Question about Roper REX3614KW Electric Dryer
Dryer won'y heat up
Dryer runs but no heat an if its a fuse or switch where are they located at on this roper dryer
    Genius:
  • 2,920 Answers
You either have a bad heating element or your limit switches are out..it could be either or both they are what control the heat
Posted on Jan 27, 2009
Roper dryer takes 2 cycles to dry clothes. How do I look at the heating element? OR since it is still heating, just not quickly enough, could it be something else? OR does it have 2 heating elements?
First of all, unplug the unit before working on it. Be careful inside a fuse box, dangerous voltages. It's usually safe to change fuses or flip a breaker so long as your not in a wet location. Most dryers run the heating element on 220 volts, meaning you can either have one larger breaker or you could have 2 smaller breakers or fuses. If that is the case, possibly one of these breaker "legs" has tripped. Check that first. I would sooner think one of the heating elements are open or "not heating". I would look up the Roper Model number and search for the heating elements section. Some do have a thermal fuse but I think that would cause both elements to quit. Take a look here: https://www.youtube.com/results?search_query=roper+dryer+heating+element+replacement
Dec 20, 2017 | Roper Dryers
Won't start roper dryer door closed properly still
Hi bootywatcher...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Sep 28, 2012 | Dryers
My roper dryer won't start unless i find just the
Hi jodiew0228...
Sounds like you have two problems
1...Bad timer...replace your timer
2...Something wrong in the heating circuit...
Check your Wiring
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Sep 16, 2011 | Roper Dryers
My dryer will not turn on, there is current to electric plug.
The thermal fuse is located on the back side of the dryer. If you see lint built up that fuse can be melted. If it is melted then the motor won't run because that fuse is in the same circuit as the door switch. So if the fuse is good look for a bad door switch.
Roper dryer tuneup
Service manual and more
Sep 11, 2011 | Roper REX5635E Dryer
IT RUNS BUT DOES NOT HEAT
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Roper Dryers
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
Dryer not heating, but the heating element looks fine
If it is a 220V. dryer.. it needs 2 fuses. One runs the dryer motor and the other one runs the heating element. Check the main fuse box. Turn off main power before messing with any fuses. Look for 2 big fuses, probably in their own block. You can switch these 2 around and try the dryer again. If it does not come on, then the fuse is bad and needs replaced. If nothing is any different, then the element may need replaced.
Oct 13, 2009 | Roper Dryers
Turns no heat continues to run? roper dryer model # red4340sq1
you need a Thermol fuse. This part is a non resetable fuse. you will need to replace it. it is located in the back of the dryer. you will need to take off the back panel. let me know if this helps
Oct 12, 2009 | Roper REX4634KQ Electric Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Dryer won heat timer dosen't avance
huntman, the model posted shows as a gas dryer. In the lower left side there is a square plastic peep hole. Take a putty knife and pull it off. Set the dryer to high heat and take a look in the hole. Does the ignitor glow? If it doesn't you either have a bad thermal fuse or a bad ignitor. Start with the thermal fuse. You will have to remove the back panel to get at it. I will attach a photo. You can ohm it out, or just jump the wires temp. to see if the ignitor glows. If theral fuse is good and the ignitor does glow, you probabley have a bad set of coils. These sit on the gas valve are easy to replace. The timer won't advance without the heat. Check this out first...Catriver..post back.
Mar 15, 2007 | Roper RGS7745PQ Dryer
Roper REX3614KW Electric Dryer Logo
167 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
