Question about Sony Playstation 3 (PS3) Console
Ps3 screen says wireless controller not detected but controller is plugged into machine
Hi eveyone i have a ps3 and a Logitech wireless controller but won't connect to the ps3 please help
If there is a USB cable /charging port plug into PS3. If this doesn't have a USB cable /charging cable using your other ps3 controller turn ps3 on, scroll over to the settings, manage blue tooth accessories, turn controller on in discovery mode , and follow steps on screen to pair your PS3 and controller
Aug 11, 2014 | Video Game Consoles & Games
Tip
How to use a ps3 wireless controller.
<span>Ensure your playstation 3 is properly set up and connected to Plug the power cord for the PS3 wireless controller into one of the usb ports on the front of the PlayStation 3.<span><br /><br /></span><span>Plug the power cord for the PS3 wireless controller into one of the USB ports on the front of the PlayStation 3.<span><br />Plug the other end of the power cord into the access port on the top of your wireless controller.Allow the wireless controller to charge, leaving it plugged into the PlayStation 3 undisturbed for several hours to gain a full charge.Disconnect the PS3 wireless controller from the power cord. Press the PS button to start up the PlayStation 3. The PS button is in the middle of the controller. It is clear and displays the PlayStation logo of a letter P and a letter S molded together into one shape.Use the wireless controller to control the PlayStation 3, exactly as you would have with a corded controller for earlier PlayStations.<br /><span><br /><br /></span></span></span></span>
on Dec 06, 2010 | Sony Playstation 3 (PS3) Console
My INTEC Turbo Shock 3 Controller is not working i asked my friend i followed to instructions it did not help please help as soon as possible Thanks Peter
I have the same problem. I disconnected the key, plugged the controller with its original cable. Turned the PS3 on, turning controller on, pressing Sync, connecting the key in PS3. At that state, the 4 leds start to flash slower as it detects the key. Problem is I can never connect to console. I mean I press Home and it never connects. Its been working fine before I updated PS3 to 3.5 version.
Dec 27, 2010 | Intec PlayStation 3 Turbo Shock III...
Just bought an older 80 gig ps3 from a pawn shop. I received hdmi, power audio and video cable, and 1 wireless controller with usb cord. when I power up the unit it says detected an hdmi source.. but I...
you need to plug the usb cord in to the ps3 and the controller. then press the ps button then it should work. if it does not then keep it plugged in and press the small reset button with a pin on the back of the controller and then repeat the first step.
Jun 08, 2010 | Sony Playstation 3 (PS3) Console
How do i program the Sony BD remote without the actual PS3 controller
Use a game controller to look under System Settings - > Accessories. Choose Register BD Remote.
Jan 20, 2010 | Sony BD Remote Control for Playstation 3
Its a big ben wireless controller with no usb how do i connect it to my ps3
plug the usb thingy in the pc then connect the bigben controller then take out usb thing plug it into ps3 conct the controller and itz done
Jan 18, 2010 | Sony Wireless Controller for PS3
Ps3 controller
Turn your ps3 on and plug in your controller with the usb cable provided with the ps3 and then press the ps button while it is plugged in and it will connect. Then unplug the controller and it should wirelessly connect.
Jun 14, 2009 | Sony Wireless Controller for PS3
PS3 Freezes On The Wavy Lines
I had the same problem.
Whilst the machine is turned on, plug in the usb to the wireless controller and the PS3 should detect it and ask you to press the ps button (center of controller). Do this and you should get a menu, select RESTORE FACTORY SETTINGS, and you will have to input time, date etc but it does get machine working again - previous data is lost and you may need to keep trying as machine took several attempts to detect wireless controller - just persevere!!! I tried pressing buttons etc, switching off but nothing else worked for me ... Hope this helps
Dec 08, 2008 | Sony Playstation 3 (PS3) Console
PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
Oct 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
