. Also keep in mind that the air in the line has to work out so give it 24 hours to make it to the ice maker. You should see the hose in the back of the frig, that runs from the solenoid to the ice maker. Also check the ice maker itself to make sure it is plugged in completely. Good luck
Jan 09, 2015 | Whirlpool Refrigerators
Whirlpool ET21GK Ice maker not filling
fill tube might be frozen at icemaker .
Oct 14, 2013 | Refrigerators
Whirlpool side by side frig, model #: ED2JHGXRBO2, serial #: ST2854810. We have had this frig for several years and almost from the get go when you open the right side door, the door gets so far and always...
I own a whirlpool fridge (side by side) model # ed2jhgxrt02. with a problem with the ice maker. the water is not being delivered to the ice makers. it seems that the switch to turn on the water to flow is not making contact. any suggestions?
Jan 04, 2011 | Whirlpool Refrigerators
I think my Whirlpool French door (freezer on bottom) is leaking underneath. I have checked the water lines on the outside and looked underneath and nothing. When I moved the fridge there was a film of...
check to make sure that the condensation pan is in its correct position,, somtimes when the unit is moved up steps it causes the pan to sit in there cocked or unlevel and will drain out excessively. or it may be a crack on the fill valve solinod where the water line connects to the fridge.. there will be a blue plasitc cover right where the water line connects to the frig and somtimes they crack and will only leak when the ice maker calls for water... pull out the frig and empty the ice tray and when you here it start to fill up the icemaker check around that solinoed be sure to use a bright flash light because sometimes the leak will be a little stream of water that is really hard to see sometimes you can only feel it with your fingers...I hope this helps......
Nov 11, 2009 | Whirlpool GX5FHDXT French Door...
How can I stop the ice maker on a whirlpool side by side frig? I do not have the water line connected but the ice maker valve is making noise.
just turn the IM off. its either going to have a metal hanger looking thing hanging on side of it, or an off button on IM
Nov 04, 2009 | Washing Machines
Model GD5PHAXLB01 Ice Maker
Probably the dual valve (solenoid) is leaking and overflood the ice maker.
Sep 24, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker makes hollow ice cubs or cubes with
Whats happening is the ice isnt freezing all the way. Try cleaning your condensor's under the frig.In Hotter weather when condensor's get filled with dust it causes the frig to cycle to ofeten. In turn your cubes aren't freezing all the way.
Jun 26, 2009 | Whirlpool Refrigerators
Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
Whirlpool ED5LHAXMB11 Refrigerator side by side
check your module itself on the ice maker make sure the plactic piece that turn the motor is not broke off if you can move the injector blades up and down without force that could be your issue to check you ice make sensor open the freezer and push the light switch 3 times you should get a solid red light where you can turn your ice maker on or off if that is not solid it is the computer chips that are in the freezer liner if all that checks then replace the water valve
Mar 11, 2008 | Whirlpool GS6NBEXR Side by Side...
My ice maker is leaking and would not stop making ice.
MAKE SURE THAT THE WATER SUPPLY SOLENOID VALVE IS NOT STUCK OPEN BY DEBRE. AS FOR THE HAIR DRIER ??? THERE IS A LIMIT T-STAT THAT PREVENTS THE ICE-CUBE MAKER HEATER WIRES OR PLATE FROM OVER HEATING. MAKE SURE TO LET THE IT COOL-OFF TO RE-SET THE SAFTY SWITCH. YOU CAN CHECK TO SEE IF SOLENOID IS ENERGIZED BY PLACING A METAL BUTTER KNIFE CLOSE TO THE TOP OF THE SOLENOID... YOU SHOULD FEEL THE MAGNETIC PULL FROM THE SOLENOID. ALWAYS MAKE SURE THAT YOU HAVE ADEQUATE WATER GOING INTO AND OUT OF THE WATER SOLENOID VALVE ... USUALLY LOCATED BEHIND THE FRIG WHERE THE ICE MAKER IS LOCATED.
Apr 21, 2007 | Whirlpool GD5SHAX Side by Side...
Refrigerators Logo
66 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
