Seagate 9y1682-540 won't install driver automaticaly
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Posted on Jan 23, 2013
Seagate Freeagent external Hard drive won't increase free space when files are deleted?
How are you deleting the files? If you're simply moving them to the trashcan/recycle bin then they're still taking space on your drive. Try emptying the trashcan/recycle bin.
Mar 21, 2013 | Seagate FreeAgent Computers & Internet
Seagate expansion portable drive won't post makes clicking noise
Very likely the head is no longer aligned, and can no read the disc correctly. This is physical damage that can not be repaired. There are specialist, but at premium prices.
Oct 20, 2012 | Seagate Expansion 500GB External USB 2.0...
My seagate free agent 320gb hard drive won't power on
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jun 19, 2012 | Seagate FreeAgent Pro Desktop - 320GB -...
Seagate 9sd2a3-500 320 GB Problem
Improve the Fixya experience for everyone by voting!
It sounds as though you have one of the following problems:
  1. Dirty contacts that can be cleaned with CRC electronic component cleaner;
  2. A faulty drive that may have been dropped at some point in time. Your drive may have a three-year warranty and Seagate will replace it. Just go online and provide the serial number; and.
  3. You may have to reinstall the drivers. The Seagate website can provide this if needed.
Apr 14, 2012 | Seagate 320GB Portable External Drive ...
I won a Seagate ST30000CB, Part # 9Y7865-560 Serial # 5QF3J7W7 and need get Seagate Disc Utility CD. How and where can i get same or how can I download ?
I'm not sure what Seagate Disk Utility is, do you mean SeaTools? That can be downloaded from the seagate website (also includes installation download). As for the disk Utility, what are you trying to do with it, or what do you need it for? If you give me some details I can suggest a program which might solve your problem. Also be sure to include your operating system name and version (IE Windows 3.1). Thanks!
Sep 12, 2011 | Seagate FreeAgent GoFlex 750 GB USB 20...
After adding my Go Flex Pro to my Mac the computer froze up and won't allow me to do anything. I can't get on anything. Was wondering what to do?????
Dear Vic, didyou try to reboot the Mac? Disconnect the drive and reboot. If that works tryto plug the drive again. If the Mac doesn't freeze try these next steps: There's a 3step solution for your problem: 1. Download this software from Seagate:http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-mac-install-software&vgnextoid=77002a... 2. If this software cannot create alink or communicate with the device, turn off your Mac and if you have anavailable pc try with it. If the drive works at the PC, Then is a compatibilty issue
3. Seagate report some compatibility problemswith this drive. If it is under warranty, ask for reimburse and choose anexternal HDD that has firewire 400, if your Mac is a recent model (2010-2011)you can buy an external drive with 800 firewire. If have doubt about the firewire option, lookfor about this Mac button and then press more info button, there you will findthat information.
Aug 01, 2011 | Seagate FreeAgent GoFlex Home 2TB...
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Computers & Internet Logo
337 people viewed this question
David Payne
David Payne
