Question about Canon PIXMA MP530 All-In-One InkJet Printer
Can't receive faxes directly to my PC using Canon Pixma MX850
I just got a new all in one: the Canon Pixma MX 850. It is connected to my PC via a USB 2.0. I can fax from my PC without having to go thru a paper print first, but can't receive on my PC directly (ie onto the Pixma in an electronic file and transfer this file onto the PC). As one is albe to scan using the Pixma and save those documents onto the PC - I think one should be able to do the same with fax?
Thanks for your help.
Yevgeni
  • yevgeni_altm Jan 28, 2009
    I have installed Fax Services within Windows. The problem is that faxes that are received on the Pixma can't be downloaded onto the PC in ANY format. I believe this maybe an industry-wide problem. Is anyone else able to get their PC to read faxes received by their multi-purpose unit?
I know this is a very old post, but I happen to notice on the Canon website while searching for my answers that an Mx850 does not have the capability to upload faxes to the computer.
Hope this helps!
Posted on Feb 23, 2012
    Problem Solver:
  • 4 Answers
If you did not install Fax Services within Windows it will not allow you to receive faxes unless your have other SW that came from the factory with your machine.
Posted on Jan 27, 2009
I need a service manual for my canon pixma mx850
It's hard to find free service manual but you can get MX850 Service Manual here and Parts Catalog here!
Sep 11, 2013 | Canon PIXMA MX850 Multifunction Printer
Canon mx 850 problem is when the copy button is pushed to make a black and white copy the printer acts as if it is printng color. Prints very slowly. Phil
I do not know the Canon MX 850 but it seems like your printer is set to default to high quality printing. Check the setting in your Canon software for something like this.
Aug 23, 2011 | Canon PIXMA MX850 Multifunction Printer
I have a Cannon MX 850 all in one. My Fax is not sending upon receiving the fax signal from a long distant account. The number rings through, the signal begins, it rings once then stops. The local fax's...
REREINSTALL VIA A WIRELESS CONNECTION FIRST THEN ATTEMPT TO REFAX
Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
Jan 25, 2011 | Canon PIXMA MX850 Multifunction Printer
Mx 850 gives error code 6A00 . We have purchased
6A00 means the purge unit is not cycling properly. If the printhead can come out of the right corner, you check there for paper scraps. If it's stuck on the right with this error you will need a shop to take apart and see if you need a new purge assembly. The part cost is only around $20.00
Feb 22, 2010 | Canon PIXMA MX850 Multifunction Printer
Computer says Orinter is Offline but is connected. Has the Fax button highlighted. Only have Copy, Fax, Scan, Memory Card to select from, which one should be highlighted for printing from connected PC
In order to print from PC you should choose COPY function. To check the connection between PC and your printer perform these steps:
  • Right click on printer driver name (Canon PIXMA MX 850 in this case)
  • Choose Properties
  • Click on Maintenance tab
  • Click View Printer Status: the status should ONLINE in order to print or scan
If still Offline,please recheck USB cable,reinstal it,or compare with another cable.
Source: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MX850 Multifunction Printer
Cannot find fax receive code for Pixma MX850
might be you have refill the cartridge. and u have to purchase a new one
Jul 27, 2009 | Canon PIXMA MX850 Multifunction Printer
Mx 850 canon with reoccurring error of 6010 or 6000
if it's 6A00 then theres a problem with the cleaning unit where the printhead parks. Look for any paper scraps in that area, 6000 is a paper feed error saying something may have fallen in stopping the paper transport roller.
Jul 23, 2009 | Canon PIXMA MX850 Multifunction Printer
Hi I am trying to install this printer. My cd-drive doesn't work, so I am trying to find the setup software online. can you help?
the link below will point you to Canon's download center for Pixma MX-850, just click on it and select your operating system to download the setup software of your printer. Goodluck, hope this helps
Canon Pixma MX850 Software Download
if you have other questions just lemme know
Dec 06, 2008 | Canon PIXMA MX850 Multifunction Printer
Canon pixma mx 300 won't send or receive fax
Dear friend,
it's very important to connect your MX 300 with the telephone line the right way! Please read once more the part "Preparing the machine for fax" in the chapter "Faxing" of the MX 300 User's Guide and mind the hint "Important: Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A). The machine may not operate properly."
Greetings from Cologne (Germany) to the UK!
Dec 02, 2008 | Canon MX300 Office All-In-One Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
870 people viewed this question
old marine
old marine
