Question about GE Ovens
JkSo5BoW2BB MODEL3.4 DUTCH OVEN
THE OVEN PERHEATS AND THEN STATERS BEEPING F4 OR F7 OR F3 I PUSH CANUAL AND STARTOVER AGAIN AND IT MAY STOP AND BE RIGHT I NEED A FREE MANUAL TO KNOW HOW TO FIX THIS PROBLEM
Powerman
  • 68 Answers
SOURCE: Fault code F7....
The root cause of most F7 problems is a short circuit in between the two segments of the ribbon cable. In cases with a metal touch panel, there could also be a short circuit between the ribbon cable and the edge of the slot in the touch panel. __The solution is the same for both problems. Add insulation. My fix which has worked for hundreds of cases is to simply place a slip of paper in between the two sections of ribbon cable and for metal touch panels, also between the ribbon cable and the edges of the slot. Try to work the insulation down into the slot at least 1/8". See the attached photo which shows my solution. The short circuit is caused by what is known as a dendrite. This is a form of corrosion that is quite common to printed circuits. Moisture is the primary culprit.____Cleaning the contacts is often suggested. This only works for a short length of time. The movement of the cable temporarily interrupts the short circuit, but with time it grows back again.____Using the self cleaning feature seems to accelerate the deterioration of the cable.____Don't worry about putting paper in the top of oven. It will not get hot enough to burn. GE places service instructions in the top of the oven.____Be certain to turn off the power to the oven before opening the touch panel.____This problem is the result of a design defect in GE ovens that is common to ovens produced since 1998.
Posted on Apr 14, 2007
eagle338
  • 4889 Answers
SOURCE: F3 Error
This is due to a Defective control board..You have to get it replaced..
Posted on Oct 22, 2007
SOURCE: F7 message with beeping
...and here it is without having to wade through that whole thread:
take off the faceplate, unhook the wide, flat ribbon cord and use a pencil eraser to clean the metal contact points. Put it back together and you're good to go for a few months. When it happens again, fix it again. It takes about 5 minutes and it's free, which, by the way, is cheaper than buying either of the parts (which I would venture to guess will have the same problem a while down the road anyway).
Posted on Jan 13, 2008
CMV9
  • 594 Answers
SOURCE: GE JKP15 Electric Single Oven - Code F7
If possible i will need the letter that come next after the JKP15.
Posted on Aug 19, 2008
aborcass
  • 2651 Answers
SOURCE: f7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Posted on Nov 17, 2008
What do I do about oven beeping?
Could be control module, but not sure. I had issues with a code a long time ago, and the broiler kept coming on and wouldn't shut off, so finally had to shut it off at the breaker. Turns out the control module is fried. But just a thought.
Apr 28, 2015 | Kenmore Double 27" Electric Built-in Wall...
GE Oven Model # JRS04B0W3BB is showing an F7 code, how do I fix it? I can stop the beeping noise by pushing the stop button, but the beeping returns after about 30 minutes. I have pulled the breaker for...
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE 24" Built-In Single Electric Wall Oven
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
I'm getting a beeping f3 when I press bake. model is 31806660
F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Aug 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F7 error code- what does this mean?
Oven Fault Codes
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
When oven get hot f3 come on and the oven stop
May 04, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
F7 error steady beeping
Nov 17, 2008 | GE JKP45 Electric Double Oven
GE Oven displaying both F2 and F3 error codes; bad ERC or temp sensor?
F3 is Open oven temperature sensor circuit.
F4 Shorted oven temperature sensor circuit .
F7 Component failure.
To fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Oct 28, 2008 | GE JRP15 Electric Single Oven
F3 code and beeping
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Nov 17, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Oven won't stay on and give an F error message
Disconnect the power. Disconnect the sensor harness from the control. Measure the sensor resistance (white leads). The resistance should be 1080 ohms at room temp. If the sensor is open the resistance is usually over 2900 and you get an F3 message. If the sensor is shorted the resistance is usually less than 950 ohms and you get an F4 error message. Also look for damaged harness terminals if not a bad sensor.
Aug 31, 2007 | Ovens
Ovens Logo
26 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
