Hotpoint wont fill properly
It starts washing soap from dispenser then stops
  • steve oliver Jan 23, 2013
    Hotpoint WMA62.I got in to fill last night but nothing else happened.
    Sergeant:
    Champion:
  • 249 Answers
What is your model number is then we can get started then
Posted on Jan 22, 2013
Jimster
  • 240 Answers
SOURCE: hotpoint wma10 washing machine wont stop filling up
You may have a problem with the pressure dome hose (has a cut or kink in it) or it may be a problem with the main control board. Sometimes that small hose inside the machine can get a cut or come loose. That sends pressure to the board and its valve to let the machine know that it has the right amount of water in it. If it has a hole or is blocked, that signal wont ever come on, and you have overfilling.
Posted on Sep 07, 2007
  • 10 Answers
SOURCE: wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
Posted on Feb 22, 2008
dutchman05
  • 487 Answers
SOURCE: soap won't dispense
the problem is quite easy. There are 2 valves on top of the dispenser box. When disconnected from power source please check whether the connections are secured. Sometimes the valve connections shake lose during transport or opperation. Also check the dispens drawer for clogging . This should be fixed easily. If you leave the top cover off and plug the machine in and start opperation there should be 120V on the valve connectors. If there is and water stil does not come out the valve is faulty and you have to order a new one.
  • Part for Model# WM2277HW
  • Part# 5221ER1003A
( ) indicates recommended quantity Valve assy, inlet
Posted on Apr 17, 2008
SOURCE: My washing machine wont work properly!!!!!
may i suggest that you check that the filter is not blocked, i had a very similar problem to this except my machine stopped washing and started making a beeping noise.hope this helps
Posted on Aug 03, 2008
rajeshmb
  • 38 Answers
SOURCE: kenmore elite he5 - error code F30
F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit..
Posted on Nov 11, 2008
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
How to clean soap dispensers on hotpoint washing machine
use very warm water and bleach then put mech on final rinces no clothes and let it go through cycle
Mar 02, 2015 | Hotpoint Washing Machines
What is code H20 on hotpoint washing machine
Check to make sure that the water valves are open and water is getting to the machine.
May 29, 2012 | Hotpoint Washing Machines
The soap tablet is left whole in the bottom of the dishwasher at the end of the cycle, so dishes aren't washed properly.
This means that either the soap cup dispenser is going bad or the control that sends power to it. You would need to check for proper voltage at the dispenser wax motor to verify.
Appliance & Refrigerator Repair
Mar 23, 2011 | Hotpoint Dishwashers
When hotpoint aquarius starts washing cycle, water comes out of soap dispensing tray. is there a blockage in the pipe to the drum . i allways use liquids instead of powders, so i find a pipe blockage as...
It could have over filled, or the drum is turning too fast, or there is a blockage in the dispenser hose. To accessw the hose, remove the top cover, and give the hose a good squeeze to clear any possible blockage.
There is little else it could be, so I am afraid it is a process of elmination.
Good luck.
Jan 25, 2010 | Hotpoint WMA64 Front Load Washer
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
The fabric softner release has stopped working
Most likely the fabric soft dispenser is clogged . this happens when you wash alot in cold water the left over fabric softner get very pasty and can clog it up. You can try filling the dispenser with hot water and run a cycle with hot water this should unclog the dispenser .
Nov 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
I just bought a used Kenmore standalone dishwasher and ran it for the first time. The dishes on the top did not get clean and the soap did not come out of the closed soup dish. at one point I took a shower...
The inlet filter is probably clogged. Try letting it fill up. Open the door to stop it right after it starts to wash Pour a gallon or two of hot water in and see it it works better Stop and do this everytime it goes to fill up. If the door opens , soap is used and dishes are clean ,clean the filter in the fill valve and possibly replace it. or the whole valve. (around $25) The soap door may be a seperate problem. I don't remember if Kenmore uses a spring or a small heat element to open the soap dispenser. Try cleaning it really well, shut the dispenser, open the door and turn the timer very , very slowly and watch to see if the dispenser opens. (WIth the door open the dishwasher will not run, but leave it plugged in.) It should open sometime during the cycle.
Jun 29, 2008 | Dishwashers
Where's the soap going?
Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
