Question about Icom IC-756PRO Transceiver 002896
Icom 756pro power switch not powering down
Will not turn off with power switch
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
You seem to have a bit of a problem here, but do not fear.
May I suggest the following: join yahoo group specific to your radio Make/Model, where you will receive expert info from professional people in the field. Plus you can down load manuals, diagrams and software, just to name a few things, freely.
I hope this will help you.
Best regards,
Peter
Posted on Mar 05, 2013
How come my icom 756 pro did not transmitting on 8000 frequency
You have to modify this radio to operate outside of the HAM bands. You will likely find the modification at www.mods.dk. This is a pretty common and easy modification for HAM radios. Your performance may not be as good as in the HAM bands.
You do this MOD at your own risk. If you are not licensed for operation on ANY frequency or band, you are not legally allowed to transmit. Heavy fines may be levied against you.
Jul 14, 2016 | Icom IC-756PRO Transceiver 002896
No prob on 20mtrs but on 40mtrs no power out using rtty setting
check antenna connection and power output of your radio.
Aug 31, 2015 | Icom IC-756PRO Transceiver 002896
I have a IC-756pro and the cat system won't work? Is it something easy to fix or only the factery
Icom radios are particularly problematic for HRD. I would urge you to read the instructions here. http://www.ham-radio-deluxe.com/hrdrigcontrol.pdf There are special instructions for Icom radios.
Dec 09, 2014 | Icom Ic-756pro Hf Transceiver Service...
Why my icom 2200h is getting hot even if i did not used it and when the power is off?
Check your wiring , you may have reversed the power suply with the stan by wires. They are both same polarity, hoever the power goes to fuse and control panel and the standby gos to baterie.
Sep 17, 2014 | Icom Ic 2200h Vhf Mobile Two Way Radio...
Icom IC-A210 wont turn on
Need to check your input power lines for any voltage applied. And also need to ensure it is properly grounded.
http://www.icom.co.jp/world/support/download/manual/pdf/IC-A210_Inst_4.pdf
Jan 06, 2014 | Icom IC-A210 Panel Mount COMM Transceiver
My icom 706 mk2g transmits on VHF uhf but not on HF whats the possible problem
My icom 706mk2g does no give me hf power on the hf bands but on uhf is working wel.
On the s meter the last blok is turn on.
Reseiver is working wel.
Wat can it be?? Transistor Finals broken???
The two srfj?
May 19, 2013 | Icom IC-706MKIIG
756 pro no signal for a while then comes on
To help you resolve this issue, the best advice I can give is to: join yahoo group specific to your radio Make/Model, the team there will help you with expert advice and info, plus you can download goodies for your radio, all is free.
I hope I have assisted you.
Best regards,
Peter
Aug 13, 2012 | Icom IC-756PRO Transceiver 002896
I have a icom ic-r5 scanner that will not start
Check the battery contacts. Sometimes there may be corrosion on them from old batteries. You can also check the contacts that connect the logic board to the battery contacts. There are two small Philips screws in the battery compartment. Remove them and the back cover comes off. You can check the contacts on the inside of the back cover and see where they make contact with the logic board. Make sure all contacts are free of corrosion. If it still will not power up. try a CPU reset. While holding down [FUNC] and [V/M], turn the power ON to reset the CPU.
Nov 02, 2010 | Icom IC-R5 Handheld Scanner
Why wont my R10 work on battery power? The batterys are brand new? It works fine if i use the wall wart? How do u modify it to remove the cell block?
The manual for your Icom R10 can be downloaded here:
http://www.rigpix.com/icom/icr10_manual.pdf
Pay particular attention to pages 7 & 8, as they deal specifically with NiCad & Alkaline battery usage and the charge switch.
The modifications available for te Icom R10 can be downloaded here for free (registration is required):
http://www.mods.dk/index.php?ModelId=350&RadioRec=icom
Sep 29, 2009 | Icom IC-R10 Handheld Scanner
Icom IC-756PRO Transceiver 002896 Logo
Top Icom Radio Communications Experts
peter0911
Steve
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
