Question about Whirlpool LGR7646E Dryer
Whirlpool Gas Dryer LGR7646JQ1 Auto Setting Does Not work
Hello All,
I have a Whirlpool Gas Dryer LGR7646JQ1 and when set to auto the timer wont advance and it does not heat up, it just sits there and runs. When set in the timed mode the dryer works perfect. I replaced the 4 wire thermostat on the exhaust and this did not help. I also cleaned the vent but no help. Any ideas?
Thanks,
Bryan
  • dhdingfelder Feb 02, 2009
    I have the same problem with my whirlpool LGR5620KQ1 gas dryer. When on auto, the timer doesn't advance and the cloth's do not get dry. It seems to work fine when set to the timer mode.
    President:
  • 1,214 Answers
I am thinking the timer has gone bad, They tend to work in some spots, and not others , when they fail. If you can put the dryer in Auto mode, then nudge the timer until you hear the burner light, see if it continues from there. If it does, chances are pretty good it's the timer.
Posted on Jan 27, 2009
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
Whirlpool gas dryer (WGD9450WR1) not drying on auto-cycles
try cleaning the 2 silver senser bars located inside the dryer drum on the door side with isopropyl alcohol and lint free wipes,these bars sense moisture and control timer speed,and when they get coated with the chemicals in dryer sheets they become coated and can no longer sense the damp clothes (these sensers use capacitance to sense moisture)
Feb 18, 2012 | Dryers
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
Mar 26, 2009 | Whirlpool Dryers
Gas Dryer runs non-stop.
Repairing a dryer that won't shut off many seem daunting, but fixing your own appliance is actually pretty easy. The toughest part is figuring out what dryer part is the problem. We've created a list of the most common parts that can cause a dryer to not shut off. Use this list to diagnose the problem you're having and then enter your model number into the search box to find the right part for you. You'll also be able to access even more detailed repair help and tips about your dryer.https://www.youtube.com/watch?v=rXs6cL_prAQ
Mar 16, 2017 | Whirlpool Dryers
Whirlpool Gas Dryer, LGR5636EQ2, timer not moving on Auto (DryMis
If that is a 3 wire gas assembly then the timer is screwed.The orange wire when removed from the mix will make the thing advance. The trouble is in the timer. If that is a 2 wire gas operator you need to change the high limit and open up the outside vent. My opinion.
Nov 14, 2008 | Whirlpool GGQ8831L Gas Dryer
Electric dryer timer
the auto temp sensor is bad / Larry
Nov 01, 2008 | Kenmore 62602 Electric Dryer
Whirlpool gas model LGC8858EQ1 dryer works fine except the timer does not move.
ckd for wire from thermostat on rear of blower or high limit might be easier to look at wiring diagram wire is usually orange they have been known to come off voltage is feed to timer motor during auto setting from a thermostat
Jul 30, 2008 | Dryers
Dryers Logo
269 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
