Question about D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842)
DI624 will not work. All 4 LAN lights permanantly on with no cables connected
Lost internet connection. Noticed all light on lan cable ports on permanently with no cables connected. tried reser, no good. Has the router failed completly? It is about 5 years old.
  • D-Link Master
  • 32,281 Answers
Yes it could be faulty, especially if it the router is not protected with a surge protection power board.
Posted on Jan 23, 2013
  • 287 Answers
SOURCE: LAN led light alway on and flashing
Reset the router:
While the router is powered on press and hold the reset button for 5-10 sec. Release the button and wait until the router boots up (1 min).
If this does not work then you can try this
Try setting it into recovery mode and loading firmware:
Unplug power cable from the router and press the reset button. While holding the reset button plug the power cable in. Continue holding the reset button untill you will see LEDs on the router flashing rapidly.
You should be able to log into the router - you will see a prompt to load firmware. The firmware is available on our WEB site: http://www.dlink.com.au/tech/
Note - suggest you d/l the firmware BEFORE you reset router
Posted on Jul 06, 2008
SOURCE: I have a 2640b router failure
I think that u need to go on, open your internet explorer, and enter your ip address in the address bar. Enter your password. Check your settings. Sometimes, internet stops, because firmware needs to be updated, sometimes its your computers driver (this is not likely); but most likely, your best option is to update the firmware for it. Consult your manual or internet on how to do it.
Posted on Jan 06, 2009
  • 49 Answers
SOURCE: D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Posted on Jan 10, 2009
  • 31 Answers
SOURCE: D-Link DSA-3200 Gateway/Router and Access Points
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
Posted on Mar 14, 2009
  • 10406 Answers
SOURCE: I have a DIR-615 router
You could pay a qualified technician $50 for one hour of "trouble-shooting",
and then be told that it's not fixable,
or you could skip that step, and just pay $50 to buy a replacement.
Contact D-Link; if the device is still under warranty, they will replace it, at minimal cost to you.
Posted on Dec 06, 2010
Belkin F5U307 Hub suddenly doesnot work on my Macbook
The lights (link light) on the hub indicate the LAN cable from the computer to the hub is connected and working.Disconnect the cable fron the hub and the computer then connect the Lan cable to the computer first and the other end of the LAN cable to the hub anf the link light for that LAN port on the hub should light up. If not the LAN cable could be faulty then try a different LAN cable.
NEXT
Try turning off the power to the hub for 30 secs, reconnect the power and check the LED lights. If this does not fix the problem then it appears the hub is faulty.
Apr 20, 2012 | Apple Computers & Internet
No internet or lan lights on? Tried reset, hard reset. All other lights, power, wireless, router are on and green. No lights on internet and lan connection. I have tried another wireless router and have no...
The LAN lights will only turn on once you have an Ethernet cable connected to it and the other end of the cable is connected to a working computer.
If you already have a computer connected to the Ethernet port of the router via an Ethernet cable and the lights are still off. Check if the computer you have connected recognizes a network via LAN.
If the lights on the router are still off and the computer doesn't recognize a network then that means that the port for the ethernet of your Router is bad and sadly there's no way of getting that fixed but to have the router replaced.
Otherwise if the lights are off and the computer recognizes the Network and lets you connect to the internet or other computers on the same network then its just the LED of the LAN light that's broken and I think you can live with that.
Hope this helps!
Jul 18, 2011 | Buffalo Technology AirStation Nfiniti...
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
I have cable internet and how would i connect the DGL-4500 wireless router to cable???
Turn the cable-modem off.
Turn the router off.
Use an Ethernet cable to connect the network-port on the cable-modem to the 'WAN' or 'Internet' port on the router.
Use another Ethernet cable to connect the network-port on your computer to one of the 4 'LAN' ports on the router.
Turn the cable-modem on.
Wait for its lights to settle-down to a repeatable pattern.
Turn the router on.
On your computer, you should have Internet access.
Feb 21, 2011 | D-Link DGL-4500 Wireless Router
The wireless internet connection wont work. we previously had a wireless connection and now it wont register. we lost the connection completely and it doesnt show up on the list of internet connections....
Try turning off the router for 30 secs, then power it up again.
Then try connecting a LAN cable from the computer to the router and see if you can connect to the Internet.
If you can connect to the Internet then -
With the LAN cable open a browser and type in the configuration URL and check the Wireless settings, then check and/or the wireless card settings (it should have the router's SSID and encryption settings etc.)
Also install the latest wireless card driver.
Then test the wireless and Internet connection. If this doesn't work -
Next connect the computer with a LAN cable to the cable or DSL modem to see if you can connect to the Internet.
If you cannot get an Internet connection with the LAN cable, contact your ISP and get them to test the connection to your modem.
If the modem and Internet is OK and you still cannot get a wireless connection then the problem could be a faulty wireless router.
Dec 25, 2009 | Dell TrueMobile 2300 Wireless Router...
Router cannot connect to the internet
I assume you are following my instructions.
Did you connect the LAN cable from the DSL or cable modem to the WAN or Internet port on the wireless router?
To test if the modem is working properly, connect the LAN cable from the modem to the LAN network card on a computer and see if you can access the Internet.
If if doesn't connect to the Internet, contact your ISP and they can check the connection to your modem to determine if it is working properly.
Dec 03, 2009 | Linksys WRH54G Wireless Router
I have a cisco linksys wrt54g2 v1 that I have hooked up to my verizon dsl modem. My computer says I am connected but it wont let me get on the internet. If I plug the ethernet cable from the modem to my...
Connect the cable from the LAN port on the DSL modem to any of the 4- LAN ports on the Linksys Swicth (not the port Labelled Internet), then from any of the remaining 4 ports then connect your computer. Also try using a cross-over cable to modem from the DSL LAN port to the Linksys.
Oct 24, 2009 | Linksys Wireless-G WRT54G Router
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
Linksys Wireless-G BroadBand Router
Who is your ISP (Internet Service Provider)?
If you're using a Cable provider, do the ff. steps. (For Linksys router)
1. Launch Internet Explorer and type http://192.168.1.1
2. It will prompt you for username and password. Leave it blank on username and type admin for the password.
3. Under SETUP tab, click the sub-tab MAC Address Clone. The click the button Clone My PC's MAC. Then click on Save Settings.
4. Unplug the power to the modem and the router for 30 secs. After that, power on the modem first, wait for all lights to go solid then power on the router. Check if the internet works.
Hope this helps.
Jul 19, 2008 | Linksys Wireless-G Broadband Router
D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Logo
35 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
