Question about Samsung DoubleTime
How to instructions for setting up my samsung double time cell phone
Add wi-fi network asks for network SSID what do I enter?
tinualbinale
  • 436 Answers
SOURCE: Im connecting to my home WI fi and it says authentication failed
You will be asked for a password only if you are connecting to a password protected WiFi network.You can set a password for your Home WiFi modem and after that you have to enter the password whenever you try to connect.
Posted on Sep 12, 2009
gomartymo
  • 20 Answers
SOURCE: could not connect to the internet using wi-fi connection
need to configure modem/router. just put ip address off modem into address bar on web browser. use admin as name and password for password. Check out portforward.com and all info will be easily found to solve problem.
Posted on Oct 26, 2009
darkpain
  • 316 Answers
SOURCE: I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
Posted on Jan 08, 2010
  • 101 Answers
SOURCE: How do I set up wi-fi for internet and also mms?
search for the network and connect it put security coode if asked but its known that ur fone doesnt connect to the wifi problem from the device itself
Posted on May 23, 2010
SOURCE: Unable to Connect to WI-FI with my Samsung Galaxy
I just had this same problem - I suspect it may have been a new app I installed that changed some settings.
I fixed mine by going into Settings>Mobile Network settings, then tick "Use packet data". Worth a try.
Posted on Dec 25, 2010
Carnot connect to wifi
Make sure the router is working as it should.
Mar 19, 2017 | Cell Phones
Tip
How to Connect Wi-Fi Connection
laptop user must know how to set up. to connect toWi-Fi locations. Using Windows XP in this tutorial, we'll go throughthe steps for setting up a laptop to access a Wi-Fi network. Some Wi-Ficards can be set to automatically detect and connect to Wi-Fi networks,though it is still important to know how to manually set up your Wi-Ficard to connect to a wireless network.
  • Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP keys are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their Web site or they'll give you the information when you purchase access.
  • Ensure you have a firewall program installed and running. This will protect your data.
  • Start up your laptop and look for the Wi-Fi network icon in the bottom right of the screen.
  • Click on the Wi-Fi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click onthe Properties tab
    This window shows the type of networking card installed. Click on the Wireless Networks tab.
    Once the Wireless Network Connection Properties window is open, you will have two options depending on how you set up your laptop. If you do not see any networks listed in Preferred or Available networks,you will have to manually add the SSID. Click on Add. You will have toenter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available Networks box.
    If you see the correct SSID showing in the Available Networks, then youn eed to click on Configure in order to enter the WEP key if that is required.
    In this window, enter the SSID for the Wi-Fi network you want to a ccess. Make sure you do not have CAPS lock or NUM lock while entering the information. If a Network key is required, click on "DataEncryption and then enter the Network key you have been provided with.Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly, a message will pop up and you will need to re-enter the key.
    Next go to Start - and where it says Connect To click on that and you should see choices similar to the graphic below. Click on WirelessNetwork Connection and it should work. Potential Problems & Their Solutions:
    Thereare occasions when the connection doesn't work. In these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall programd isabled, you will need to change your firewall settings. If your firewall program is not the problem, check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
    on Jun 24, 2010 | Computers & Internet
    How do I connect the WiFi
      1. To connect to a Wi-Fi network with a hidden SSID, select Add Wi-Finetwork from the settings. Then manually type in your SSID and password, and select your network security type. Select Save when finished. Now you can browse the web through your Wi-Fi router orconnect to other network devices.Jul 29, 2010
        Beginners: Connect Your iPhone, iPod Touch, or Android ...
        www.howtogeek.com/.../connect-your-iphone-ipod-touch-or-android-phon...
      Feedback
    1. Can't connect to Wi-Fi on an android phone? Here's the fix ...
    Jan 01, 2016 | Cell Phones
    HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
    Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
    To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
    and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
    through which the signal passes.
    Turning Wi-Fi on and connecting to a wireless network
    From the Home screen, press MENU, and then tap Settings > Wireless & networks.
    Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
    networks.
    Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
    are displayed in the Wi-Fi networks section.
    If the wireless network you want to connect to is not in the list of detected networks,
    scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
    settings, and then tap Save.
    Tap the Wi-Fi network you want to connect to.
    If you selected an open network, you will be automatically connected to the network.
    If you selected a network that is secured with WEP, enter the key and then tap
    Connect.
    Depending on the network type and its security settings, you may also need to enter more information
    or choose a security certificate.
    When your phone is connected to a wireless network, the Wi-Fi icon appears in the
    status bar and tells you the approximate signal strength (number of bands that light up).
    The next time your phone connects to a previously accessed secured wireless network, you
    will not be prompted to enter the key or other security information again, unless you reset
    your phone to its factory default settings.
    Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
    What does need a data connection mean
    To use Google maps or some other programs (like games), you need to be connected to a Wi-Fi network, not the cellular network. You will need to be in an area with an open wi-fi network or have a wireless router in your home. Find your password for the router's wi-fi network (it should be password-protected) and the SSID; you also need the encryption type (WAP, WEP, etc.).
    Press Apps on the Home Screen. Then press Settings and then Wi-Fi. Select Scan to locate available networks. While on the Wi-Fi tab, press Add Network. Enter the SSID with the keyboard, then touch Security type to select the encryption for your router. Then enter the password and finally press Save. (Some wi-fi routers will want the MAC address before you can add a device to the network. Go to the Menu - Advanced from the Wi-fi tab to get the information.)
    If the wi-fi network has been set up on the Tab, press Apps on the Home Screen. Then press Settings and look for the Wi-Fi On/Off icon. Toggle this to on. (You can also access this by touching the time on the Home Screen. Then touch Wi-fi on the Quick Settings list.)
    I hope this helps.
    Jan 16, 2013 | Samsung Galaxy Tab 2 7.0
    How do i connect to the wifi
    If you need to connect your HTC Wildfire to a Wi-Fi network then check out this simple, step-by-step user guide to getting connected wirelessly
    If you're using your HTC Wildfire for the first time, you can easily select the Wi-Fi network you'd like to join using the setup manager.
    When you opt in for either Mobile Network or Wi-Fi, or just Wi-Fi, the Wildfire will by default try to connect to a Wi-Fi network near you.
    Select the network you wish to connect to, enter the password if required and you're set up.
    If you want to change the settings, or set it up for the first time, you can do this through the Settings menu.
    Note: If you're attempting to access a network-based page or app, you may be required to set up a new Wi-Fi connection. When prompted, select the option to set up a new connection.
    1. Access the Wi-Fi settings menu by navigating to the Wireless & networksmenu
    2. Select Wi-Fi settings
    3. Choose a listed network, or add a hidden network by selecting Add Wi-Fi network
    4. If you choose one of the listed networks and it's secured, enter the password, press Connect and you'll be connected to that network
    5. If you wish to access a hidden network, select Add Wi-Fi network and enter the SSID
    6. If a password is required, you'll be prompted to enter this before connecting
    If Wi-Fi is turned off, you can now turn this on by ticking the box in the Wireless & networks menu.
    links that may helphttp://www.htc.com/uk/howto.aspx?id=3381&type=1&p_id=316 http://www.knowyourcell.com/htc/htc-wildfire/wildfire-guides/487458/how_to_set_up_a_wifi_connection_on_the_htc_wildfire.html
    Jul 28, 2011 | HTC Wildfire Cell Phone
    MY SONNY ERICSSON X8 WHY I CAN'T GET THRU IN WIFI
    To connect to a WLAN via Wi-Fi™:
    1. From the Home screen, find and tap Settings.
    2. Tap Wireless controls > Wi-Fi settings.
    3. Mark the Wi-Fi checkbox. Available Wi-Fi™ networks are displayed in a list under Wi-Fi networks. The available networks may be open or secured. This is indicated by the icon next to the network name.
    4. Tap a Wi-Fi™ network to connect to it. If you are trying to connect to a secured Wi-Fi™ network, you are asked to enter the security key for that Wi-Fi™ network before you can connect to it. The Wi-Fi™ connection is displayed in the status bar once you are connected.
    Useful tip:
    • The next time you connect to a Wi-Fi™ network, the phone will remember the security key.
    • To enable Wi-Fi™ network notification of open networks, mark the Network notification checkbox.
    • To connect to another Wi-Fi™ network, just tap another Wi-Fi™ network in the Wi-Fi networks list.
    • To scan for Wi-Fi™ networks manually, press the Menu key and tap Scan. The phone scans for Wi-Fi™ networks and displays them in the Wi-Fi networks section.
    You can also try updating your softwares by going to the sites below;
    Update Service,
    http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax8?cc=gb&lc=en
    PC Companion,
    http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pccompanion/xperiax8?cc=gb&lc=en
    Start the program and just follow the on-screen instructions.
    I hope this will help.
    Jun 16, 2011 | Sony Ericsson XPERIA X8 Cell Phone
    WiFi just scans but does not find any available networks to connect to??;le
    Hello Derek,
    Connecting Wi-Fi in HTC Desire Cell Phone
    From the Home screen, press , and then tap Settings > Wireless & networks.Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless networks.Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks are displayed in the Wi-Fi networks section.If the wireless network you want to connect to is not in the list of detected networks, scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network settings, and then tap Save.Tap the Wi-Fi network you want to connect to. If you selected an open network, you will be automatically connected to the network. If you selected a network that is secured with WEP, enter the key and then tap Connect.
    Jun 02, 2011 | HTC Desire Cell Phone
    Hi Team, My phone does not automatically connect to my home wifi. How do I get it to do that? Thanks B.
    By default, Android will remember. If due to whatever reason it 'forgot' then you may add it manually.
    1. Go to Wireless & networks menu
    3. Choose a listed network, or add a hidden network by selecting add Wi-Fi network
    4. If the network is encrypted then enter the password.
    5. If your home network is not broadcasting (hidden network), then select Add Wi-Fi network and enter the SSID name
    6. Provide the WEP/WPA key.
    Hope this helps
    Mar 09, 2011 | Samsung Galaxy S GTI9000 Smartphone
    How to get phone on home internet
    1. Click Set Up Wi-Fi.
    2. Click Next.
    3. Click Manually Add Network.
    4. Type the network name or service set identifier (SSID).
    5. Click Add.
    6. From the Security Type menu, select the security type for
    the Wi-Fi network.
    7. Specify the required security credentials.
    8. Click Connect to manually add and connect to a Wi-Fi
    network.
    Jan 05, 2011 | AT&T Blackberry Curve 8300 Smartphone
    Samsung DoubleTime Logo
    57 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Fotis Papastamatiou
    Bill Long
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
