Question about Kenmore 22422 Top Load Washer
Loose cabinet Is there a trick to popping the clips?
  • ihilanifarms Jan 29, 2009
    rumorbill's solution is for an older model Kenmore i think where the clips are in front. clight16's solution got the job done. Thanks everyone!!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 544 Answers
You could try to use a 1 -1/2 inch stiff putty knife.
Posted on Jan 28, 2009
  • 130 Answers
KInd of, just use a screw driver and put it under the loop. pry it up and they should pop free
Wondering how to get the door panel off so i can replace the motor for the window
they sell a door panel tool , but i usually just use caution and a small flat screwdriver. locate any screws on the door panel ( usually there;s a few around the door handles, and possibly some near the armrests. ( take them out first) then remove the handles. use the screwdriver and gently push it behind the door panel and feel around for the door panel clips. they are generally button styled press in plastic pieces that can be worked loose by using leverage and the screwdriver,be carefull not to pull too had on the door panel Causing it to crack in half / But generally the door panel can take some abuse= the door clips will be in several spots around the door panel, ( they slip in the back of the door panel and pop into holes in the door) and normally pop loose easy.the trick is to get the plastic door panel clips to pop out of the door holes / not the door panel slots= reinstall in reverse order,
Jul 31, 2010 | 1999 Buick Park Avenue
Any advice or tricks to removing the top of my Kenmore Dryer for belt installation? I've already removed the control console. there seems to be some sort of clip I need to figure out. Kenmore...
on front side of cabinet between top and front, in that seam about 2 inches in from each side is a clip.  i use a paint scraper to wedge in there on each one and it will pop open for you.
Jul 30, 2010 | Kenmore Dryers
How do i remove and replace window winder to change the lock on my 96 golf cabrio
pull a ra out of the tool box wrap it around the handle near door pull it back and forth in the groove by boor skin ther are somtimes washers at door check witch side the clip is on then placerag on clip do a 360 degree sweep clip will pop watch your eyes and follow that clip if you loose it got to scrap and do same trick or buy new from dealer or auto zone
Jan 15, 2010 | 1998 Volkswagen Jetta
Need help to remove water pump on a kitchen aid washing machine kaws777
Hello Friend, It's easy to replace the pump on your machine. First, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, you can easily remove the pump by snapping off the two spring clips. The pump will slide right off the motor shaft. Happy to help, Tim.
Jun 25, 2009 | KitchenAid KAWS850LE Top Load Washer
How do I get the top to pop open? I thought you just stick a screw driver in and pop it up but its not working?
The old ones used to be like that but these newer models are built to remove the cabinet. How do they do it? They pop the control panelup and release clips holding the cabinet to the base then the case/cabinet is easily removed.
READ MORE/WITH PICTURES
Jun 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Hood latch disconnected
small plastic tie straps will do the trick
Jun 02, 2009 | 2005 Hyundai Elantra
Machine does not spin...makes a noise
your drive coupler is most likely broken.It is located between the motor and transmission.very easy fix.you will need to take the screws from the face of the machine out and lift the face .make sure to unplug.their are 2 gold clamps that hold your cabinet in place.take screw driver and pop clips out.pull your lid switch connection loose and pull cabinet off.you will see your pump in front bottom of machine.remove clamps that hold pump in place then remove the power clip from your motor.remove 2 clamps that hold motor in place and your drive coupler is their.it will be 2 white plastic pieces and a black rubber piece in center of 2.check if teeth are broke or if craked.
Mar 07, 2009 | Kenmore Washing Machines
Loose cabinet
take the screws off the control panel, then pop the 2 clips. cabinet will pull off. then put the front lip under the lower brace and lower it back onto frame. once you get it lined up snaps the clips back in place
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Model lat9557aae: how does the front of the cabinet reassemble - the clips (at the top) popped off, when I opened it, before i could see how they were oriented and anchored.
Go to searspartsdirect.com and type in the model number you provided. Look under the "Cabinet" heading at item number 5. The clips should be placed in the openings at the top of the front panel as shown. It may take a little effort to reinsert them. This is a common problem sometimes when opening the top panel. I do not know how you opened the front panel, but for future reference, insert a putty knife at the point of the clips and push in to release the top panel. This may prevent them from coming loose. If the clips are damaged and you wish to order new ones, the part number is 22001650 and is sold as a set of two. If you have questions, or require additional assistance please let me know. I hope this helps you.
Jan 23, 2009 | Washing Machines
Cant get the back panel off the washing machine
If it is a top loading washer the cabinet itself is actually removed from the back panel and base frame.
1. Remove two trim caps on either side of the control panel, they are just plastic, and clip in place, either remove by hand, or if they don't come right away you can pop them off with a flat blade screwdriver.
2. Remove two screws (now visible with trim removal) that secure the panel to the cabinet.
3. Panel should now be able to pull up and out, flip it back on it's hinges.
4. Disconnect the wire harness from the lid switch connector, this should be the only place (on most models) where wires connect from the control panel to the cabinet top.
5. Remove the two gold clips that secure the cabinet to the rear panel of washer, they snap into the cabinet, and should pop out easily with a flat screwdriver, this can be difficult to figure out which way to go with the screwdriver, the best I can describe it would be to slide the blade of the screwdriver into the front of the clip (about 2 inches below the cabinet top) and then press the screwdriver back over the top of the clip for leverage. It should pop right out.
6. With the clips removed, you should now be able to simply tip the cabinet towards yourself and pull it right off of the frame. The washers "guts" should all be accessible now.
Hope that helps.
Sep 14, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
19 people viewed this question
Sal De
fordexpert
Robert Rankin
