Cable connection from router to tv - Computers & Internet
  • 7,627 Answers
If your TV has a Ethernet Connection (RJ-45) use a Ethernet cable, If it has a Wireless Adapter connect wirelessly. I don't know your TV's make Model?
Posted on Jan 23, 2013
What do I connect the Lan cable to. Computer or T.V
never had a TV that had LAN connector on it
Dec 05, 2016 | Computers & Internet
Can I get help with connecting my smart tv to internet as its not working for me thanks a million :)
Hi, commonly these TVs use a network cable for connecting to Internet through a router, another TVs are wireless enabled, in this case you need a WiFi router to get Internet in your smart TV. The process is similar as you connect a computer to Internet but the keyboard of your TV is the remote control, some smart TVs can work with standard wireless keyboards and mices to surf Internet as with a computer.
Nov 01, 2013 | Televison & Video
Belkin access point connect to smart tv
Does the TV, you didn't supply the Make, Model, have a Wireless Adapter? Connect the Belkin, you didn't supply the Model, to the ISP modem, connect a Ethernet cable.
Mar 07, 2013 | Computers & Internet
I have Sony Bravia KDL-46HX800 3D TV. My Ethernet connection stopped working. I can't get IP, my Sony blueray player doesn't have such problem (it is connected to the same net. switch). TV say
use a straight thru to connect directly to the router. Cross overs are typically used when connecting PC's directly together or daisy chaning routers or switches. Try a different port on the switch? Also from a pc, go to the DOS prompt and try and ping your TV. If your TV IP settings are all correct, and your network equipment is working, your should get a response from pinging your TV. If you don't, I would suspect a problem with your TV Enet port.
Jan 05, 2013 | Sony BRAVIA KDL46HX800 46 1080p LED 3D TV...
Can i connect my router to my hdtv?
Yes you can connect your HDTV to the router. If the TV has Ethernet port then you can connect the TV to the router using an Ethernet cable. Moreover, if the TV has wireless capabilities then you can even connect the TV to the wireless network of the router.
Regards
Anand
Oct 10, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I have a Roku, which allows me to transfer Netflix films to my TV. Since we no longer have a WiFi it must be attached by wire. I have a Linksys Cisco router. Can yo give me directions on installing both...
Okay, the router "if needed" first. Do you need a router? A router is used mainly to connect multiple devices to one internet connection. The Roku is one, if you have computer(s) also, then yes you need a router. Is the Linksys router wireless?
From the wall the coaxial cable TV/internet cable goes into the cable modem and another coaxial to the Cable box. Wire to the TV as desired. From the cable modem to the router use a RJ 45 cable into the WAN/Internet port. Now use another RJ 45 cable to the Roku and RJ 45's to the other ports marked 1 to 4 as needed for computers. If the Linksys router is wireless you can set up everything wirelessly.
Instructions for setting up the Roku is at the link below.
http://support.roku.com/entries/244199-how-do-i-set-up-my-roku-player
Good luck,
Cullen
May 19, 2011 | Linksys Computers & Internet
I plugged all my cables from my modem to the router and the internet is still not wanting to work on my laptop. Im still confused as to which plugs go where.
Please follow the physical connection setup to get your connection working,
1. Connect the modem cable to the router in the yellow color slot
2. Connect your computer to any one of the grey slot of the router
3. If your Internet Service Provider is cable provider (like Comcast, Cablevision) , then
unscrew the coaxial cable(TV cable) from the cable modem and unplug the power cable from the modem also unplug the power cable of the router then wait for 1min .
4. After a minute first screw in the coaxial cable and the power cable to the cable modem and wait till all the lights comes up on the modem , then turn on the Belkin router.
5. Then the light on the router will be Green , You will be able to access the internet .
Let me know it it works!
Thanks in Advance!
With Regards,
Prema.
Jan 10, 2011 | Belkin Connect N150 Wireless Router...
How to hook up tv with internet hard wired to existing router with wireless connection to computer ip address on computer will not connect tv to internet help
Assuming that you have an "IP" TV, run an Ethernet cable from the TV to one of the LAN ports on the router.
Run another Ethernet cable from your computer to one of the other LAN ports on the router.
Both the TV and the computer should now have Internet access.
Do you have a third computer that has a "wireless" connection to the router?
Sep 26, 2010 | Belkin (F5D7230-4) Router (587009)
I cannot get an internet connection through the router . It was working fine untill I had the cable co. fix my TV cable yesterday. Could this be related, or is my router broken?
It could be connections issue, connection from the Cable box to the Router, Disconnect the Router Cable, Turn off the Router and try to boot again.
This should help
Jun 26, 2010 | Linksys Wireless-G WRT54G Router
Router problems
Please answer the following questions --
Is this a new router installation?
IF so -
  • Who is your internet service provider?
  • If they are Cable TV based your wan side router configuration might be correct.
  • If they are Telco (phone line) based your wan side router configuration probably needs to be updated.
How is the connection wired
  • Starting with the cable tv coax or a phone wire plugged into a phone jack
  • Does this connect to a box provided by your service provider? (probably a modem/whatever box)
  • Does an ethernet cable (looks like a fat phone wire with wide connectors on the end ( 8 metal connection points) -- connect the modem to a single port not in a group on your router?
  • Does another ethernet cable connect one if the block of four ports to your computer?
If so you appear to be wired correctly
If not explain to be in the same order preferably how your equipment is wired.
After you reply I will provide additional steps.
Jan 02, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Computers & Internet Logo
David Payne
David Payne
