Question about Toshiba Office Equipment & Supplies
Toshiba e-studio 453 displays add paper for all drawers with paper level full
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Sounds like your lift motors may be out.
Posted on Feb 15, 2013
  • 628 Answers
SOURCE: setup photocopier wirelessly
To change paper size setting, press the user function-->user-->drawer. In order to do network printing using network port (RJ45), u need to make sure printing kit (GM107x) is installed on your machine. It looks like an thumb driver. But u can also enable the 60 days trial periods in order to try out the network printing.
Posted on Jun 03, 2009
  • 46 Answers
SOURCE: How do you meter read Toshiba e-studio 453 copier?
"User functions"
"print total counter"
That's it......
Posted on Aug 13, 2009
  • 51 Answers
SOURCE: My Toshiba e studio 28 keeps saying to Add Paper
Tray motor is bad or gearing has fallen out of place. Could also be paper present sensor in the machine above the tray.
Posted on Apr 06, 2010
  • 62 Answers
SOURCE: Hello, my copier machine cannot detect paper
Pull paper tray out and set aside,
in the back there is white lever above the spring
push lever in ,a black actuator should drop down
if it does not it may be broken or stuck.
The tray select button on the control panel should allow you to use the side tray.
Posted on Jul 22, 2010
  • 21 Answers
SOURCE: toshiba e studio 305 purchased
drum cleaning blade problem replace. paper end sensor may have come loose from housing or missing
Posted on Oct 21, 2010
Add paper
open ur drawer and replace it
Jun 24, 2014 | Toshiba e-studio 455 Copier
My toshiba e-studio always indicates (add paper) in the second tray . there is paper and the cassette moves to its position.
typically its a bad paper sensor
you can look inside the cavity when you remove the drawer and see if it is hung up. If not it maybe a bad sensor
Sep 17, 2013 | Toshiba e-Studio 350 Copier
It wont print on heavy paper
You may have to use the manual feed tray on the side of the copier. It is not designed to run through the paper tray, to many bends....Good Luck
Mar 08, 2013 | Toshiba e-studio 203sd
My Toshiba e studio 28 keeps saying to Add Paper but the paper tray is full. How do I fix this?
Apr 05, 2010 | Toshiba e-Studio 232 Black and White...
Keeps saying add paper but paper is in legal and letter drawer
Check the display carefully, is it waiting for a different size to be supplied, or is it waiting for apaper to be loaded into the bypass tray
If you attempt to print/copy to a size not loaded into the machine, they will wait for the requested size. (depending on your optional menu settings)
This is especially a problem if you eg. try to print A4 size, and only have US legal or US letter loaded into the machine, and visa-versa.
Dec 09, 2009 | Toshiba e-Studio 232 Black and White...
F10 error code for a toshiba e-studio 28
Your HDD is having issues. You can try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Dec 03, 2009 | Toshiba e-STUDIO 282 Black and White...
Toshiba e-350 paper jam
rebuild the fusing assembly
Aug 10, 2009 | Toshiba e-Studio 350 Copier
Add paper to Toshiba e-Studio 282 Printer
you have a bad lift motor, this motor runs the top two trays (lifts paper to specific height) one or both sides of the motor can go bad (gears break) a good tech can replace in 1/2 hr. when you close the drawers you should hear the lift, if no noise...bad motor
Jul 21, 2009 | Toshiba e-Studio 282 Printer
It says add paper but it has paper loaded
Remove the paper drawer, and be sure there are no obstructions. Check to be sure nothing is stuck, and the paper is seated properly. Insert the drawer again, and see if the error goes away.
Jul 06, 2009 | Toshiba e-STUDIO 352 Black and White...
82 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
